Question about Whirlpool Calypso GVW9959K Top Load Washer
Water collecting around top of washer
At the end of all cycles, when i raise the lid to remove the clothes, a large volumn of water pours into the washer. It appears that a seal is allowing water to leak into the top area of the washer (just under the lid). I've checked the rubber gaskets and all appear ok. If someone is having/had a similar problem and has found a solution (or a suggestion) please advise.
Use liquid soap. I had the same problem and after Sears replaced the lid seal twice, it dawned on me that it must be something else. A did some tests and found if detergent sat in the dispenser, the water hit the pile of detergent and splashed up under the lid. Either make sure all the detergent goes down the hole before you start or use liquid soap.
Posted on Apr 07, 2007
We're having the same problem. I too have checked everything and even lowered the water pressure in the event it was too high and shooting water over the detergent dispenser. I'm at a loss as to how to correct it. however, after reading all that was stated on ePinions.com, I'm regretting that I listened to Consumer Reports and bought the thing (although it's been one of the best washers/dryers we've owned although it's a little noiser than I was expecting). If anyone finds a solution in the next few months, please let me know otherwise when the thing starts falling apart, I'll probably get a new washer and dryer.
Posted on Mar 03, 2007
My kenmore washer model 110.27802690 will not spin and will not drain the water. the motor will make a humming noise but won't come on. we took all the clothes out and it will now fill up the washer, wash...
Under the lid there should be a small hole with a push down flap and that should be the automatic stop, which can either be a bad switch under the top of the machine or could be a broken trip/ prong on the lid that pushes this button when the lid is dropped. When the machine reaches it's spin cycle time leave it turned on and raise the lid push down on this flap with something careful to keep hands out of the washers tub and see if it works then!
Mar 02, 2018 | Kenmore 24032\24036 Top Load Washer
Neptune MLG2000A doesn't drain completely and has moldy smell
You need to clean the stationary "brush" that collects lint and debris from the water during the cycle. The brush can be seen around the tub directly touching it along the bottom/front of the device. Right were I pour my detergent in, after the cloths are in there. To remove the debris I use a bottle brush. You can expect to use trial and error for your attempts. As far as the water being left.... My device has always left water in the bowl. I periodically just run a cycle with no cloths and bleach...HOT.....Mine is not spinning at the moment...again....I think its another call to the local dealer....AGAIN....
Jun 11, 2010 | Maytag Neptune MLG2000A Front Load Stacked...
WM0642HW LG water level is too low.I want to get more water in it. Any suggestions? Is there any way i can override sensors so i can get about 5 gallons more water in it?
YES YOU CAN RAISE THE WATER LEVEL ! Raise the top of the washer lid by removing the 4 dispenser screws. Push side of dispenser tabs to drop dispenser down off from lid. Using an opener or flat item, insert into lid front edge to depress inward the metal top hold down clip. Do the left side first then the right side. Raise the lid.You'll see the water level sensor switch on the inner cabinet upper right side. You will see a set screw for a phillips screwdriver. Slowly turn that screw CLOCKWISE about a quarter turn. With washer cylinder emply,and holding detergent dispenser assembly upright so it won't spill water into inner cabinet area, start the washer.You will see the water level rise to a higher set point than just to the edge of the gray cylinder baffels.I have set mine to fill to the edge of the rubber door seal. I wouldn't go any higher than that. I see no need for the water level going over onto the glass window area.Ever since i raised the water level so my clothing tumbles in water instead of wicking up water as before and only becomming fully saturated nearing the end of the wash segment. The new adjustment has ended all of the complaints i had earlier about this washer not cleaning or rinsing well. My laundry is clean the first time around and all my washer needed was a few more gallons of water to work with. LG themselves were of NO help when i called dozens of times before .They just gave me the run around and never a straight answer about the water level except nothing could be done, it was based on laundry load weight, too bad so sad. That was TOTALLY UNTRUE! I found out how to adjust it by another owner of the LG WM0642HW posting this info on how to raise the water level, and how to go about doing it.I've not had to do a single rewash since turning that water level switch higher.Honestly!
Mar 15, 2010 | LG WM0642H
Soap-not residue-still on clothes
Wow that's a strange one.
Are you pouring the soap into the tub onto the clothes or using a soap dispenser? If using a dispenser, it may be malfunctioning, try pouring soap directly into the tub under the waterfall while it is filling.
When the machine is agitating are the clothes on top being drawn under the water? Usually this occurs as a rolling motion from the edge of the tub towards the agitator. If the top layer of clothes have an air bubble trapped in them they may not be submerging into the water. Any soap on top may not be dissolved.
