TOUCH FOCUS ERROR on Projection Toshiba TV
Hello Guru. I am getting the same error as ronny. My Toshiba has the TOUCH FOCUS ERROR message and the blue lines do not converge. I see a resolution was posted to replace the convergence IC's and that the Low OHM Resistors need to be checked for proper value.
Can you tell me how to do that? Thanks...
rbgaunt@yahoo.com I also have the same issue with my Toshiba 51inch rear projection. Also it is very "scratchy" and out of focus for the first 5 minutes that it is on (then it clears up - I can deal with that one!)
Looks 3D Red lines are off balance.
When we hit the automatic touch focus --it say touch focus error.
you can see how the blue and green lines vertical and horizontal are straight. The red has a moon shape to it.
I am not able to clear the Red focus error. I cannot find anyone in my area who will service Toshiba. Help me Please. TY
  • 1 more comment
  • shez126 Nov 23, 2008
    Thank You so very much.
    Ginko, Thanks so much. Where can I find the part number for the Toshiba 51H84 Convergence Board?
    I was just informed that my television is a 50H82 NOT the 51H84. Does this change the part number? Im sorry. I was misinformed. Thanks again
  • 19,396 Answers
The lowh OHM resistors are small resistors at the base of the convergence ICs, you need to test them for continuity using a multimeter.
Posted on Nov 23, 2008
  • 1 more comment
  • Ginko
    Ginko Nov 23, 2008
    To do the job you need experience in testing electronics and doing precision soldering.
    Better also to grab the service manual before starting the job. So that you can follow schematics and diagrams.
    You first test the small resistors at the base of the convergence ICs using a multimeter set to read impedance. If impedance is infinite, then the resistor had blown because the IC is faulty.
    A good alternative to replacing the ICs is replacing the whole convergence board. This is easier than replacing the ICs , even if more expensive. See : Toshiba Parts
    and Accessories
    or Partstore.
    To find Toshiba service in your area you can call Toshiba at 800-631-3811
    or see
    Contact
    Toshiba
  • Ginko
    Ginko Nov 23, 2008
    This should be the part, double check with the seller by calling them by phone and giving your model number first.: PD1731A1 PCB CONV, Toshiba 23761974X
    Vance Baldwin also have the part.Toshiba - Vance Baldwin Electronics
    Here is an used board, but buying that is a risk, I suggest buying a new one.
    Before buying the part perform a full convergence setup procedure by following the service manual. Convergence setup must be performed also after replacing the board.
    See if you can buy the service manual here :https://www.tvtechcenter.com/xcart/produ...">TV Tech Center :: Service Manuals :: Toshiba :: 51H84
    The board is expensive. ICs are much cheaper, just $7.99 each, but they are more difficult to install.
    Here is explained how to do.
  • Ginko
    Ginko Nov 24, 2008
    50H82is different, on 50H82 test also the hyper board that can give you picture problems that can easilyt been confused with convergence problems.
    Get the Service manual first, then follow the troubleshooting diagrams, on this model it will tell you to check convergence ICs and a group of capacitors on hyper board.
    You find the part number for 50H82 convergence board on service manual , or ask to the dealers in my previous comment ( Toshiba Parts
    and Accessories
    or Partstore).
    The ICs are stk392-110 ICs, same as the other module.
    See the following websites to buy the service manual.
    Service Manual 50H82
    TOSHIBA 50H82
    Toshiba - 50H82 Service Manual
2 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: TOUCH FOCUS ERROR on Projection Toshiba TV
i hope it doesn't fail again ebay parts have been know to fail because some are look a likes. trust a well know company like MCM electronics or B&D electronics
glad it fixed it for you
Posted on Dec 19, 2007
Touch focus error blue
The tv HYPER board it is dead aslo known as a tv convergence board.Tv have a convergence problems,it is dead.Tv Magic Focus button no longer response give error messages.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D picture look alike?Yes,than the tv HYPER board it is dead also known as a tv convergence board must have it components parts replaced like 2 STK convergence ICS and some or all of resistors too.To fixed the tv HYPER also known as a tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 12, 2011 | Toshiba 42H82 42" Rear Projection...
Toshiba 50hdx82 tv touch focus error blue is bowed.
Convergence is dead.Know how to solders.Must replaced the 2 Convergence ICS,and all it resitors.To do it ur self repair buy a convergence kit at Tv repair World.com,Repeairkits.com.The shop will cost u $300 for parts and labors.
Feb 04, 2010 | Toshiba 50HDX82 50" Rear Projection...
Trying to manually fix color convergence on Toshiba 57H81
The convergence ICs and the six 1.8 ohm 1watt resistors need to be replaced. You can get the convergence repair kit for your model at www.tvrepairworld.com which has the Two Convergence ICs and the six resistors plus the CD with instructions on how to do the repair.
Dec 02, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba 50H81 Projection TV
youre convergence ICs need to be replaced there are two of them they are both STK392-110 you can get replacement Ics and free instalation instructions at the following link.
http://servicemanuals.vstore.ca/
May 24, 2008 | Toshiba 50H81 50" Rear Projection...
My 57H81 won't converge, plus I get the "touch focus error" message. I could get manual convergence of blue, but not red. Plus, during touch focus the red would not move horizontally
Nov 25, 2007 | Toshiba 57H81 57" Rear Projection...
TOUCH FOCUS ERROR
The convergence IC`s need to be replaced and the related low ohm resistors need to be checked for proper value.
Oct 15, 2007 | Toshiba 57H81 57" Rear Projection...
Touch Focus Error
Even if the pix appears to be "OK", the internal convergence
alignment (in servicer mode) must be accurate within certain
parameters for the Touch Focus function to complete w/o error.
Adjustments should be done in "Full" mode,both HD & regular
signal.
Oct 13, 2007 | Toshiba 53H71 53 in. Rear Projection...
Blue ghost
If you have the ability to work on solid state electronics and know how these circuits work, you will need to replace the convergence IC's in this TV set. If you do not, call in a pro to assist you in this repair. Good Luck
Jun 20, 2007 | Toshiba 43H71 43" Rear Projection...
Televison & Video Logo
134 people viewed this question
Top Televison & Video Experts
