With the engine off put it in gear pull in the clutch if you can't move the bike the clutch is dragging and needs adjusting
Ok I tried that and I cant move the bike... Would you be able to tell me how to adjust the clutch?
unwind the adjuster so the lever has about 3mm of free play then starts to pull in the clutch
If adjusting the clutch all the way doesn't release the plates, then you have frozen or seized plates in the clutch basket. You will need to remove the clutch side cover and inspect/replace.
Did you say you made the clutch loose? You need to tighten the cable so that it actuates the clutch fully but not letting it slip.
Hi rm250 1998 start up let it heat up soon as click in to gear jumps froward and stalls tried even wen pull clutch in and try push it in gear doesn't roll
SOURCE: ran my rmx 250 out
Check the vacuum hose on rear of tap for cracks & fastness & turn tap to Prime if possible
SOURCE: gear/clutch problem
does not seem like the waterpump. is the clutch set too loose?
usually in wire based clutches, if the clutch cable is set to be too loose, or if it is frayed, and needs replacement, the bike will jump and stall.
check that.
SOURCE: clutch engaged engine stalls 2003 Suzuki GSX-R 1000
The bike has a sidestand interlock that prevents you from riding away with the kickstand down. That interlock is not functioning properly. Could have been bent or moved, unplugged, or perhaps the relay has failed. If physically activating the switch does not work, and connecting the wires with a jumper does not work start looking at the turn signal relay, some bikes have that circuit integrated into the relay.
SOURCE: RMX 250 model
Your bike is a 2000 model year. The 10th digit is the year designation.
Top rating on this answer please. Thanks!
SOURCE: my 1994 suzuki intruder starts but as soon as you
loose or broken ground wire ,could be broke under insulation, vibration of motor makes it lose contact. probably on gear indicator switch.
there is an adjuster at the lever end of the clutch cable wind this out until you have about 3mm of free play before you feel the clutch
I made the cluch as loose as I could and it still stalls... Could it be the clutch plates or basket? Thank you for your help
what do you mean by you made the clutch loose
The clutch lever sorry I made it with about 3 mm of play and then I unwound it as far as it could go
