Question about E-Machines (T2824) PC Desktop
Out of range
When i start up my computer it says out of range and goes black. How can I fix it?
  • Jay Glendenning
    Jay Glendenning May 11, 2010
    Is there anything else it says .. what is on the screen just before "out of range"
  • E-Machines Master
  • 4,806 Answers
Thats the diplay drivers that are bad, boot to safe mode (F8) and un-install the display drivers, reboot to normal mode and re-install drivers
regards
Posted on Nov 23, 2008
After self clean oven panel went black
Sometimes these can be fixed by unplugging it for a few minutes and plugging back in. I am assuming this is a gas top and electric oven. Verify the incoming voltage at the back of the range (not at the receptive but where it comes into the back of the range. Disconnect the plug before taking off the rear access cover and verify all the connections are tight before plugging it back in. Set volts to AC on your meter and check power between neutral and line (hot wire usually black). If this range uses 220 volts then check between the 2 lines (usually red and black). If the voltage is 120 or 220 respectively then you may have a fuse that blew (sometimes it is a fusible link in one of the power feeds) or a board.
Apr 05, 2017 | KitchenAid Kitchen Aid 30 In. Stainless...
Laptop is working fine until the screen goes black
The problem of black screen can also happen in other versions of the Windows. However, the symptoms and effects of the problems in all operating systems are almost same. For instance, when a user starts his Windows, everything goes fine. But when he logs into it there awaits a black screen instead of the normal desktop layout. An average computer user finds it very disturbing and has no clue how to fix Windows 7.
However, the best way to find a solution to this problem is to fix the registry errors in your computer which become the cause of all major Windows errors and crashes. The registry in Windows 7 is a very important component of the entire operating system and it stores information about the Windows settings. If these settings are not adjusted properly then there start to appear strange computer problems such as Windows 7 black screen.
Here are some discrete steps you shall also take besides fixing your Windows 7 registry which is inevitable for safer and stable computing:
* Conduct an antivirus and antimalware scan. Fixing for malwares after a registry scan gives an extra protection to the PC and saves PCs from lots of dangerous infections.
* Start Windows 7 in safe mode and restore your PC/system to the previous date after which you received the Windows 7 updates. It is believed that some updates may be behind these screen issues in Windows 7.
* Adjust your display settings since the wrong settings may also cause the Windows 7 black screen also called the blank screen. You can do this by starting Windows in safe mode.
Follow all the guidelines and start from registry repairing scan for Windows 7 to fix Windows 7 black screen. The best available tool to repair registry and fix PC errors such as this is Reg In Out.
Sep 12, 2010 | Acer Aspire One PC Notebook
My laptop turned completely black it says its on but its not doesn't load someone spilled beer on the bottom of my laptop what do i do???
If: the computer turn on, keyboard lights turn on, then screen goes black, then keyboard doesn't work, then unfortunately, I'm 99% sure the beer short-circuited the motherboard, which is an expensive fix and can range anywhere from $30 - $80 for a new one (plus the money for a techie expert to install this all for you). Sorry man, it happened to my laptop too :(
Jun 29, 2010 | Computers & Internet
I have a rca hd56w66, my screen shuts off but the audio still stays on. For a few days, it started fading to orange and then to green and then out to black. After about a minute, the picture would come...
Sounds like you lost the power supply to guns, now this doen't mean you have to go looking for it, you will need a repair person to fix it. Word of advise, if you haven't had one of these fixed before it can range in upwards of 600.00 or more to fix now days.
Oct 09, 2009 | RCA HD56W66 56" HDTV
After Windows has started and the setup screens show, my Kogi monitor says "out of range" and the screen goes black. How can I fix this?
Set the resolution lower.
It is telling you that the resolution you want is beyond its normal operating range.
just drop it to lets say 800 x 600
Then bump it up one resolution at a time until you get the message again, then drop it back one.
Running monitors above the acceptable range can drastically shorten their lifespan.
Sep 06, 2009 | Computers & Internet
Monitor comes on for seconds and then goes black
This may be because the resolution that is set in your user profile when you log on has been changed to a resolution not supported by the monitor. The best way to fix this is by going into Safe Mode (press F8 as the computer starts to load Windows) and change it to a lower resolution once you get logged in. 1024X768 is a pretty safe resolution to start with. Then restart and see if that fixes the issue.
Sep 02, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Gateway w350a when turned on wont get past the black screen
gateway w350a T-series HDMI power on but screen stays blank...Its just a black screen. Is there a fix for this?
Mar 31, 2009 | Gateway M305CRV Notebook
Monitor displays Msg. frequency out of range, screen is black
Start your computer and press the F8 when the manufacturer's logo screen is showing. This will bring you to the Windows startup menu. Pick "start in VGA mode" and windows will start up with video settings you monitor can handle. Then you can change your video settings so Windows will start normally with your monitor.
Mar 31, 2009 | Compaq Computers & Internet
E-Machines (T2824) PC Desktop Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
