Question about Innovage Mini Flip Phone 1510255
Battery do not charge using usb
After 3 hrs the battery is not charged !
    Problem Solver:
  • 15 Answers
There is a power limitation that the USB-port provides. This is 500mA (milliAmperes). Therefore, if your battery needs more power to charge (see the specifications) you will have to wait longer. If the difference between the limitation of the power on USB-port and your battery specification is significant, you will have to wait centuries before the battery is fully charged.
Posted on Nov 23, 2008
  • Simos Gerasimidis Nov 23, 2008
    That means, as I already explained, that your battery needs much more power to be charged. Check the following:
    1. Is there a difference after the 3-hour charging via USB to the percentage of the battery life? If there is it means that the battery is charging and you will have to wait longer. As I have already explained, it might take ages until your battery is charged.
    2. Is the USB-port you are using coming out of a USB-hub? If you are using a hub, try to find/buy an ACTIVE, not PASSIVE one. By the term ACTIVE I mean that the hub includes an external power source in order to secure the maximum power output of 500mA of the USB-port.
Not hold charge for more than 3 hrs
the battery is fried, you will need to take it to a place that can replace it for you
Jun 02, 2014 | Apple iPod nano
I put a new battery in my camera charged it. Used the camera till the battery ran down. Now it won't charge . This is the second battery I've bought every time I try to charge it won't charge.
It takes over 7 hours to charge, so did you leave it charge overnight?
But while the original battery is chargable, disposable replacements are not. Here is what the manual says:
The supplied battery is a Li-ion battery. It charges while in the camera using the supplied charger. The camera can also use a Duracell CP1 disposable Li battery, which has the same form factor as the supplied Li-ion cell. HP claim the Li-ion cell will provide power for approximately 200 shots under "average" use and 100 shots with "extensive use of the LCD and flash".
Charge time for the battery using the supplied charger and in-camera charging is 5-7 hrs for a fully depleted battery. In the optional docking station, charging takes 2.5-3.5 hrs and using the optional rapid charger, charging takes 1-2 hrs. ... }
http://www.bobatkins.com/photography/digital/hp707.html
Aug 08, 2010 | HP Photosmart R707 Digital Camera
How can i charge my nuvi garmin 310 and how long
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} FIRST, make sure you have the GARMIN approved charger!!!!
There are three ways to charge the internal battery in your automotive GPS unit.1
  1. Use the provided vehicle power cable that came with your GPS unit. The unit will charge while powered on and using the device as well as when the GPS unit is powered off and plugged into a running vehicle. About 3 hrs for a full charge. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
  2. Use an AC power adaptor. Some units come with this power cable to plug the GPS unit into a wall outlet allowing the GPS unit to take a charge. For units that do not come with this cable, one can be purchased from Garmin's online store.
  3. For most units, the final way of charging the battery is to plug the GPS into a powered on computer with a USB cable2. This method of charging will be a trickle charge and it may take longer (like a full day) than the other two options, however it will still charge the battery. A USB cable is provided with a few GPS models. For those that don't come with this cable, one can either be ordered from the online store or you can use a standard USB to mini-USB cable that fits the unit and plugs into your computer.
1 - Please note that temperature can play an effect on the charging of a device. If the battery registers a temperature of 0°C and below or 45°C and above (32°F and 113°F respectively) then it will not charge. When connected to external power it will only be operating off of external power.
2 - The Quest® and Quest® 2 will not charge using a USB cable.
Nov 30, 2009 | Garmin NUVI 360 GPS Receiver
Iphone won't take a charge
  • Wen your charging the phone make sure you charge it fr 4 hrs because my iphone normally charge slow.
  • when your using usb for charging it will really take a coupe of hours the most is 5 hrs.
  • just chrge it 6 hrs and I can assure you it will power on.
Jul 23, 2009 | Apple iPhone Smartphone
Charging a garmin nuvi 255w
From dead flat it takes about 9-10 hours
do not leave on charger for more than that otherwise you will overheat and burn it out.
After each use recharge for about 3-4 hours depending on whether the unit has been used for that lengthyof time
Jun 30, 2009 | Garmin nuvi 255W GPS Receiver
Need to know how to charge garmin nuvi 255w using home wall charger.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There are three ways to charge the internal battery in your automotive GPS unit.1
Jun 26, 2009 | Garmin nuvi 255W GPS Receiver
Latitude L400 new battery not working?
u should charge new batt for about 6 hrs and then 2 to 3 hrs
Dec 20, 2008 | Dell Latitude L400 Notebook
Lands Phones Logo
113 people viewed this question
Top Innovage Lands Phones Experts
wiccan8thhouse
wiccan8thhouse
Computer Repairing
Computer Repairing
Kolbrun...
Are you an Innovage Lands Phone Expert? Answer questions, earn points and help others
