Question about M-Audio Delta 1010 Sound Card
Loud buzz on every output with no audio
My delta 1010 is emitting nothing but an extremely loud hum out of every output. this, i believe, is the result of a blown capacitor due to a series of power failures in my house in combination with poor quality electrical wiring. i would return it back to m-audio only i bought it second hand and they don't want anything to do with it. my assumptions about the cause as well as my troubleshooting techniques could be miles off base, so i would be grateful for any advice that i can get. current setup: mac G4 dual 1.25ghz mdd m-audio delta 1010 pci interface pro tools mpowered 7.1 so far i've tried several cables, swapping pci slots, uninstalling/re-installing drivers and programs, swapping over to P4 PC, spdif and analogue.....all to no avail. please help. thanks.
  • Bay Blues
    Bay Blues Sep 23, 2014
    First I would go to the apple symbole
  • Bay Blues
    Go to the apple in the left hand corner of your browser click on it and open up SYSTEM PREFERENCES /the speaker symbol click on it and it opens up to show you the choices you have for you sound on your computer. Here you should be able to select the delta 1010 . If it doesn't give you the choice then something is wrong with the card. The PROBLEM I BELIEVE YOU ARE HAVING IS THE BUILT IN SOUND ON YOUR COMPUTER AND THE delta 1010 are both trying to play at the same time. This is how mine acted and this is how I resolved it.........~~~~~~*BB
Hi, Its a pretty easy fix of your handy with a soldering iron, just replace all of the caps near the power supply. Make sure you replace them with the same or higher voltage rating.
Posted on Mar 16, 2008
    Problem Solver:
  • 14 Answers
Look in the computer music mags and look fro M-Audio dealers. Ring them up and tell them the problem your having and see how much it will cost to fix. If it's humming then it's proably broke and needs repairing. Just make sure the sampel rate isn't set too low as well
Posted on Apr 13, 2007
I have a Boston Acoustics VR-500 Subwoofer with a problem. As soon as anything is plugged into the line level RCA jacks, the subwoofer produces a loud buzz/hum. I have tried connecting it to the subwoofer...
I'm thinking you have an open shield ground on the RCA input side. Connecting speaker inputs possibly restores the ground. Try connecting the high level inputs then disconnect the remote end of the cables (floating the grounds).
Then get out an ohmmeter and find that open circuitor or bad solder joint between RCA ground and real ground in the speaker's amplifier. Or.... if speaker ground kills the hum and you want to use RCA Line Level input to the sub, just connect one minus speaker output on your source amp to one minus on the sub's amp.
Mar 01, 2011 | Audio Players & Recorders
Hello! I purchased a pair of M- Audio Av 30 speakers years ago and I've noticed that at times they emit an annoying buzzing sound from the subwoofer parts of each speaker. I normally dont notice it because...
LOL. This is a common, easily solveable problem. Remove your cellphone or anything that emits radiation of any sort from the general area. Don't believe me? send a text message while sitting net to your speakers. It does this even if you arent sending a message because your phone sends intermittent signals to the cell tower. the radiation being emitted from the phone does weird things with the magnets inside the speakers.
Dec 27, 2010 | M-Audio Studiophile AV 30 Computer...
Where can i get a free M-audio 1010 to download?
You can download the Delta 1010 drivers from the website http://www.m-audio.com/index.php?do=support.drivers&f=736
I hope this works for you :)
Regards,
Aby
Apr 21, 2010 | M-Audio Delta 1010 Sound Card
A couple of weeks after initial setup of my brand new Onkyo XT-SR606 receiver, I noticed a loud buzzing noise that starts up approximately 10 min after the receiver is turned on. The buzzing is definitely...
The "buzz" you hear is a power hum made by the power supply transformer. It's technically called "Lamination hum" caused by the revering of electrical current through the power supply transformer. In some cases the hum can vibrate the chassis causing other loose material to vibrate. If you can, go to your dealer and check to see if other units of this same type typically make a hum this loud, and if not, see if he can solve the problem for you.
Feb 27, 2009 | Onkyo TX-SR606 Receiver
M audio sound cards
I don't believe that is going to work, the reason being the operating system will only accept one input device recording at a time...meaning you cannot record with 2 cards simultaneously....the only way you MAY be able to pull this off is if you record with 2 separate programs , and make each program use a different input device....
Oct 06, 2008 | M-Audio Delta 1010LT Sound Sound Card
M-Audio Delta 1010 PCI CARD
It has 8 mono inputs or 4 stereo pairs, which can be recorded in cubase or whatever sequencer at once.
Jun 17, 2008 | M-Audio Delta 1010 PCI CARD Sound Editing...
Using drum triggers with M Audio Delta 1010 and Digidesign MP 7.3
This site is useless. I posted this problem awhile back and nothing is posted for it. Don't waste your time here.
May 14, 2008 | M-Audio Delta 1010 Sound Card
Delta1010 on Hacintosh
WORKING DRIVER HERE FOR M-audio PCI:
 M-Audio Delta 44 (verified)
 M-Audio Delta 66 (verified)
 M-Audio Delta 410 (verified)
 M-Audio Delta 2496 (verified)
 M-Audio Delta 1010 (works for some)
 M-Audio Delta 1010LT (verified)
 Terratec Phase 88 / EWS88MT / TS88PCI (tested only on EWS88MT)
 Terratec EWX2496
I tested on my M-audio Delta 1010 with box today and everything incl. SPDIF is working great on my osx86 v_7 10.5.8 system! The only thing not working is midi as told on website. Im submitting file for the above sound cards! Dont Forget to donate some money to this guy!!!
http://www.audio-evolution.com/drivers/
http://www.insanelymac.com/forum/lofiversi...t25145-150.html
Mar 22, 2008 | M-Audio Delta 1010 Sound Card
Loud buzzing noise
Out put Capacitor breaking down - needs a serive replacement if available.
Nov 13, 2006 | Sony DVP-NS55P DVD Player
Open Questions:
M-Audio Delta 1010 Sound Card Logo
621 people viewed this question
Top M-Audio Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Jim Goldsmith
Jim Goldsmith
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
