Question about Panasonic NN-S950WA Microwave Oven
Microwave shuts off after 3 seconds
RE: Panasonic NN-950BC/WC microwave 5-year-old unit. All functions appear normal. Can set time for "rice" etc. Quick minute works. Manual time set works. In all methods, the unit starts fine and runs for exactly 3 seconds and stops. It does make rather weird noises for that 3-second period. Unplugged and replugged. No other symptoms or problems until today. Happy 2007! Thank you, Clive
  • 2 more comments
  • Clive Schaupmeyer Dec 28, 2006
    Thanks. Much appreciated. Will check with a service tech and take it from there. Thanks. Clive
  • Anonymous Mar 12, 2014
    Combination Microwave Oven Second one just failed and being returned again to Currys today Code H97 showed. We have just replaced our 27+-year old faultless microwave, own 2 Panasonic TVs and a brilliant breadmaker. This microwave would appear to be unfit for purpose. I note in Which reviews a number of people have had a lot of problems with this current model also. When returned to Curry's the first time they were told by yourselves to avise us to take it to Bradford - 30+ miles away. Come on Panasonic - this is not acceptable. Have told a relative not to buy one the same as its bad news. Not least of all is the considerable inconvenience this has caused. What is the problem with this model and what is being done about it?! We are becoming very disillusioned with Panasonic and its ridiculous customer care. Pass this to management please. What is your solution?
  • Anonymous Mar 16, 2014
    set the time, press start, Nothing happens, to get it to start you have to open the door and spin the glass tray, shut door press start again! Some times it takes 3 or 4 times of spinning the tray before it starts?!?! I've only had this micro 1 year! nn-sn651b
  • Anonymous Mar 24, 2014
    My lg microwave works normally but only for 30 seconds. It takes only 30 seconds automatically when said start no other time it accepts like 1 minute or 10 minutes. Other time even if u press the over stops after 30 seconds only everytime
  • Panasonic Master
  • 9,156 Answers
Although your model number doesn't seem to show up, the NNS950-series units are powered by an high-voltage inverter. And yours has failed. While an inverter (switched-mode power supply) is more efficient from a power consumption standpoint, it is more complex, thus more statistically prone to fail. These should only be examined and worked on by someone who has the necessary technical qualifications. Seriously. Often the machine-soldered connections in a microwave inverter are too weak, so they eventually fail, especially if heat is high in the area. They sometimes fail catastrophically. When not catastrophically damaged, you may hear clicking or squealing and may smell an electrical odor, which is sometimes obscured by the cooling fan. Sometimes a whole new inverter is cheaper than the time and labor required to fix the old one. If a technician is willing and able to troubleshoot and repair the inverter to component level, it will may be expensive, but may be worth it, especially if he or she will resolder and reinforce connections as needed as part of a thorough repair. That could easily make your inverter beter than a new one! You might be able to get some verbal estimates if you call Panasonic-authorized appliance / microwave repair shops and ask then specifically about inverter component-level repair and simple inverter replacement costs for your exact model number.
Posted on Dec 28, 2006
NN-T563 shuts off after 5 seconds
We recommend you use the below link to locate an authorized service center. Panasonic microwaves have a 5 year warranty on the microwave.
www.panasonic.com/repair
Apr 12, 2014 | Panasonic NN-S563 Microwave Oven
How do I get my Panasonic Inverter microwave out of demo mode? I think my toddler might have hit something to put it in demo!
Hello Two options to try: a) Press the Clock / Timer button 3 times b) Unplug, wait a few seconds, then re-plug to power up with the factory settings. You will need to reset your clock and any favourite settings.
This should work with all Panasonic Microwave models.
Good luck
Aug 10, 2010 | Panasonic NN-H275 Microwave Oven
My NN-T994SFR Panasonic Microwave shuts off after 1 second.
My unit shuts off after about 2 seconds. It seems like it tries to go, but it sounds like it stops working and then 1 or 2 more seconds run off and it shuts down. Then you hit start again and it lights up inside and then shuts down. It's only about 2 or 3 years old.Any solutions?
Mar 05, 2010 | Panasonic Microwave Ovens
Microwave oven no. NN-A514 cuts out when cooking
I had that issue and I opened the unit and there was a fuse near where the power went in. Went to the small local hardware store and they ordered it. It was well under $5 (can't remember) but it still works over 10 years later.
If the fuse blew again I would have trashed the unit.
Dec 21, 2017 | Panasonic Microwave Ovens
Model NN 9804 U microwave in Demo Mode
No owner's manual?
If you're in the US, find it here.
If you're not in the US, see Panasonic.net and look for support / download links.
Otherwise, I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Jan 14, 2010 | Panasonic NN-T888S Convection/Microwave...
Panasonic Model No. NN-S933BF Microwave Oven
No sorry the issue will be with eiher the inverter, the magnetron or the main timer board. There is a tracer signal that comunicates through these components and if it doesnt get to where it is supposed to go it wil just shut off, the big hint at that is the time interval. It is not something like a sensor heating up and causing a fault. it is not running long enough to get any thing hot it is in the electroincs. Too expoensive to repair, im sorry better to get a new one. Good Luck
Jun 17, 2017 | Panasonic NN-S950BA Microwave Oven
Panasonic Inverter Microwave, NN-H665BF, Smoking Issue
The magnatron is covered by warranty for 5 years and I just spoke with an authorized Panasonic repair center who said the inverter is covered on this unit depending on the manufacture date, like april 04 to october 05 approximately.
Jan 21, 2009 | Panasonic NN-P294SF Microwave Oven
Microwave Ovens Logo
1,081 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
