Question about Sharp (AN-XR10LP) Projector Lamp for XR10X
Lamp won't turn on.
Our lamp bulb is 1 1/2 years old. I have to unplug the bulb and plug it back in for it to come on. I forget what the model number is. I think it maybe xgu 6, I'm not sure. Thanks
  • siobhanmcph Jan 01, 2009
    The lamp light flashes green for about a minute, and then starts flashing red, meanwhile the standby light flashes green then they both go red. the lamp looks fine, but wont turn on. I hope we don't need to get another one!
  • siobhanmcph May 11, 2010
    That does not seem to do anything. It's like the machine is not responding at all. Thanks for the suggestion though.
I have a sharp xr10x ..........the problem lies in the bulb it needs a warmer temprature for the gas to expand in the bulb to fire and light up... hold a hair dryer up to the side of it fo a while and then fire it up still holding the haidryer up to it till it starts it may take a couple tries... ( this is a fix if your having a no buld startup problem and you know your bulb is still good) THIS IS THE FIX IF**** the lights will blink green for a while then one red and one green then will (shut off at both red) and not restart***
i had the same problem and thought id have to get a new bulb but this is the fix....
Posted on Feb 23, 2009
Someone else had a similar problem and there was a post to press the power off button for 10 secs on the remote and turn back on. It worked perfectly. Thanks
Posted on Nov 24, 2008
TV shutting down, lamp and power light blinking
I would try a new lamp. Lamps have varying qualities & usage conditions may cause varying life spans.So, even though the lamp may be 1 year old I would try a new one first.
Jan 07, 2015 | Samsung HL61A650C Television
I heard a pop on the Toshiba rear projection TV (model #62hmx84) and immediately lost the picture
Sir the problem of your unit is the lamp try to replace it it is much better to use a gloves and wash your hand after replacing the lamp because this lamp contains mercury. follow this steps.
1. Unplug the unit to main ac outlet. Remove the bulb housing cover from the back of the TV. Using a screwdriver, carefully remove the cover to reveal the old bulb. Using a cloth, remove the bulb from the TV by first unplugging it from the wiring harness. Carefully rock the harness back and forth until it comes free from the bulb. Push in the bulb slightly and turn it a quarter-turn to remove it from the bulb housing.
2. Install the new bulb. Do not touch the new bulb with your fingers, as any grease or fingerprint from your hands will damage the tiny mirrors in the bulb. Instead, carefully handle the bulb using the cloth. Insert it into the bulb housing and secure the door. Test the unit. Plug in and turn on your Toshiba TV and make sure that the new bulb is installed properly and that the image looks crisp.
3.
Reset the lamp time counter. Each Toshiba TV comes with a lamp hour meter stored in its software. If you do not reset the lamp timer, the unit may stop operating when it gets to a certain time (refer to your manual because each Toshiba TV is slightly different). To reset your Toshiba lamp timer, turn off the TV, wait 10 seconds, hold down the "on," "menu" and "input" buttons on the remote at the same time, and turn the power back on. A yellow light should appear in the bottom corner of the TV indicating that the lamp timer has been reset.
Hope this help good day and best regards.
Sep 23, 2011 | Toshiba 62HMX84 62" Rear Projection HDTV
I have a LG rear protection tv. I believe 52sz8d-is. When I plug it in the red power led light comes on and the bulb led flashes green but it won't Turn on
Tries change the tv projection lamp.Tv projection lamp ben in the tv like 1 1/2 or 2 years already,tv watches daily 4 or 5 hours every day.Yes.Than the tv projection lamp life are ended,now tv require a new tv projection lamp replacement.
Jun 05, 2011 | LG RU-52SZ51D 52" Rear Projection...
I have a panasonic projection TV, PT-60C13 that will not turn on. Upon pressing the power on button, the button flashes green many times, then flashes red five time then one orange flash. This red/orange...
The most common cause of Panasonic Rear Projection LCD TVs not starting is bulb failure. The PT-60LC13 users manual gives some help in translating the LEDs on the front of the TV.
