Question about Maytag Refrigerators
Ice maker clicks and does not make ice - Maytag Refrigerators
Your site did help me with the problem. I removed the ice maker from my Maytag MSD2756AEB and cleaned out the hardened ice that had kept the maker from cycling. I also noted that you had mentioned that the fill line might be blocked (frozen) solid so I hair dryed it open by warming the tube for a few minutes. This cleaning action would have cost me at least a couple of hundred but thanks to your posts it was business as usual for ice making in my home. Thank you so much for your site, FixYa.
Posted on Nov 23, 2008
Why is icemaker making a clicking sound?
Ice Maker Not Dispensing Ice ' ThriftyFun
Sometimes your refrigerator ice maker makes ice, but does not dispense it. ... If it gets pushed all the way back to the ice maker it prevents the metal arm from full ... Itry not to put anything on the shelf over the bin and also try to keep it pulled out just a little ... My ice maker is making a clicking noise and not making much ice.
Ice maker making ice, but won't come out thru door
If when you attempt to dispense ice (and it doesn't work) the whole refrigerator seems to .... Many have just bought a new refridgerator or don't use the ice dispenser. ... I'vetried to decrease the cold in it from the dial and that doesn't help. ... The motor was working and the auger would turn with no ice in bin but the added ...
Dec 25, 2015 | Samsung RH29H9000SR RH29H9000SR 29 cu. ft....
Replace water inlet valve for ice dispenser with new. When icemaker cycles it dispenses through the water dispenser instead of tube going to ice maker. I have switch lines around but can only get water...
The ice maker is what tells the water control valve to open so it may be correct now and the thermostat in ice maker may be defective. Part 27 or 627985 down below where it says Whirlpool Ice Maker Parts Breakdown and in that photo is the ice maker thermostat. If your ice maker has been used for many years the complete ice maker may be better to replace. Ice maker Model=> 4317943
Or click here=>Point and Click Then enter model or part number into search feature. If you have questions please ask, Thanks, Sea Breeze
Whirlpool Model ED5GTFXKQ02 Ice Maker Parts Breakdown
Dec 17, 2010 | Whirlpool Refrigerators
Our kitchen and pantry were flooded because the icemaker wouldn't shut off. My husband had to unplug the refrigerator to stop the water from pouring out
That is a rare happening but the solution is inside the ice maker itself. Click Here=>MSD2732GR Ice Maker Parts Break Down Part 13 is the Click Here=> 627985 Ice Maker Thermostat and sometimes it is just less expensive to replace the complete Ice Maker=> Ice Maker
Simply unplug the ice maker from inside the freezer section rear wall until you can replace the part or ice maker. If you have more questions feel free to ask here or my through my web sites. Thanks, Sea Breezesea_breeze_15.jpg
Appliance 911
Dec 08, 2010 | Maytag MSD2732GR Side by Side Refrigerator
Need user guide for kenwood ice cream maker
Go to the Kenwood site.
Click on the instructions tab. These can be printed or viewed.
Alan Hood
Dec 04, 2009 | Ice Cream Makers
Model ed22dqxaw10 - water enters the ice maker
If the water enters as if it were on a timed basis it would be clear that your ice maker either needs rebuilt or replaced. All signals are sent to the water control valve from the ice maker. The ice maker if working properly will begin its cycle when the thermostat tells the icemaker to begin by heating the elements below the ice maker to warm slightly to loosen the ice from their ice slots. After that any confusion would be in the front of the ice maker to tell the water to come on before the ice maker emptys its ice and begins a 7 second refill of water. If you would like to rebuild your ice maker click HERE and enter your model number ED22DQXAW10 then click on photo 11 ice maker on left of screen. If you would prefer a Replacement Icemaker Click Here=> P/N: 4317943 Try disconnecting the ice maker side of your dual water dispenser to insure that it is not the problem. Dual water control valve part number Click Here=> P/N: 2188542 Like to know if the problem has been located and resolved or if you would like to continue with my assistance contact => Sea Breeze just above the Fixya Tech Support Box on right. Or try that is having problems because of server overload. Thanks, Sea Breeze
Oct 26, 2009 | Whirlpool Refrigerators
LG LFX 25950SB, the Ice Maker is not working, just hear a click
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
Feb 22, 2009 | LG LFX25960 Bottom Freezer French Door...
Crosley side by side ice maker makes to much ice !!!!!!
Most ice makers have a wire bar that senses when the ice bucket is full. The bar lifts up when new ice is made. The ice maker determines if the ice bucket is full by lowering the bar back down after the ice drops into the bucket. If the bar hits the ice cubes in a full bucket, the ice maker shuts off. If the bar drops all the way and dosen't touch ice cube, the ice maker continues making ice until the bucket is full.
So you likely have one of the following problems:
1) The wire bar is missing or bent. Check to make sure that when the bar is pushed up, the ice maker stops making ice. Most bars will 'click' into the up position so you can shut the ice maker off. Push the bar up until it clicks into the up position and wait overnight to see if it makes more ice. If there is no wire bar over the ice bucket, that is your problem.
2) The switch the wire bar is connected to is malfunctioning. If you push the wire bar up and the ice maker continues to make ice, this is likely your problem. You will need a new ice maker unit. Try Appliance Parts Pros or EBay for a new unit.
Jan 07, 2009 | Hotpoint HSS25GFP Side by Side...
Salton ice cream maker manual
I downloaded a manual for the ICM21, same picture as yours, today, August 2009, from
Click on frozen dessert maker under Member Contributed Manuals.
Click on Salton frozen dessert maker
Scroll down to Comments, get this manual
Click on instructions
Salton ice cream maker pdf
The one there is for the old ICM21 ice cream maker.
Jan 16, 2008 | Salton ICM-21 1.5 Quart Ice Cream Maker
Refrigerators Logo
144 people viewed this question
Top Maytag Refrigerators Experts
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
