Question about Sunbeam 5891 Bread Maker
Blade inserted in bread when done
My bread machine is new. So far till the last 4 times, no problem. Now every time I take the bread out of the machine, the blade is inserted inside, difficult to get it out. Has to cut the bread to take the blade out. Your assistance or suggestion is appreciated. Thanks.
  • 1 more comment
  • suze_27 Dec 05, 2008
    same thing with my new machine - blade bake sinto the bread!
    same problem with mine- sunbeam should fix this ASAP
  • osita_honey Dec 15, 2008
    I really appreciate having this site where we can post our problems with the bread machines and find solutions. Thanks so much!
Use the provided hook to pull the blade out of the finished bread.
Posted on Sep 27, 2010
  • 4 Answers
Either spay a non stick spray on the blade/paddle before you began or simplly remove the the blade/paddle after the kneading cycle is completed
Posted on Dec 15, 2008
I just bought your breadmaker B2200 and i am looking for recipes for a basic white and whole wheat bread.The booklet does not have basic recipes. I am looking forward to baking bread for a long time to...
Basic White
1 1/3 cups lukewarm water
2 tablespoons powdered milk
1 1/2 teaspoons salt
1 tablespoon sugar
2 tablespoons butter or margarine
3 3/4 cups white flour
1 teaspoon yeast
1. Measure ingredients in the order listed into Baking Pan.
2. Insert Baking Pan securely into unit; close lid.
3. Select BASIC setting and 2.0 lb. loaf setting. Choose LIGHT or DARK crust setting.
4. Push Start button. There will be a 15-minute preheat delay before mixing begins.
5. The Complete Signal will sound when bread is done.
6. Using pot holders, remove Baking Pan from the unit and carefully turn bread out of Baking Pan. (Mixing paddle may remain in bread. Remove paddle when load if cool.)
7. Allow to cool before slicing.
Time 3:50 hours
100% Whole Wheat
1 1/2 cups lukewarm water
2 tablespoons powered milk
2 tablespoons honey
2 tablespoons molasses
3 3/4 cups whole wheat flour
1 3/4 teaspoons yeast
2. Insert Baking Pan security into unit; close lid.
3. Select GRAIN setting and 1.5lb. loaf setting.
4. Push Start button. There will be a 25-minute preheat delay before mixing begins.
Time: 4.10 hours
Feb 19, 2011 | Black & Decker Bread Machine
Cannot remove the blade from the pan
i have a kenwood bread maker mine has done the same you can live with it or buy a new pan and kneeder blade from amazon (bread maker parts) about £25 i live with it as my last bread maker did the same, if it still works leave it. the heat from the bread maker has made it fuse together
i hoped this helped............
Jan 29, 2011 | Breadman TR520 Bread Maker
When my machine goes into the next to the last rise I have a loaf about 5' but then when it goes into the last rise before it bakes it never rises high again. The finished loaf is about 3 1/2" high....
Not fully understanding this but it sounds like you are opening the lid too much and spoiling the rise. Only open the lid when at the dough stage if necessary.
Bread will not keep warm, it will steam and go wet and soft in the pan. Open the lid when the cycle has finished and remove the loaf.
Try re-setting your machine by holding down the start button till the display goes out.
Jan 28, 2011 | West Bend 41048 Bread & Dough Maker
Have a Panasonic Bread Bakery SD-YD205, the book does not have anything about removing the beater blade before the baking process starts. Can it be done without interfearing with the baking process? Thank...
I have a bit of experience with this one.My wife says she never removes the blades before baking .When your machine punches down your dough for the last time before it bakes...and if u can catch it in time u can remove them,but its not necessary.
Dec 16, 2010 | Vacuums
Needing the recipe for white 3lb sandwich loaf for the all in one model B2300. Lost the manual and there is nothing online
Hi Lyndseycoone:
Here is the recipe from the manual
3 cups of water (80 to 90 F)
3 tbsp butter or margarine, cut into pieces
1 tsp salt
3 tbsp dry milk powder
4 tbsp sugar
5 1/2 cups bread flour
1 1/4 tsp active dry or bread machine yeast
1. Measure ingredients into bread pan in the order listed
2. Insert bread pan into unit, close lid. Plug unit into wall outlet
3. Select Sandwich setting and appropriate loaf size (3 lb)
4. Press start button
6. Using pot holders remove bread pan from the unit and carefully remove bread from pan and turn right side up. (Kneading blade may remain in bread. Remove blade when bread is cooled.
7. Allow bread to cool on wire rack until ready to serve at least 20 minutes.
Hope this helps...
Darlene
Nov 06, 2010 | Black & Decker B2300 Bread Machine
When the blades are inserted do they have to click into place? Mine just sit loosly on the shafts--but do go completely down to the bottom of the shaft---however, the dough is not mixing or rising or...
Most bread machine paddles fit kind of loose so you can get them off for cleaning. Try turning on your machine like you were going to bake a loaf but don't put any ingredients in. Just watch, you won't hurt anything doing this, you are just trying to see if your paddles are turning or not. If they are turning then your problem is something other than the paddles.
Oct 05, 2010 | Zojirushi BBCC-V20 Home Bakery Traditional...
Why did the kneading paddle on my 1148X bread machine quit working. This happened the third time it was used. It did the initial mixing and resting. When it started the kneading process again, the blade...
Hi, If this is the third time using it, it could be defective. Return it for service. If not under warranty, try a few things. 1) Make sure the pan is inserted in the machine correctly. 2) Make sure that the paddle is not sticking, or the sealed bearing on the bottom of the bread pan is not broken or frozen. (Take pan out and see if you can turn the paddle freely by hand). Or finally, the belt may be loose and slipping, especially when it takes more power to knead the dough the second time. Good luck...Hank
Jun 12, 2010 | Toastmaster 1148X FastBake Bread Maker
First time use. set machine to dough and pressed
Hi, Keep the bread pan out of the machine and start a kneading cycle. Look through the lid window and see if the motor shaft is turning. If no...then the belt fell off. If the motor spins, check to make sure the paddle spins freely. Keep pan out and turn paddle by hand. If no then the bearing is frozen. If that's ok..make sure you inserted the pan correctly into machine. If everything checks out then it's a faulty machine. Before you do anything send it out for warranty service. Usually it's warranted for a year. Hank
May 12, 2010 | Black & Decker B2250 Bread Machine
I need a part
Bread Machine Parts Finder locates and sells used bread machine parts. We also sell other hard to find vintage kitchen items and spare parts. We are here to provide those hard to find items. Bread Machine Parts Finder searches for discontinued bread machines weekly.
Let us know what you need. Don't be fooled by blogs which state that pans & paddles are the only parts available and are priced so high that you should by a new machine, because of a low $50 or less price tag. New machines just are not built like those older machines that were built to last. New machines are built to ware-out quickly. I'm sure you know why. Most older machines were built to last & are easy to work on. I have hundreds of bread machine parts in my eBay Store & they're all less than $50. We carry all internal & external parts. We carry lids, lid hinges, control panels, rubber feet, pans, paddles, gaskets, belts, coupler-drives, pc-brains, inner-pans, heating elements, sensors, electric motors, timing gears, pulleys, screws and more. Just click on the link below to go to our eBay Store.
http://stores.ebay.com/Bread-Machine-Parts-Finder
Apr 01, 2010 | Welbilt ABM3500 Bread Maker
Broken kneading blade 6725
kneading blades get stuck in the dough and have a hard time removing the bread from machine when done
Mar 02, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
Sunbeam 5891 Bread Maker Logo
123 people viewed this question
Top Sunbeam Kitchen Appliances - Others Experts
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
