Question about Northwestern Bell 99141 2-Way Radio
Has static and cannot hear transmission
When we try to talk from one to the other lots of noise, changed to channel 1 but did not help. any advice appreciated! thanks
  • 47 Answers
Sounds like it is off frequency and needs retuning
Posted on Nov 27, 2008
The Clip Light and Static ?
I don't know what make & model of microphone or clip light you're using, but try unplugging the microphone cable from the preamp. That will tell you if the problem is in the microphone or the preamp/amplifier.
If you still get noise with microphone unplugged, try checking the power supply. You'll probably hear any hum from power supply. Make sure you're using one that's recommended or sold by the manufacturer.
Finally, try replacing the output cable. Any open circuits in the output cable could cause hum & noise.
That's all I can think of right now. Good luck.
May 01, 2014 | Rolls MP13 Mini Microphone 1-Channel...
I just bought it and tested on a channel and eliminator code and it worked fine. But after a while I cannot hear static when holding "mon" and cannot hear the other radio if I talk into one. This happens...
If the radios are working fine otherwise, don't worry about the monitor feature not creating white noise (static). If you are still having a problem with the radios, try setting the interference eliminator code to off (zero). And turn off any other special features to see if you can regain communications. Then slowly add the features back in as you need them. All radios must be identical in freq., code, and features.
Best regards.
Aug 19, 2013 | Motorola Talkabout T5720 (7 Channels)...
Can not get static out of radio i have a cobra 29 with weather channel the squ knob seem 2 b not working sometimes can u help me
Turn the squelch down, and the RF gain all the way up.
You need to realize that some times, there is not a lot of noise out there. Right now lately there has been due to skip. But it does die down. When you hear a lot of noise for a while, then it goes away, it messes with your head. You don't hear anything, but that's because its quite out. I would test it by talking to some one on the radio. If you can hear them just fine even though you don't hear a lot of static, then its just quiet out.
Jul 23, 2011 | Cobra 29 WX NW ST 40-Channels Base CB...
Have (2) Cobra 22 channel Micro talk radios that both just quit together. Only get static when tring to talk on them. Have (4) AAA rechargable in each one that show they are charged up. Both quit at the...
  • It is odd to see them both quit just like that. Were you messing with the buttons on one of them when it just quit? Did you happen to change one of the privacy channels on a main channel? The privacy channels isolate a main channel so you can talk on a channel without everyone with a radio hearing you. Make sure the channels on both radios are on only the channels and that no CTCSS or DCS code accidentally got added onto a channel. You should be able to tell by just looking at the screen and you will see the channel you are on and will also indicate a CTCSS or DCS code. Should you see either of them then remove them and retry the radio on a plain channel only.
  • Should this fail the you have got some major internal malfunction that happened to happen at the same time and it is time to invest in a new set of radios.
Regards, Tony
Apr 30, 2011 | Cobra 18-Mile, 22-Channel FRS/GMRS 2-Way...
When i transmit if the other vehicle is anything over a mile away they get a lot of static. I can receive them clearly at up to 5 miles. What do I do to get better transmission? I have a K40 antenna...
Well if they are not hearing you over a mile but you hear them over 5 miles that is a good indicator that your antenna is working properly but your radio is not getting out there. First go ahead and check the TX knob. Turn it all the way to the right so you modulate as much as the radio will allow. Next turn the squelch knob all the way to the left until you hear static and then turn it to the right slowly until the static noise goes away. Some don't mind the continual static but I like to squelch it out. The TX being turned to the right will allow your radio to work at full capacity. If you still don't get reports much over a mile then you can try a power mike to help you out a bit. Your microphone could have seen it's better days and can for sure mess up your transmit. Make sure your SWR is low 1:1.5 is the goal not to exceed 2. If all that checks out then have it peeked /tuned and aligned by a tech. Good luck to you.
Feb 06, 2011 | Cobra 29 WX NW ST 40-Channels Base CB...
Uniden 3315 Frequency Problem
Your phone has Digital Enhanced Cordless Telecommunications (DECT), known as Digital European Cordless Telephone[1] until 1995, The digital filters will prevent interference from the bandwidths used by phones and wi-fi.
Your phone also incorporates dynamic channel allocation which switches frequencies when noise(static) is encountered.
Eventually your conversations take a wire route down the road. You are getting some "cross talk", an actual scientific term used to describe signal transmission from one line parallel to another by magnetic eddy currents. I would call the phone company and have them trace the problem.
May 13, 2009 | Uniden Lands Phones
git a good grond on it or it will go sky hi
Dec 05, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
The cordless phones have a button to change the channels that are within the radio freq. range. I would change the channels until you get a clear/static free call.
May 20, 2007 | Northwestern Bell 35807 Cordless Phone
Northwestern Bell 99141 2-Way Radio Logo
141 people viewed this question
Top Northwestern Bell Radio Communications Experts
Mike Charette
Are you a Northwestern Bell Radio Communication Expert? Answer questions, earn points and help others
