Question about Intel D845GVSR Motherboard
Turned off computer for the night now will not turn back on
The g/f turned off her emachines d2880 and now it will not turn back on. I've changed the power supply with a good one, and only the LED on motherboard lights up. with the power supply hooked up to motherboard none of the connectors show a good voltage but it works fine in another computer.
  • 18 Answers
Sounds like either a short, or misconfigured cable connection.
Posted on Nov 23, 2008
Emachine d2880 power on switch is bad. How do I work around? Is there a way to short the pins on mother board to turn on my PC? In words do you have connection details for power on switch wires to mother...
In your computer you have a power switch located on the PC chassis, you will find two wires coming off of it. At the end these two wires you should find a black 2 pin push plug. This should be connected to your mainboard. On your mainboard, the header for LEDs, hdd, power etc, you should see two pins labled power. Switch push plug goes over these two pins or these two pins labeled power can be shorted with a screwdriver, however this can be risky as it is very easy to touch other pins in the process and kill the mainboard. Rather use a push plug!
You can also read my guide as your computer my not be POSTing, my published guide is entitled My Computer is not turning on!!! Is it dead!!! No POST!!!
All the best!
damnor01
Nov 22, 2010 | E-Machines eMachines Desktop PC
My E19T6W 19" LCD monitor
Sorry, I have no solution, just thought you might like to know that I am having the exact same problem.
The only thing I can add is that it appeared after a night that my computer was set to do a weekly upload of Microsoft, anti-virus and anti-spyware updates. Also, that night we had some electrical storms. The menu pops up in the bottom right corner at very erratic intervals and sometimes just flashes, while other times stays on for minutes. It is driving me crazy!
I have tried updating the monitor driver and the video card using the "Device Manager" icon found in the "Control Panel". No luck. I have also ran anti-virus and anti-spyware scans and also used AVG to scan and fix registry errors. No luck.
I am open to suggestions.
Thanks
Nov 07, 2010 | eMachines E19T6W 19" Monitor
Emachine D2880 worked fine yesterday will not power on today
when you push the power button, fan or blower on power supply spinning or not? of not. your problem is power supply, nut if yes... did you hear any beeping sounds?
Jun 19, 2010 | E-Machines eMachines Desktop PC
Emachine D2880 no power clarification
your getting power to your PSU, via the green light on your mobo.
verify the PSU has a green light(most emachines do)
it sort of sounds stupid but, check the connection of the cable coming from the front of the case(the wires that connect to the mobo to the power button on the outside of the case.
if all else fails, take the pc out of the case.. put all components on a static free bag and start to rebuild your PC(without a case)
...this will rule out a short on the PC case, and faulty wiring from the case...
pretty much sounds like you've been through almost every step except replacing the PSU(you just said you tested/but your getting power to the PSU)
hope some of this helped
Sep 04, 2009 | E-Machines eMachines Desktop PC
Emachine D2880-No Power
Probably yes, the poiwer-source may be delivering "dirty" power (happens also when using a back-up generator, as in the power in the building goes out, or when used in an old RV, and the back-up kicks in) <--- is a safety feature to protect the CPU. Try also a different powerstrip, or head off to the neighbors and try their plug before swapping out the power supply.
In the end, you may wish purchase an inexpensive clone-tower, swap out the HD and processor (if you are spending too much time and money trying to band-aid the old one)
Hope this helps!
-- RT
Sep 03, 2009 | E-Machines eMachines Desktop PC
HP home computer will not turn on
i guess the problem is there in the power supply i.e, smps of your cpu. change it and check whether it turns on. if your pc fails to start after changing a new smps then the problem should be your motherboard.
Jun 18, 2009 | E-Machines eMachines Desktop PC
Computer will not turn on
Best way to check is to open your case. Near the power supply plug to the motherboard should be a little led light. If it is getting power to the board this light should be green. If it's unlit then most likely your power supply has gone bad. Hope this helps.
Dec 21, 2008 | E-Machines Emachine T5026 power supply **...
Won't turn on
Seems that your CPU-Cabinet is not giving the video output for your monitor. Please check the powercord and other internal assembly (if possible) that runs in and around the cabinet and restart the machine.
Sep 08, 2008 | E-Machines eMachines Desktop PC
Intel D845GVSR Motherboard Logo
91 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