Finally, if you are pouring soap into the tub, make sure you are not spilling any onto the inside of the lid or in the softener dispenser. It could get trapped in the lip around the edge of the lid and be spilling onto the clothes when you open the lid at the end of the cycle.
Do you have the same problem if you use powder soap?
Nov 12, 2009 | Washing Machines
Wash starts before water is full
most washers if put on a large load do start going around before the water has finished filling this is just to get all the clothes fully wet before the proper cycle starts to wash them it is just how the washer copes with a large load peter
Nov 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
I was washing clothes -- in the rinse cycle and the washer just stopped -- I think right before it was to drain the water. I redistributed clothes, turned the knob until it was in the rinse cycle again...
It sounds like your lid switch is bad . Raise the lid , and insert something into the lid switch hole on the top ( where the lid actuator goes into the hole ) , to see if the washer drains . Without your complete model number , can't give you a part number .
Oct 11, 2009 | Kenmore 15864/15862 Top Load Washer
Amana nav5800aww water on floor after spin cycle
Sounds very similar to having something such as a sock or small article of clothing that is too large to be sucked down the drain hose into the pump. So what happens is it hangs around between the inner and outer drums and sometimes gets itself lodged over the drum drain hole, and can allow water to be centrifically flung over the top of the drum. Most times when the spin cycle stops, the article of clothing will dislodge and float around inside the drum only to do it again later....
If you can remove the top of the machine, you can usually see the gap between the two drums and use a piece of coathanger wire with a small hook on the end and "go fishing in the area between the two drums and close to the drain hole location... bet you'll find something in there... Let me know how it goes... and if I can help .. ken
May 10, 2009 | Amana NAV5800A Top Load Washer
Too much water on clothers
this is common with this model
may need a new lid
Oct 20, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Can I use color safe bleach in my new cabrio, and if so where do I put it?
According to the manual on pages 12 & 13.
1.
Place a load of sorted clothes into the washer. See “Laundry
Tips.”
■ Load evenly to maintain washer balance. Mix large and
small items. Items should move easily through the wash
water.
■ Load only to the top of the basket as shown. Overloading
can cause poor cleaning. Items need to move easily
through the wash water.
2. Pour measured powdered or liquid High Efficiency detergent
into the detergent dispenser. Always use the detergent
dispenser, and do not put detergent directly onto clothes in
the washer.
3. Add color-safe bleach (powdered or liquid) to this dispenser,
if needed. Be sure to match powdered color-safe bleach with
powdered detergent or match liquid color-safe bleach with
liquid detergent.
4. Pour measured liquid chlorine bleach into the liquid chlorine
bleach dispenser, if needed. Bleach is diluted and
automatically dispensed at the proper time during the wash
cycle.
■ Do not overfill. Do not dilute. Do not use more than 1 cup
(250 mL) for a full load. Use less with a smaller load size.
■ Follow the garment and the chlorine bleach
manufacturer’s directions for proper use.
■ To avoid spilling, use a cup with a pouring spout. Do not
let bleach splash, drip, or run down into the washer basket.
■ At the end of the cycle, a small amount of water may be
left in the dispenser. This is normal.
NOTE: Use only liquid chlorine bleach in this dispenser.
5. Pour measured liquid fabric softener into the fabric softener
dispenser, if desired.
■ Do not overfill. The dispenser holds 3 oz (94 mL), or a
capful of fabric softener.
■ The fabric softener is dispensed in the final rinse. If Extra
Rinse is selected, the fabric softener will be dispensed
during the Extra Rinse.
■ Do not spill or drip any fabric softener onto the clothes.
NOTE: Use only liquid fabric softener in this dispenser.
6. Close the washer lid.
7. Press POWER. This turns on the washer display.
8. Select a Wash Cycle. See “Cycles.”
9. Select the desired Modifiers. See “Modifiers.”
10. Select an Option, if desired. See “Options.”
11. Select Delay Wash, if desired. See “Delay Wash” in the
“Modifiers” section.
12. Press START. The wash cycle begins, and the display shows
the estimated remaining time. The lid will lock.
NOTE: If you do not press Start within 5 minutes of pressing
Power, the washer automatically shuts off.
The way that I read the manual, your color safe bleach would go in the detergent dispenser. Your liquid chlorine bleach would go in the bleach dispenser.
Please rate this solution
Aug 03, 2008 | Whirlpool Washing Machines
Whirlpool Calypso GVW9959K Top Load Washer Logo
98 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
