Question about Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Kdl40v2500 hdmi input won't work
My hdmi connection won't work on my Sony kdl40v2500. It used to then stopped is there a setting that I need to change
Thanks
  • Any Guy
    Any Guy May 11, 2010
    Can you tell me what you are trying to hook up to the HDMI input? Also, do you get sound or picture, or nothing at all?
circuitcity
  • 137 Answers
SOURCE: Color quality has degraded
Since this yellow tint color in on both HDMI and your composite input you may have a bad lite engine. This part is very expensive. There are no other way out. sorry. Part number A-1123-071-A
Average cost $504.00
Best regards
Circuitcity
Posted on Dec 10, 2007
SOURCE: HDMI input not working
I had the same problem with my 50 zenith when it was new. It needs a HDMI board replaced.
Posted on Jan 18, 2008
  • 103 Answers
SOURCE: HDMI Malfunction
You may have to activate that imput through your menu.Alot of plasmas have the ability to mute imputs.
Posted on Mar 03, 2008
mistersony
  • 320 Answers
SOURCE: HDMI Input Stopped Working Sony Bravia KDL-40S2000
Bad input board BU or AU
Posted on Oct 18, 2008
  • 267 Answers
SOURCE: Sony 46" LCD tv hdmi input replacement kdl-46v2500
replace that board
Posted on Mar 06, 2009
Sony DAV-IS10 doesn't get video and sound from Samsung 3D Blu-ray Player.
change the input settings on the SONY. sometimes there are are HDMI INPUTS AND OUTPUTS on high end systems. Make sure you are in INPUT
Mar 10, 2014 | Sony DAV-IS10 System
I have a Sony LCD television. Model # KLVS32A10. The HDMI input has quit working. Is this possible to fix or would it be to costly.
There are two possible reasons the HDMI is not working anymore. The first is that the set needs a software up grade which would be free from Sony. If the set has a ethernet connection on the back you can do the software upgrade over the internet. The software version the set has is under the support menu of the set. If it does not have a ethernet connection you would need to contact Sony at 1800-222-SONY to see if your set has the latest software version. If not, they will send it to you. If that does not fix it, replacing the main board will. Most of the time it is called the "B" board or the "BA3" board. To be honest with you, Sony's ultimate fix is to use the component cables and not use the HDMI inputs at all. It is disturbing that the technical support has that as a fix but you will not be loosing anything picture quality wise and you will never have the HDMI issue anymore.
Most issues with HDMI is that there are several different software versions for it and there is not one standard one that anyone uses. To make things worse, it changes from one product run to another across all manufactures. So you wind up with software incompatibilities.
I hope this helps,
Skyassoc
Dec 14, 2010 | Televison & Video
I bought an hp laptop and a sony hdmi cabel so i could be able to use my laptop on the lcd sony bravia tv. i connect my ps3 as well on the hdmi ports. at first everything was fine. no it doesnt work. i...
if you constantly change between one type of unit to another. say between your ps3 and another type of device then you could have worn the connector on the hdmi socket. it may need to be replaced. thats the best I can do. we have a bravia but dont change connections at all because it can cause many issues over extend use especially if youre changing devices whilst the set is on, as this can interfere and damage the internal circutry which may have shorted out the hdmi circuits.
Sep 11, 2010 | Televison & Video
I normally play my ps3 through HDMI. I am currently in a hotel trying to use it on a tv with only component inputs. How can I change the video setting without seeing the menus?
all you need to do is connect your ps3 to the tv using your hdmi cable and hold the on button on the ps3 for 6 seconds. You will hear the initial beep then a second beep, this will reset the settings on the system and it will change the settings to match the tv being used.
Apr 06, 2010 | Sony Playstation 3 (PS3) Console
I have my xbox 360 connected via hdmi to my yamaha rx-v363 receiver, and the receiver connected to my sony bravia lcd tv via hdmi as well. The xbox picture comes through to the tv fine, but the sound will...
Connect Xbox via HDMI to DTV/IN, Connect HDMI from out to Sony Bavia's HDMI/IN. Connect TV's Optical out to amps DTV/Optical in.
2X HDMI cables and one Optical are required.
Enjoy great sound :)
OH: choose the DTV input then stereo and then dolby 5.1 etc .. cheers
Sep 04, 2009 | Yamaha RX-V363 Receiver
Ps3 has no video
I would first try changing the inputs if there is an HDMI cable connected the PS3 will detect it and change the output to HDMI. Make sure when you connect any HDMI cables that the power is off on ALL Units that are using HDMI. Connect the cables then power up all units. Change TV and Receiver or Amp to correct HDMI Inputs. On the PS3 go to Display Settings over to the left of the Crossbar. Select output settings and select HDMI and everything after select AUTOMATIC! Then Set your Audio (Also use Auto) and Save by pressing X.  Good Luck!
Apr 29, 2009 | Sony PlayStation® 3 (80GB) Console
Hitachi 50V720 No sound with HDMI - no Component video inputs
Right now there seems to be many people with the same TV problems with sony and HDMI cables. Most of the solutions are resetting the TV and sony product. Try leaving your TV unplugged for a hour to let it reset itself.
Feb 17, 2009 | Hitachi 50V720 Television
I have a sony pfm-42b1 plasma tv with 2 vga inputs an 1svideo input.. i want to connect my ps3 hdmi cable to the vga input. i purchased the cable but nothing shows.. thanks for your help
you should change it from hdmi to cable. You can do it only on a hdmi tv when you do that you can use it for the pfm-42b1e because i had the same problem too. when you plug your ps3 to a hdmi tv you go to settings-display settings- video output settings than you change it to av multi. After you do that you can use it on pfm-42b1e
Dec 16, 2008 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Sony KF50we60 hdmi-dvi sound cuts when plugging into a ht-sf2300
DVI = HDMI without the audio connectors. So basically you need to connect your audio in some different way, PS3s allow you to keep your video signal as HDMI and change the Audio signal to component, so that is one way or doing it, not sure if the blue ray players allow you to do this though.
Nov 22, 2008 | Sony Grand WEGA KF-50WE620 Television
No input signal HDMI
turn on and hold down the on/off button for thirty seconds when it resets it will load up via hdmi lead this works both ways going from sd to hd, failing that have both connections plugged in both scart and hdmi lead then change the settings to hdmi when viewing through scart connector then flick to hdmi input and hey presto its worked.........
Nov 09, 2008 | Sony Playstation 3 (PS3) Console
Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
133 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
