Question about HP Pavillion ZV6000 Notebook
Print spooler error during printer installation windows vista
During the installation of a printer, the printer software presented a problem with print spooler. I am not able to start print spooler in my PC.
  • 1,124 Answers
Go to Start, Control Panels, Administrative Tools, Services.
Windows 2000: Go to Start, Settings, Control Panel, Administrative Tools, Services.
Right click on the print spooler and select Properties.
Click on Dependencies to view a list of all the system components that the print spooler depends on.
Under Services, go to each of these dependencies and check the properties. In each case, ensure that the Startup type is set to Automatic, and that the Service status is set to Started.
Posted on Nov 23, 2008
I also have a problem with the print spooler. When installing my printer it states that service has stopped and needs to be running to continue. They is a fix now button however this does not work. Can you help, Jim
Posted on Dec 10, 2008
Print spooler subsystem stopped
Start and stop the print spooler Windows XP
To start and stop the print spooleropen Computer Management, click Start,click Control Panel, double-click Administrative Tools,and then double-click Computer Management.In the console tree, click Component Services.
Under Console Root click Services (Local)
In the details pane, double-click Print Spooler.Do one of the following depending on the task you want todo:
Click Stop to stop the service.
Click Start to start the service.When you try to install a printer and get an error message "PrintSpooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the Generaltab then select these items - Startup type select AutomaticService status click StartThen click OK
May 12, 2012 | Office Equipment & Supplies
My hppsc 1315 printer has a problem with the Print Spooler Service , the only way to get it going again is to delete the printer all together and reinstall it ,then the Print spooler is ok . During the...
Hi Noel, Let me start by informing you it is not a problem with your printer but it is a problem with your print drivers on your pc or windows itself.
What I normally find is that that is corrupt driver installed on the system, your best bet is to uninstall via control panel/programs and features (or add remove programs depending on windows version) all old printer driver software and also remove completely this HP's software, you will probally find old programs that were installed on/with previous printers, get rid of them all as I have seen conflicts occur when two different driver software programs are installed (especially epson). Once you have removed old printer programs, go to printers and faxs and delete all unused icons for old printers and also this Hp's one. Then reboot.
Dont use the CD to install new drivers go to HP's web and download the latest HP driver for use with your printer and operating system, ensure it is exactly correct but even the HP universal driver should work as long as it is for the right windows system ie Vista, or Win7 64bit etc.
What is your windows system? (im guessing Vista as it has known to have issues) Also ensure you have the latest service packs installed from windows update, expessally if using VIsta
Let me know how you go but from many years experance let me assure you it is not a issue with the printer itself but a problem with the way in which windows is trying to communicate with it via installed software and windows print spooling software.
Cheers Steve
Please make sure you get you driver software from HP directly first google search is not HP, here is the correct link
Oct 14, 2011 | HP PSC 1315 All-In-One InkJet Printer
I am running vista ultimate 32-bit but i often received this error message:".....the local print spooler is not running...." when attempting to install a remote oki B4400 printer. Why is that?
Print spooler is printer service if this service is not running, it might not allow you to add or see any printer drivers
Try enabling print spooler service. Follow the instructions
Click on Start->Search->type "services.msc" hit enter. Service windows will open up, on the right side pane search for "Print Spooler"
-> double click to open service and select start type as "Automatic"
click on apply and click on "Start" botton to start the service.
Now try to install the drivers
Snapshot for more information.
Hope this helps
May 21, 2010 | Computers & Internet
IS034 Error when intalling driver software for MFC-490CW on vista
This issue is cause when the print spooler service isn't running, MFL pro installs the printer driver 1st (after paperport install) which will not wun if the service is disabled
Sep 11, 2009 | Brother MFC 490cw Color Inkjet...
HP print spooler problem and error 1068. Want my printer back!!!
Just go to your Server or Desktop PC and enable the RPC service (Remote Procedure Call)
Right click in "My computer" icon, from the manu select "Manage" then go to "Services and Applications" and expand that, after that select "Services" you will find that services in the right pane, just click in "Start"
I hope this work for you, good luck!!!!
Jul 28, 2008 | HP LaserJet 1022 Printer
Spooler not running after Lexmark x83 installation on windows XP laptop
From what you're saying the windows print spooler service is not starting following the installation of your printer (and thereby you cannot print i'm assuming)
try the following to start the print spooler service if it is not already running.
Click Start
Right Click My Computer
Click Manage
Click "Services and Applications"
Click Services
Scroll down to "Print Spooler" and double click on it to open up the properties page
where it says "startup type" select automatic from the combo box list
If the service is NOT running, start it by clicking "start"
click OK
The print spooler service is started now, and **should** work properly. If the spooler is still not starting properly, then you may have a driver issue and i reccommend uninstalling and reinstalling the drivers for your printer.
Jul 01, 2008 | Lexmark X4270 All-In-One InkJet Printer
hi! Print Spooler is actually a service for your Operating system-
Try this
Click on start and click on run
in the open box type in services.msc and your services local window should open, scroll down and look for print spooler, highlight it and do a right click and on the dropdown menu left click on stop and it will go to a process of stopping the service and then right click back and click on start. if you get an error message about print spooling or spooler, then that means you have a problem with the operating system. call or go to microsoft help and support online in that case. and RPC server unavailable error has something to do with a network printer. but i believe you setup the printer locally.
You can email me at
Apr 04, 2008 | Epson CX8400 All-In-One InkJet Printer
There are several ways to resolve printer spooler error, probably because there are many variations of this error. The error caused by faulty software can be resolved by deleting all the information found in the directory. Thereafter, navigate to the Control Panel, click on Administrative Tools and then services icon. Find the service labeled Print Spooler, highlight it and restart the process. If that doesn’t work, the program might be corrupted. Click on start, then Run. Search for the document labeled services.msc, and this will trigger the opening of another window. On this window, scroll down and click “Print Spooler”. Check its setting and turn on automatic mode. Click Okay, and restart the machine. If you’re lucky, this might be all you have to do. Still doesn’t work? Navigate to the Add/Remove Programs screen of the Control Panel. Find the all the software responsible for making the printer run including the drivers, and uninstall them. Be sure to be thorough about it, or the problem may not be solved. Download the latest copy of your printer’s software from the manufacturer and reinstall it. get more information for printer spooler error .Hope this helps you.
Mar 03, 2008 | HP OfficeJet 4255 All-In-One InkJet...
HP Pavillion ZV6000 Notebook Logo
162 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
