Question about Panasonic Video Cameras
Message ''tape not inserted'' appears.
When I want to play my video the message "tape not inserted" comes up even if the tape is inserted.
  • 3 more comments
  • kehau219 Nov 23, 2008
    I have a Panasonic MiniDV, when I want to record or view my tape the message "tape not inserted" appears even though my tape is in. The response I got was the tape sensor is not working. How do I fix this problem?
    Is there a specific area I should focus on?
    comment by fixyy states to change the menu settings back to initial set. I do not see this as an option. Could I have more info?
    someone suggested that I clean the parts with alcohol. Do you think it is worth trying? If so, do you know which areas to focus on or avoid?
    yurid316 suggests I try cleaning the lens sensor, can you tell me where this is?
    Brigadier General:
  • 6,966 Answers
Depending on the actual model of your camcorder and therefore its design, most sensors would be a small lever/tab that is pushed down when the bottom of the cassette presses on it. This then activates a small switch that tells the camcorder that a tape is in. In some instances, the tabl/lever could be mis-aligned and therefore the cassette would not be pressing on it. In some other cases, this tabl/lever could be broken. Yet in some other, it is the switch that could be faulty.
Whatever the probable cause, the unit has to be opened for a look & see. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 23, 2008
  • 728 Answers
Your tape sensor that tells the camcorder that a tape has been inserted is probably broken or the cord that leads from it is probably broken. I would not advise working on it yourself as getting to the area where the tape sensor is located to see if that is the problem could cause you to mess up something else and cause a bigger problem to occur and you will not be able to use it any more. You will have to take it to a repair shop and let them look at it and let them repair it.
    Sergeant:
    Champion:
  • 283 Answers
Have you tried another tape? If yes, try clean its lens sensor using a dried tissue. Post for further information. Please dont rate me if not satisfied...Thank you..
  • 905 Answers
You most likely cannot do this your self as qualified repair shops can only get these parts and it is extremely difficult to work on these , to even know what has failed will need testing because it may not be the sensor and may be a digital chip that failing or the circuit that controls the sensors
if you do not know what you are doing then I would suggest you take it to an electronic repair shop
electech
    Genius:
  • 1,550 Answers
Your tape is struck inside thats why you are getting message that tape is not inserted .
It is not able to move properly .
Hand strap may be tight loosening the hand strap will allow the tape carriage to move properly again.
If this doesnot work you need to replace carriage mechanism .
    Sergeant:
  • 229 Answers
Well you can try a couple of things yourself at home. Use compressed air to blow out any debris in the camcorder then you can clean the interior out with a solder/component safe electronics cleaner. Some folks simply use a q-tip and alcohol(denatured)not the good stuff to clean any visible components. Do this with the camcorder unplugged of course. You may be able to get the device to work again like this. It is worth a try at least. If not a repair tech can replace the part cheaply at any electronics repair store. Good Luck
    Scholar:
  • 181 Answers
The tape sensor is not detecting the tape in the device.
  • 2 more comments
  • fixyy Nov 23, 2008
    You can change the Menu settings back to theshipping condition.1 Set [INITIAL] >> [INITIAL SET] >> [YES].The initializing takes a little while.After the initializing is completed, the[COMPLETED] Indication appears withbeeps.Initializing will not erase the clock setting (-17-)
    Warning/Alarm IndicationsIf any one of the following indications lights up orflashes, please check the condition of the MovieCamera.3DEW (DEW DETECT/EJECT TAPE):Condensation has occurred. -53-Y (CHECK REC TAB/TAPE NOT INSERTED):You are attempting to record pictures on aTape with setting the accidental erasureprevention slider to [SAVE].You are attempting Audio dubbing or Digitaldubbing on a Tape with setting theaccidental erasure previntion slider to[SAVE].No Cassette is inserted. -12-6 (LOW BATTERY):
    The Battery is low. Recharge it. -9-0: The built-in battery is low. -18-: (NEED HEAD CLEANING):The video heads are dirty. -54-2END (TAPE END):The tape came to the end during recording.REMOTE (CHECK REMOTE MODE):Wrong Remote Controller Mode has beenselected. -9-UNPLAYABLE TAPE(OTHER FORMAT):You are attempting to play back a tapesection that has been recorded with adifferent TV system.UNABLE TO A. DUB(LP RECORDED):Because the original recording was done inLP Mode, audio dubbing cannot beperformed.INCOMPATIBLE TAPE:This cassette is incompatible
My canon camera seems to work fine in record mode. The LCD shows the video and the timestamp, and tape is moving. Yet in playback mode no matter what Tape I use (even if I know the tape has video on it)...