If the TV worked normally for a period of time (months or years) and won't start, the most likely cause is bulb failure. There is no way to measure the bulb, sometimes the bulb is visibly damaged when it fails. Remove the Lamp Assembly and look at the bulb.
If there was an On-Screen Lamp Replace warning and TV won't start, bulb has failed.
The first step with all Panasonic Rear Projection TV "No Picture" problems is bulb replacement. If that does not remedy the problem, get a technician, there are no user serviceable parts. Guessing if the ballast, power supply, controller board or optical engine is faulty is not practical.
The Panasonic Lamp Gallery shows all Panasonic models and Lamp Numbers. There is also a link to Panasonic DIY bulb and lamp replacement.
easyab
May 05, 2011 | Panasonic PT-60LC13 60" Rear Projection...
My TV made a noise that sounded like a "pop" when i pushed the power button to turn it on. Then my lamp light came on and stayed on. I unplugged it from the wall outlet and then plugged it back...
The tv old projection lamp in the tv now like 1 1/2 or 2 yeears?The tv LED "LAMP" light up or flashes the projection lamp is dead.Yes,the tv require a new projection lamp.
Oct 31, 2010 | Mitsubishi WD-60735 Projection Television
My rca dlp doesn't turn on
You probably need a new projector bulb. Google up your model and buy the best warranteed one you can find. Buy a "caged assembly" and not just a bare bulb.
Then unplug your tv and get a screwdriver. Follow your model's instructions and just snug down the electrical screws. Do not overtighten them.
Then consult your manual on how to reset the lamp timer so it knows you put a new bulb in and fires up from the first try.
Treat yourself because you've just saved yourself a trip from a repairman!!
Aug 11, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
Ordered new bulb and fan on back. Is there any other fans or parts that could have caused the bulb to blow that I need to replace too. TV is 2 years old and a 50vs69a model
Lamp Ballast board it is what turns Lamp on! Call Encompass Parts
1-800-638-3328 Visit their website Encompass Parts Distrubtion.
Dec 23, 2009 | Hitachi Televison & Video
Replace bulb in housing for Infocus IN24.. i want instructions how to remove old bulb from housing.
1 Turn off the projector and unplug the power cord. 2 Wait 60 minutes to allow the projector to cool thoroughly. 3 Turn the projector upside down on a soft cloth so that the lamp door is facing you. 4 Slide the lamp door off. WARNING: Be extremely careful when removing the lamp housing. In the unlikely event that the bulb ruptures, small glass fragments may be generated. The lamp housing is designed to contain these fragments, but use caution when removing the lamp housing. Before replacing the lamp, clean the lamp compartment and dispose of cleaning materials. Wash hands after lamp replacement. Hg ? Lamp contains mercury. Manage in accordance with local disposal laws. 5 Detach the lamp connector from the projector by depressing the locking tab on the connector and lightly pulling it free. 6 Loosen the captive screw that attaches the lamp housing to the projector.Carefully remove the lamp housing. Dispose of the lamp in an environmentally proper manner. 7 Install the new lamp housing and tighten the screw. 8 Re-attach the lamp connector to the projector. The locking tab should engage when the connector is fully plugged in. 9 Replace the lamp door by sliding it into place. Be sure the lamp connector wires are not in the way. 10 Plug in the power cord and press the Power button to turn the projector back on. 11To reset the lamp hour timer, navigate to the Settings>Service menu and select Reset Lamp Hours.
Nov 09, 2009 | InFocus Office Equipment & Supplies
How do I fix a headlight that is burned out on low beam on a '97 Olds supreme
I believe that car has halogen lights, which are generally replaced from under the hood. Look behind the headlight, and you should see a connector that you can turn 1/4 turn and then remove the lamp. Get a replacement (before you start), unplug the old and plug in the new. BE CAREFUL not to touch the new lamp. Oils from your hand will cause the bulb to bubble when it heats up. Slide the connector back in and turn 1/4 turn to lock. I hope this helps you fix the problem.
Oct 31, 2009 | 1997 Oldsmobile Cutlass Supreme
Lamps
color wheel brakes then causes this same affects check your wheel
Nov 05, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
819 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
