Question about Weather King 10AJA1801AH Air Conditioner
Screaming Weatherking Heatpump!
Please advise what compressor blanket can be installed on weatherking model 10PJB30A01. Cant get any sleep at nite....I either have to be cold or listen to this screaming heat pump.
  • emtlorraine Nov 23, 2008
    NO! Was this an automated answer? My specific question was not answered. Guess I will look elsewhere.
    Lorraine with a BRAIN
  • 833 Answers
If the scream is something new...have  tech look at it.  You've got problems coming and you don't want that on a really cold day.
Posted on Nov 23, 2008
My Weatherking is about 8yrs old and just recently stopped blowing cold air. Its feels like outside air temp coming thru the vents. I changed the air filter about 30 days And clean the condensor coil...
It sounds like your compressor is either not running or is low on refrigerant. If it is low on refrigerant it means you have a refrigerant leak somewhere in the system. The leak would have to be found and repaired or the unit is going to keep leaking down every time you pay to have it recharged.
Sep 04, 2011 | Weather King 10AJA3601AH Air Conditioner
Heatpump wiring diagrames
I am sorry but this question is posted in the wrong category. It is not a musical instrument repair and has nothing to do with bass drum heads. Please ak the question again and tell us who made it and what model number it is..
Nov 12, 2010 | Remo Weatherking Clear Ambassador Bass 22"
Blower fan comes on but compressor will not come on
if contactor does not pull in could be low voltage problem
Apr 06, 2010 | Weather King 12AJA4801AH Air Conditioner
Weatherking 3 ton Run Capacitor
Could be; age,lightning,power surge,defective wire,loose wire,tight compressor. Capacitors fail sooner or later. They are like batteries they do not last for ever.
Aug 04, 2009 | Weather King Heating & Cooling
Compressor Problem WeatherKing 13AJA36A01
Your warranty on your WeatherKing is five years on the compressor. When you buy a compressor to go in your unit it is 1 year. Several resons for bad valves. Dirty evaporator coil, overcharged and bad evap fan motor. James
Jul 10, 2009 | Heating & Cooling
2 TON WEATHERKING HEAT PUMP VIBRATION AND NOISE.
Your friend is correct. Installing a sump or p-trap in the suction line will probably help. The oil may be leaving the compressor but can't get back.
Feb 23, 2009 | Weather King 10AJA6001AH Air Conditioner
WeatherKing Unit needs compressor and is under warranty
have you contacted the company who installed ? try there first, if no luck with the company, contact the manufacture directly, explain to them your problem and try to have them help you with getting the company who installed to do the right thing and replace the compressor under warranty, you may have to pay a warranty install charge, but it would be alot less than having to pay for a whole new compressor, or new unit, put your ducks in a row, get model and serial numbers, date of install, who installed it, and the manufactures warranty on the compressor, that way you will be ahead of the game, best of luck, hope that helped
Jan 19, 2009 | Heating & Cooling
Weatherking Air Handler
I do have a technical .PDF document for this model. It is not the users manual. It shows the matching coil, Air flow requirements, and other technical data. If this is what you want please provide your email ( I don't know of any other way to send it to you on this web site) address and I will send it to you. Thanks.
Jun 25, 2008 | Ruud Heating & Cooling
Open Questions:
See all Weather King 10AJA1801AH Air Conditioner Questions
Weather King 10AJA1801AH Air Conditioner Logo
236 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
John Tripp
John Tripp
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
