Question about Lands Phones
LG vx8300-after getting a new battery the phone just about went dead in 3 days. When charger is on, the screen just says verizon wireless and then sometimes displays the battery is charging. When unplugged, it completely shuts off.
    Problem Solver:
  • 15 Answers
Is the battery the same type as the previous one? If not try to find if the one you have purchased can be used with your phone. In the case the battery is compatible with your phone, since you are having problems, just return it to the store you bought it from, cause there is high chance it is destroyed.
Posted on Nov 23, 2008
My cell phone won't charge or turn on when I plug it in.
this generally indicates a bad battery, try to purchase a replacement battery
if this does not fix the problem, then sorry to say, but the phone is shot, it is older now
Dec 22, 2013 | LG VX8300 Cellular Phone
My LG env3 cell phone won't turn on?
That happened with my phone, I was texting while in the shower(not smart) & it messed it up. On the front and inside screen it would turn to the Verizon Wireless screen, but then as if it were to switch to the actual wallpaper i had it set to, it would white out for .5 seconds, then turn to the same Verizon Wireless screen, what I did was plug it into the charger, turn it upside down, leave it like that over night, and it was perfectly fine. It's ironic that I'm going through this right now:/ haha.
Feb 15, 2010 | LG enV3 VX9200 Cell Phone
Phone will not turn on
call verizon it's time to find out if they can replace it or exchange it. Good luck, i have verizon and they are pretty good about this stuff so i hope they treat you well too :)
Mar 19, 2009 | LG VX8300 Cellular Phone
LG phone problem- screen blinks on and off
This is an obvious software issue.
I took mine down to Verizon to ask them to reboot the software.
The tech said that unlike a computer, there is no BIOS chip.
So they have to pull the motherboard to reboot.
And that was not within his ability.
So he pulled a field replacement from his cupboard.
Put my Battery and backplate on it.
And assigned my phone number too the new phone.
All at no charge.
Mar 04, 2008 | LG VX8300 Cellular Phone
LG VX8300 phone wet
I had this same problem and the problem actually is not with the phone. It means that the water damaged the battery. I purchased a new battery at a verizon store (because they have a 15 day return policy), popped it in and everything was hunky dory. Now I cannot say if there is any water damage to the rest of the phone, but when you are getting the error to use genuine battery, it is because that one is now damaged. New battery costs about 30 to 40 dollors
Hope this helps
Jan 16, 2008 | LG VX8300 Cellular Phone
LG vx8300 phone will not turn on
dunno. try to have it on the charger, and at the same time try to push and hold the power button. try it a couple times. my v180 from motorola did that and it seemed to work.
Sep 18, 2007 | LG VX8300 Cellular Phone
Phone won't turn on
I had to return mine to the Verizon store and they gave me a new one. This is what happened. I just received the phone from the mail brand new from the Verizon Wireless online store. However, I forgot to charge the battery when i turned it on to activate it. I did start charging it soon after though, and I dialed the *228 and hit 1 to program it. I turned it off, but I tried to turn it on later, and it wouldn't turn on. I let it charge over night, but still I was anble to turn it on. I'm thinking whatever programming was done killed the phone. When i went to the store, they put a new battery and it still wouldn't turn on. So they gave me a new phone.
Aug 05, 2007 | LG VX8300 Cellular Phone
VX8300 Phone! Problem!!
JJulie, I had a similiar problem with my phone (lg vx8300) where it would show a white screen saying "use genuine battery" and then power off automatically. Although there was no contact with liquid, there were signs of water damage (high humidity in my area, camera lens had some moisture) on the battery and phone. If you open the battery door, look at the bottom edge of the battery (where positive and negative posts are), and the spot on the phone located where the battery would line up with this dot. If either/both dots are red, then there has been liquid damage, and you will need to replace the phone. I understand that this is not good news, for me it meant that I had to pay to replace the entire unit. Check to see if you have insurance with your phone plan to get a lower cost replacement. Sorry for your loss, and hope this helped.
Jul 29, 2007 | LG VX8300 Cellular Phone
Lg vx8100 error message on screen: use genuine battery. power off 10 sec cuts off
Not exactly a solution. I tried leaving it off overnight and tried it several times after removing and inserting the batteries. I also cleaned the contacts with contact cleaner and a Q tip. It did not fix it. But I just left it off for 2 days meaning to go to the Verizon store and get it fixed or replaced. But I turned it on now and it fixed itself! Model VX8300. Maybe the contact cleaning did it but it had to dry more. You can use a Q Tip dipped in a cup of water with a teaspoon of Mr.Clean. But then rinse it with a water wet Q tip and then dry it with a paper towel. I used contact cleaner.
Dec 06, 2006 | LG VX6000
Lands Phones Logo
74 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