The playback head is dirty. Insert a brand new tape into the drive and perform a record, through the entire tape until it reaches the end. Then play a pre-recorded tape.
Nov 13, 2010 | Canon VIXIA HV30 DV Camcorder
I constantly get this message-"re-insert
No. The timing cam is misaligned. The carriage is suppose to accept the tape, and when you close the door, it pulls the tape from the carriage towards the head and drive the take-up reel to the supply reel as the head reads or plays back the tape. If the timing cam is misaligned, it will not accept the tape and thus you get the error message.
Nov 12, 2010 | Sony Handycam DCR-TRV280 Digital Camcorder
Sony DCR-TRV460 not playing back, blue screen
Follow this procedure to troubleshoot if a blue screen is displayed when attempting to playback video from the camcorder.
  1. Stop the tape.
  2. Ensure the tape has been rewound to the beginning of the video recording.
  3. Play the tape.
  4. If the issue is not resolved, stop the tape and remove it from the camcorder.
  5. Clean the video heads of the camcorder using a dry head cleaning cassette.IMPORTANT: Follow the instructions for use provided with the head cleaning cassette. It may be necessary to use the head cleaning cassette more than once per session.
  6. Reinsert the tape into the camcorder.
  7. Play the tape.
  8. If the issue is not resolved, stop the tape and remove it from the camcorder.
  9. Insert a different tape with video footage into the camcorder.
  10. Ensure the tape has been rewound to the beginning of the video recording.
  11. Play the tape.
NOTES:
  • If a blue screen is still displayed, then the camcorder may require service .
  • If the tape plays back correctly, then the first tape may be faulty or there is a problem with the video recording.
Aug 13, 2009 | Sony Handycam DCR-TRV460 Digital Camcorder
Error message; has something to do with insertion of tape. Looks like triangle over straight line. beeps and blinks, will not play. Working when loaned to a "friend", returned in this condition...
Will it record on a new tape? Will it play a different tape? Have had a similar problem with a different camera. Think it had to do with the record mode / play back. A bit like standard play and long play - are there setting like that you could change?
Jun 26, 2009 | Sony Handycam DCR-TRV27 Mini DV Digital...
JVC camcorder won't play and says Condensation present
Get the tapes professionally transferred to DVD before they deteriorate. As for the camcorder, any repair would not be cost-effective.
Apr 06, 2017 | JVC Video Cameras
Can the Panasonic AG-DV2500 play 90 minutes Minidv tapes?
the DV2500 will not play LP (90 minute) tapes. when an LP tape is inserted, it will play for 2-3 seconds, and then eject.
Nov 28, 2008 | Panasonic AG-DV2500 DV/Mini DV VCR
"Re-attach the power source" but tape is stuck, door open
I had the same problem. First, depress the reset button, located on the camera body (where the LCD screen closes over it). It is hard to see at first. It is important that the camera be set to the OFF position. When the camera is whirring after the reset, then hit the EJECT button so the tape comes out. Take the tape out and insert it back. That's it. My camcorder worked fine and let me record or plaback once I followed those steps.
Vic
Aug 22, 2007 | Sony Handycam DCR-TRV280 Digital Camcorder
Pink strips through screen and tv when playing back tapes
clean the heads - the '5 stripes' are the symptom of dirty heads.
May 16, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Video Cameras Logo
22 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
