Question about SimpleTech SimpleDrive   STI-USB235/160 160 GB Hard Drive
Dead Harddrive I need help... My hard drive had been working fine until last week. I turned it on and nothing happened! Nothing. It is plugged in, all connections are connected as normal...but it is not turning on at all. I tried it at a different computer at a different location, and still nothing. Any ideas on what I should do?? Of course, it is my ultimate back up. ALL my pics, music, important documents... please help!
  • k2phillips Nov 25, 2007
    Hi same problem. My exterbnal stroage device does not turn on. it was working fine a few days ago. I hope I have not lost everything!
    Sergeant:
  • 310 Answers
Hi, sounds like your board on the hard drive is gone, only thing you can do is get a old hard drive the same and take the board off there and replace it, or send it away to the maxtor, western digital etc depending the make and they can take your photos off for a price aint sure how much. All the best John
Posted on Mar 03, 2007
Hp 8510 will not turn on sinse i put in hard drive
you have a bad harddrive or the cables are not set right
Jan 14, 2014 | Computers & Internet
My acer netbook 532h will not power on. just before problem the power on button stayed on and nothing happened; battery was pulled to turn unit off. unit has a blue light under the light bulb icon turn...
Two things to try first before we go further with the diagnosis:
1. Try to power up the netbook with the external hard drive disconnected & see if it will work.
2. Try powering up the netbook from the AC adapter only with the battery removed.
Nov 28, 2010 | Acer Computers & Internet
I have one 1TB Freeagent hard drive and it was working just fine,until one day it just disappears from my pc and i cant get it to work.I plugged the power cord off,waited for a few seconds,plugged it back...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue.
Let me know if you need further assistance. Thanks for using FixYa
Oct 16, 2010 | Seagate FreeAgent Pro 1TB External USB...
Type on keyboard but nothing happens
in back of the computer swap the mouse plug with the keyboard. That usually works
Apr 14, 2009 | Computers & Internet
Mount problem for external simpletech 100GB harddrive
Typically points to a hard drive failure. These normally happen without much warning. Have you contacted the manufacturer tech support?
Feb 23, 2018 | SimpleTech 100GB SimpleDrive portable USB...
My WD Mybook TByte HD is not being recognized
There could be many reasons, but I had the same issues.
It turns out I had mistakingly swapped the 12v DC PSU with another one, the drive would light up, it would click but that was it. Nothing. Gave me the runaround for ages. Seems they need more current than the little PSU I was trying could deliver, so I swapped it for a 2 amp supply and it works fine.
Mar 13, 2009 | Western Digital 250GB MyBook External USB...
My external hard drive won't turn on
Ok, this just happened to me, my western digital my book studio external drive was not booting up, i could hear the disk spinning, but it would then cut out and the light on the drive was never turning on. i called Western Digital customer support and found out that the proper way to connect a drive is to plug in the power cable FIRST then the data cable. Also, with the My Book Studio Edition you should never have to press the power button, the drive just turns on when you plug it in. Hope this helps somebody...
Feb 18, 2009 | Western Digital 500GB My Book Pro-External...
PSP no power
Try taking the battery out and plugging it into the wall with only the charger and see if it turns on. does The green light came on?.
Jan 01, 2008 | Sony PlayStation Portable (PSP) Console
SimpleTech SimpleDrive   STI-USB235/160 160 GB Hard Drive Logo
Top SimpleTech Computers & Internet Experts
Marvin
Marvin
Arora Singh
Arora Singh
Phillip Whisenant
Phillip Whisenant
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
