Question about RCA HD52W59 HDTV Projection Television
Trying to fix fuse on convergence problem
Hi again. OK here my update. i received the fuses in mail today and was in the process of fixing the fuse when i noticedwhat i suspect might be the cause. there is a solder point number 10 onwhat says CAD or on the half circle solder points on bottom. I hope uknow which im talking about. well nu 10 there is completely no solder and the hole is corroded. there is no part of the circuit board to solder to. it just doesn't look normal to me. but if it is please let me know. i will not try anything until i find out about this tyvm
  • DLaboy Nov 23, 2008
    ty for your reply but there is no place to solder to. the area around the lead is completely gone and only like flakey circuit board around it. you can move that lead around and all the other leads have a big glob of solder around them :( i son't even know where all the solder from that lead went to as i have checked the ground and bottom of tv. i have a picture of it but my digital camera didn't take a good picture so i used my 35 mm but have to develop it. i will like to show you it but it will take a few days to get film back. I really thank you for your help
  • 1,030 Answers
Nice obsrervation! lead free solder this half circle is it directly under the big black componet with the red wire. i not familer with the notation cad. but the circle is charteristic of flyback. This is the common point that cause the fl231 fuse to blow.i would suggest removing the solder with a ****** or wick the clean and reappy solder when you replace fuse. always look around for bad connections like this. lead free is really become a problem with rca
Posted on Nov 23, 2008
  • Willie Howell Nov 23, 2008
    sorry bout that i guess the filter saw a dirty word remove with a vacum desolder device
How do I fix my yamaha receiver? I turned it up and it shut off,tried to turn on heard fuse blow. Replace one of the two fuses 10A 125v that one blew also.
Fuses blow due to an overload. What has happened in you case is one or more of the output devices (found on the big heat sink) has shorted and acting like it was a piece of wire. Now you have to find out which. By the way it might have gone due to bad speaker wires or speakers, or speaker wires touching each other.
Jan 11, 2016 | Yamaha HTR-5890 Receiver
Hi i got the korg pa50sd when i swith it on it shows me korg pa50sd boot loading files then this goes off, still the light on display is on but blank display with nothing on it ,. i was trying to find any...
NOT a fuse... thaat person knows nothing. There is something wrong for sure. Check if one of the buttons or keys MIGHT be stuck down (depressed). Sometimes the units check that all the control buttons are up and they don't really tell you why they fail to start. Beyond this a repair shop is in order.
Jul 11, 2011 | Korg PA50SD Pro 61 Key Keyboard Bundle
Hi I have a convergence issue. Is there a place in NYC where I can purchase these replacement items: (1) FL231 micro fuse (1) DL231 Diode (1) CL230 radial Capacitor I repaired the initial...
This DLP model RCA tv have convergence menu disappearing is very easy to fix just replaced the convergence fuse FL 231 near the FBT also must be resoldering FBT too.U can buy this FL231 covergence fuse at,but u must have to have a soldering iron,a desoring pump or desoldering braids and know how to basic soldering?To replaced this FL231 convergence fuse near the FBT and also must resodering the FBT too for protecting the new FL231 convergence fuse.
Mar 02, 2011 | RCA R52WM24 52" HDTV Projection Television
KP-51WS510 convergence problem. Replaced IC's and pico fuse
Nothing else to look for but to Replace the Convergence Ic's
Nov 06, 2009 | Sony KP-51WS510 51" Rear Projection...
FL231 Fuse not blown
check the convergence power supply board for blown reistors. Thats the upper left board when looking in the rear.
Jun 09, 2009 | Televison & Video
Screen has double image in red
This is a convergence problem that is either poor solder connections at the convergence ICs or defective ICs. If you can solder, you can fix this yourself. Update this if you wish to attempt the repair and I'll provide additional details and instructions.
Mar 24, 2009 | Mitsubishi VS-50501 50" Rear Projection...
in the tips and tricks section under ther fl231 article. This article explians why this fuse fails and how to fix it. it is my belief that is is bad solder connections.
Nov 17, 2008 | RCA HD52W59 HDTV Projection Television
RCA R52WH74 Convergence Problem
Yes i replace that fluse fl231 all the time at the shop. at least two aweek. and the first few i replaced did the same thing. I would send it back to customer and i would get a call that the set had malfuctioned again and convergence gone. It was determined the reason this fuse blows is bad conections on the flyback transformer. The flyback is the big black component with the red wire coming out of the top. if you examine the connections on this component there will more than likely be a ring in the solder. this is caused by the manufacturing process known as LEAD-free solder. THis cause oscillations in that cuicit. like turning it of and on really fast. this is a very small fuse and cant stand up to this. so when you replace this fuse just simply RESolder these connections apply a little amount of solder to these connection. i am confident this will fix your problem.
Sep 10, 2008 | RCA R52WH73 Projection Television
Same as everyone green light comes on for a couple of seconds than back off!!!
ok, the problem with short detect....
unsolder all convergance ic's and try to turn it on.
does it come on?
if no, check all diods in the power suppy area.
check h-output
does it come on?
also might have a vertical ic.
mmm, check all fuses including the solder in pico fuses.
beleave they are sold green color.
when i get one that comes in they have 1 or 2 blowed pico fuses and that means convergance ics need replaced along with fuses.
good luck!!
Apr 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
49 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
