Question about Sony KP-57WS500 57" Rear Projection Television
Sony Kp65sw500 My TV started to show the blue color like a half moon on the left side. Then 3 weeks after the color verlapping on top of each other and pictures on TV look like doubles images. Please help..........
    President:
  • 1,284 Answers
You have 2 IC's in the convergence circuit and possibly a micro fuse that needs to be replaced. Consult a local TV repair shop.
Posted on Nov 23, 2008
How do I wire a MIC on a Cobra 29 LTD classic 4 pin mic?
would need to know the mic wire code you going to use. but half moon cut out at top as you look at it is top left 1-4 next row left side 2-3. 1 is cable/ unshield (common). 2 is MOD 3 is TX 4is RX... 1 is wire with no cover 2 is with cover rapped round wire RX is received TX is transmit, hope this helps. newer mic have different code wires so check with meter, red green and blue and shield is on some of the new wiring.
Oct 10, 2014 | Cobra 29 LTD CB Radio
Color problem with Toshiba
tv is on it's 'hospice' end of life routine..unless you want to gut it completely, and replace all the electronics..
Apr 19, 2008 | Televison & Video
On left half of the screen [ KP51WS510 ], a redish shadow showing
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 07, 2010 | Sony KP-51WS500 51" Rear Projection...
Hitachi projection model #43fdx01b.distorted color, blue off set. Half moon line at the top, taking top part of picture.
Ur convergence is dead.U need buy a convergence kit,U know how to solder right?Buy it at these websites.Tv Repair World.com or Ebay.com.
Sep 30, 2009 | Hitachi 43FDX01B TV
Color convergence problem
If you follow the instructions on the other thread, you should be able to resolve the problem. Try the simple stuff first. Resolder the pins of the convergence ICs and see if that alone resolves the problem. Sometimes that is all it takes.
Keep us posted.
Dan
Jan 30, 2009 | Mitsubishi WS48511 48" Rear Projection...
Vertical lines on my 40 inch lcd mitsubishi hdtv 1080
Similar problem with an eleven and a half month old LT-40148. Approx. 1 inch vertical banding line on left side of screen on all inputs. After about two weeks, same problem on the right side of the screen.
Fortunately this occurred two weeks prior to the one year warranty expiring.
Called Mits customer service and they referred me to an authorized service center who I happened to have dealt with before.
They picked up the set. The front panel (LCD screen ) had to be replaced. Set was gone for two weeks as parts were not in stock. There was no charge. I hope this screen last more than a year.
Jan 16, 2009 | Mitsubishi LT-40133 40 in. LCD HDTV
Bad picture
Try to consider the following tips:
Smearing out of one or several colors, best seen in txt-mode, my 27CE4599/30R smeared out in red and green, not in blue, fully exchanging the drivers (input and output complete, otherwise the RGB driver will blank the crt) moved the fault to the other color
Replace the 180K feedback resistors in the amplifiers with normal 1/4W metal film instead of 1/8W, they can become open circuited (in mine both green and red were faulty in this way). Change all 3 and not just the defective ones, replace also all the paralleled 75K resistors per color (fe by 47K+27K) to prevent bright color raster (they can also become open circuit)
Nov 29, 2007 | Toshiba 55H70 55" Rear Projection...
Hitachi 43FDX15B color convergence problem
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Nov 10, 2007 | Samsung HC-P4363W 43 in. TV/DVD Combo
Picture then fades to blue.
Please post me on this as well. My Sony just turned 4 yrs this Jan and just last week it started having the same problem. -Thanks!
Mar 02, 2007 | Sony KP-65WS500 65" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
184 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
