Question about Philips Magnavox TS3260C 32" TV
Ticking TV When I plug my tv in, I hear a strange ticking noise coming from the top-ish. Also, the tv will not turn on.
  • Matt D Nov 23, 2008
    I wish these solutions could be easy but hey...life breaks. Thank you for the solution.
  • Bokes Dec 04, 2008
    I have a similar problem. My TV turns on, but then turns off within 5 seconds. I do hear a clicking sound when it turns immediately on then again when it turns off. On the screen it does show gray with white lines across the screen. I am debating on weather to buy a new TV or bring it in to get fixed. Obviously with how the economy is I can not afford to buy a new one OR pay a high price to get it fixed. Prior to this for about a couple months captions were showing on the screen but we just random letters. Help?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 56 Answers
This noise come from a component that needs soldering, probably comes from one of the terminal were by any reason is not doing good contact. Or is the flyback, a component that uses high voltages to accelerate the rays inside the tube.Unfortunately, is not a big deal for a regular technician, but is a big trouble if you try tio open the TV. Is very risky because the mentioned component, along with others usually they work at ranges ol voltages of 50,000 or more volts. Although the current is not much, the shock is very unconfortable. Don't try, take it to a tech.
Posted on Nov 23, 2008
  • Luis Rondon
    Luis Rondon Nov 23, 2008
    Thanks for you comment, and thanks for not take these risks.
My 37 in rca, model # L37WD12, Will not fully turn on. it tries to come on, but the green light just flashes. and the tv makes a small ticking noise that goes with the flashing. how do i fix this or what...
The inverter is probably bad - the ticking noise you hear is high voltage that is trying to turn on the backlight from the inverter's transformer but cannot. The only way to fix this is to open the TV and locate the problem around the inverter circuitry. Another possibility is there is an open circuit run around the inverter and may just need some solder to bridge the open.
Jan 16, 2011 | RCA L37WD12 37 in. LCD HDTV
I have a ticking noise when i try to turn on the tv..
Try putting on the back piece. Some of these TVs have a circuit protection system that will not deactivate with the back open. (It is like an old circuit breaker with the fuse out.)
I hope this helps.
Jun 03, 2010 | Philips 50PL9126D/37B 50" DLP TV
WHEN I PLUG IN TV THE TIMER LIGHT IN THE FRONT COMES ON BUT THE SCREEN WONT COME ON AND I CAN HEAR A TICKING NOISE
the ticking comes from overcurrent circuit protection there are several areas inside the tv that could be causing this. The most common are the horizontal drive and output circuit and the power supply. If you call your area service tech he can give you a good idea on what the repair costs will run.
Sep 25, 2009 | Akai PT5492S 54" Rear Projection...
Picture and a ticking noise from behind the television
ticking sound is hv shut down. electronic sweep circuit or power supply problem. need tech.
Dec 04, 2008 | Philips Magnavox TS3260C 32" TV
Green flashing power light and ticking noise but wont turn on
Did you touch the Lamp? If you did it may have blown. the color wheel may be the problem or yes the balist
Jul 25, 2008 | Panasonic PT-45LC12 45" Rear Projection...
Ticking noise from TV - Sony 50' rear projection 1080p LCD
The problem is ht leakage . remove the ultar cap of the tube and clean both the tube and cap with wd 40. then reinstall cap using some silicon glue.
this will correct your fault.
Jul 11, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Won't turn on, ticking noise that continues when unplugged
Bad flyback transformer.....Emerson parts source ..Fox international or the partstore.com ...............T.
Jan 15, 2008 | Emerson EWF2703 27" TV
High Pitched Ticking Noise
Horizontal output transistor is shorted,caused by bad flyback
transformer.If you want to pursue the repair,please give the
service number off back......I will get part # s........T.
Oct 25, 2007 | RCA F36705 36" TV
Ticking noise
lost contact use soldiring iron
Sep 19, 2007 | Sanyo AVM-3659S 36" TV
Tv won't turn on
Most likly it is a problem in the power supply regulator circuit. pretty common for Toshiba TV sets. If you know about TV serviceing, first thing to replace would be the regulator IC as that is the problem 80% of the time. if that does not help then you will need a schematic to trace out the regulator circuit. Good Luck PS please dont forget to rate this thread.
Oct 19, 2006 | Toshiba 34HF84 34" TV
Philips Magnavox TS3260C 32" TV Logo
7,482 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
