Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Garage door opens after a power surge.
How to correct the problem yourself before replacing parts?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 98 Answers
Unplug the operator for 2 mins.and remove the wires to the wall control. plug the operator back in if the operator starts running  the logic board is most likely fried (bad) and should be replaced.
Posted on Jan 02, 2009
After a power surge my garage door openers both quit working. The outlets are both getting power. The power surge came from outside the home.
Power surges love logic boards. You should remove the boards and check for burnt or missing traces on the printed circuit. Especially around the small transformer.
Aug 26, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door opens w/ Power outages
You will need to get a surge protector on this unit first of all. You will have to replace the logic board and maybe the wall button or sensors depending on how bad the surge was. Any time the power goes out the logic board can be affected by it. Thanks BB
Oct 06, 2009 | General Electric GE 13-438 Overhead Garage...
Door not working no sounds
More than likely you have received a power surge and will need to replace the logic board before it will work. You can run it by hand by pulling the red cord until it is fixed. You can get replacement parts at searspartsdirect.com. Thanks BB
Dec 15, 2008 | Sears Craftsman LiftMaster Chamberlain...
Anytime a door opens and/or closes by itself I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
HOPE THIS HELPS
Dec 03, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Craftsman garage door opener
Replace the logic board. I have seen this problem in the field. More often than not it's due to power surge or lightning strike.
Oct 02, 2008 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 1/2 hp fuse?
logic board cooked, replace board or entire unit. use a surge protector. homwowners insurance covers damage.
Sep 12, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlian 2280 Whisperdrive
Check the light beam safety at the door's bottom, to see if something is getting in the line of sight.
Jul 25, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman 1/2hp Garage Door Opener
Thats one of the symptoms of a lightning strike or a power surge. Without actually being there I would suggest replacing the back-board. But as with lightning strikes and power surges sometimes other electronic components could have been damaged as well.
Jun 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Light flashing and control won't work
Your opener has been hit by lightning or power surge.
If it's not too old you can replace the 'back board' (the computer board on the back of the opener.) Also If the opener has safety sensors one or both of them may be burnt out too, and if it was really bad then the rpm sensor will go too. So you could be looking at paying half the cost to repair or just get a new opener. Up to you, and get a surge protector. Lift master has a good line of products and makes thier own surge protectors for thier products.
Jun 14, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
131 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
Marvin
Marvin
richie46
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
