Question about HP Color LaserJet 3500 Printer
Index toner for removal in HP 4500
I want to take the color toners out of a HP 4500 but don't know how to tell the printer how to index it around. From reading it appears that the printer will do it for you if the toner is low. But what if I just want to pull it out of a bad printer to put into another printer?
  • 81 Answers
If you open the printer up, you can manually turn the cartridge rack forward (away from you if you are in front of the printer) and remove the cartridges. If the printer is still functional, the printer should automatically do this for you when you open and close the lid. Hope this helps
Posted on Nov 23, 2008
My HP color Laserjet CP5225DN shows message: "Used Cartridge". How can I fix this?
It is telling you that a used cartridge is installed so that you know that the toner tracking system cannot guarantee exact remaining toner indications. The used cartridge message is not generated by a non-HP cartridge, Non HP cartridge will generate a different error.
Jul 16, 2015 | HP Color LaserJet Professional CP5225dn -...
What is the cause cyan toner not recognize
Did you remove the red packing strip? Did you shake the cartridge?Go here:
http://www.lexmark.com/publications/pdfs/2007/c950_2/UG/html/en/index.html
Then under "Maintaining the printer" click on "Replacing Parts and Supplies". You'll find a step by step process for replacing the toner.
Jun 19, 2014 | Lexmark "c950de color laser printer"
Black line on right hand side of the pahe
This usually indicates the the Teflon coating on the fuser roller is damaged and will need to be replaced. The fuser is the part at the back of the printer that heats the toner and fuses it to the paper. The heat roller is coated with Teflon so the toner does not stick. If something scratches this coating the toner will stick and come off on the paper in a line where ever it is damaged. Here is a link to an article showing how to check the toner, the guide is for the 2100 printer but the issue is the same.
http://www.ccl-la.com/blog/index.php/how-to-fix-hp-laserjet-2100-vertical-lines-on-print/
Jan 22, 2013 | HP LaserJet 2420 Printer
I have a HP Color Laserjet 2025. I recently replaced the color cartridges and when I tried to replace the black toner cartridge I got the message - "remove the shipping lock on the black toner...
My suggestion is to put the 2 cartridges next to each other and look at them as closely as you can. There has to be a difference between the one that works and the ones that give the error.
Something that just occurred to me. Check the slot where the black cartridge sits. Check it for something that could have fallen off the original cartridge and is wedged in the slot. Compare the slot with another cartridges slot.
Because one cartridge works and others don't, it tells me it's a physical(hardware) problem not electrical.
Jul 07, 2011 | Office Equipment & Supplies
I have followed the instructions exactly for replacing the black toner cartridge on my Magicolor 2300 DL, but i still have the error message "Replace Toner Black." I tried taking out the cartridge and...
If you have changed the toner cartridge, the printer must complete a calibration cycle (up to 150 seconds). If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
1. Open the Status Display (double-click on Status Display icon in the system tray on the lower right-hand portion of the task bar, OR click Start/Programs/KONICA MINOLTA magicolor 2300W Utilities/KONICA MINOLTA magicolor 2300W Status), and then check which toner color is empty.
2. From the Print menu choose Toner Replace...
3. In the Color list box, select the color of the toner cartridge to be replaced (CYAN, MAGENTA, YELLOW, or BLACK).
4. Select the capacity of the new toner cartridge (1500 or 4500).
5. Click OK.
6. When the toner indicator on the control panel starts flashing, open the printer's front door. The carousel is automatically repositioned so that the appropriate toner cartridge can be removed.
2300-0.gif 7. Insert your thumb and index finger into the two holes in the front of the toner cartridge, and then pull the cartridge straight out about 6" (15 cm).
2300-1.gif8. Support the middle of the cartridge with your left hand, and then pull out the cartridge.
2300-2.gif9. Remove the new toner cartridge from its shipping carton.
10. Remove the protective cover clearly marked 'Remove'.
Each toner cartridge has a colored end that corresponds to a color inside the cartridge slots. Always install the toner cartridge in the slot of the same color.
2300-4.gif11. Support the middle of the cartridge with your left hand, insert the thumb and index finger of your right hand into the two holes in the front of the toner cartridge, and then insert the cartridge so that the guides on the cartridge fit into the rails in the cartridge compartment in the carousel.
2300-5.gif12. Gently push the new toner cartridge into the printer.
13. Close the printer's front door.
The printer must complete a calibration cycle (up to 150 seconds) after any consumable has been replaced. If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
Sep 01, 2009 | Konica Minolta magicolor 2300DL Laser...
Toner not detect
If you refilled it then yes, you would need to purchase this chip as it is telling the printer that it is out of toner.
Aug 09, 2009 | HP Color LaserJet 2550n printer + HP Color...
Hp laser 4500 says toner is low or out even after new cartridge
There is a toner sensor in this printer that shoots a beam of light through the toner cartridge. As long as the toner is full and blocks the light, it sees it as being full. If it were the sensor, it would tell you this for all the toners, though. The printer also calculates how much toner may have been used and gives warnings based on that. It could be that this isn't getting reset after you change toner. You can reset the toner gage by going into the reset menu and selecting "New xxxx cartridge" and changing it to YES.
Mar 17, 2009 | HP Color LaserJet 4550n Printer
HP color laser 4500 says error 54.2. I reseated the toner cartridges. Where is the brake release, carousel drive motor and rotary drive assembly?
Click on this link:
http://www.laserquipt.com/support/idx/7/111/article/HP-Color-LaserJet-4500-and-4550-Series-Printers--How-to-Resolve-542-Errors.html
The brake release as the photo will show is to the right under the cartridge access door.
Oct 20, 2008 | HP Office Equipment & Supplies
HP Color LaserJet 2600n Printer
if you wanna to keep your printer in good health plz don;t tray to use any refile toners
Mar 30, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 3500 Printer Logo
62 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
