Question about Acer Aspire 3690-2196 Notebook
Bottom left mouse buton sticks does not feel right
The button under the mouse pad does not work .its the button on the left side just below the pad id like to know how to remove the button without damage so maybe i can clean of debris.aspire3690 thank you in advance mike.
  • 18 Answers
That can be tricky, but I have done it taking a really small flat head precission screwdriver and going along the edges. Just be go slow and careful. Another option would be to just get a USB mouse to hook to your laptop.
Posted on Nov 23, 2008
Left buton in touchpad in hp probook 4530s doesnt work
Sounds like a faulty switch under the button. Have a look on ebay for a replacement.
Feb 10, 2014 | HEWLETT-PACKARD ProBook 4520s
Mark favorites delete internet
Left hand mouse = tap the bottom left of pad. Right hand mouse - tap bottom right of pad.
Nov 04, 2013 | Acer Aspire One PC Notebook
Blade MQX QUAD-COPTER
It's difficult to determine witch trim buttons effect the props. The only way to do this is durring flight. At low power, since you are working with 4 axis, each set of 2 buttons will effect the rotational speed of 1 motor. Typicaly in this set up, the left stick will control power and yaw(up and rotation left and right), while the right stick controls direction and pitch.(forward/reverse and bank left or right) Here is what I think you need. The left side bottom butons, control horizontal control. If you take off and notice the helo going to the left(banking, not turning) click the right button to attain horizontal stability. If you notice it is going slightly forward click the bottom button on the right side of the left stick. The same can be said with the axis control on the right stick. I hope to see this aircraft on youtube, as there is a shortage of these flying stabile anywere. good luck.
Apr 22, 2013 | Toys
The touchpad is locked
On some models there is a button at the top of the touchpad in the middle that toggles the touchpad on or off.
On other models you simply tap twice in the upper left hand portion of the touchpad to toggle it on or off.
And then there are some models that you use keystrokes to toggle the touchpad. Normally you would Press and Hold the ALT or FN function key near the bottom left portion of the keyboard then hit the key that toggles the touchpad. The key that toggles the touchpad will have the icon of a finger pointing at a square which represents the touchpad.
Below is what I found in your user manual on the touchpad. It looks like your touchpad is controlled by software and there is no button or keystrokes that control the toggling.
Customizing the Touch Pad and Track Stick You can use the Mouse Properties window to disable the touch pad and track stick or adjust their settings.
  1. Open the Control Panel, click Printers and Other Hardware, and then click Mouse.
  2. In the Mouse Properties window:
    • Click the Device Select tab to disable the touch pad and track stick.
    • Click the Pointer tab to adjust touch pad and track stick settings.
  3. Click OK to save the settings and close the window.
Below is a link to your manual
http://www.support.dell.com/support/edocs/systems/wsM70/en/ug/keyboard.htm#wp1052329
May 09, 2012 | Dell Precision M70 Notebook
The right side of my touch pad control button has stopped working
Did you check the settings for the left and right buttons under the mouse properties. Normally the left should be set on Click and the right should be set on Shortcut. If it's set to NONE then it will be inoperable. Better yet you can click the Default tab for buttons. Otherwise, it sounds like your touch pad needs to be replaced. The immediate remedy to this is to just go purchase a USB mouse and voila, you'll have the ability to left and right click.
Mar 20, 2012 | Toshiba Satellite A205-S4617 Notebook
Tapping on gateway nv 53 trackpad not working
This just happened on my HP2730P. I always used the click on the touchpad, plus used the right click button at the bottom. Yesterday it just decided to stop working and went haywier...it started doing the selecting and dragging while I was moving the mouse around and my left click stopped working. Obviously my enable tap click was already on cuz I used it all the time.
My solution was disabling the buttons under the "buttons" tab. Then my mousepad tap started working again, I regained function in the scrollbar on the mousepad again, and if I need to right click I can use the point stick buttons right above the pad.
OR
Does it start working when you reboot? If so, try changing the "Touchpad Sensitivity" option :)
Jan 24, 2012 | Computers & Internet
Mouse touch-pad
Click Start > Control Panel > Mouse > Device Settings (tab) > Settings (right hand side, immediately under the white box with your touch pad device listed)
Select "Tapping" on the left and make sure it is enabled.
If tapping was enabled, go to "Sensitivity" on the left and adjust the touch settings.
Thanks for using the FixYa forums!
Mar 31, 2009 | Acer Aspire One PC Notebook
Keyboard
From the Dell D620 Users Manual:
  1. Open the Control Panel and click Mouse.
The Mouse Properties utility is found like this:
Start Button>Control Panel>Printers and Other Hardware>Mouse
or in the Classic View
Start Button->Control Panel-> Mouse
Dec 31, 2008 | Dell Latitude D620 Notebook
How to set up mouse pad so it works with touch
Check in the control panel under mouse. There should be a setting to enable tapping. If there is a touch pad icon on the bottom right of the screen you can also right click on that and select options.
Dec 31, 2008 | Gateway MT3705 Notebook
Acer Aspire 3690-2196 Notebook Logo
105 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
