Question about Goodman GMS90703BXA Heater
My blower fan came off the motor shaft.
I took out the blower and replaced the motor. but can not find my wiring diagram for a gms9/gcs9.
  • Joseph Lillie
    Joseph Lillie May 11, 2010
    I have the manual, but cannot figure out how to send it. It is a pdf file
    with all the information you need.
    An expert who has answered 500 questions.
  • 540 Answers
Posted on Dec 05, 2009
My Goodman GMS9/GCS9 Gas-Fired Furnace is not working.?
Check all safety switches on door. Make sure the main breaker in fuse box is on and well as main switch on furnace. Please ad more details. New install, just quit working? How old....
Oct 27, 2013 | Goodman GMS90703BXA Heater
Goodman Furnace GMS9/GCS9 Blower seems to not be made very well. The repairman put two different ones on before finding one that's somewhat balanced. I still feel it rumbling a little. Are there
It is possible it is a problem with the motor mounting bracket or the fan housing itself. Tough to believe you have gotten three bad blower wheels. Also could be the motor .
Dec 17, 2017 | Goodman Heating & Cooling
Fuse blow each time I turn on air check for
disconnect the thernostat wires from the control board. Put a jumper wire between R & G put door back on and turn on power. Blower motor
should run, if it blows the fuse then you have a direct short between R &
G at the board. Do this with R and W(heat) and R & Y(cool).
By disconnecting the thermostat wires and reinserting them make sure that they do not touch when inserted into each terminal. If it still blows
that little 3amp fuse when jumpering between each sequence as mentioned above, then I think your board is bad. When Jumpering out the Y terminal you will have to have the AC wires still hooked up. If it
blows the fuse in that sequence. Disconnect the wires out at the condensor.
You mat have a bad contactor at the outdoor unit.
Jul 16, 2010 | Goodman GMS90703BXA Heater
Replacing AC blower motor
ITS CALLED SURGERY take picture as ya go and have a big bucket for screws. make sure you have your motor and capacitor tested first before you replace it unless you know its bad (hp,sf &rpm must match !!!! on new motor ) little guys are real expensive and are a three speed motor and must be hooked up right or you will burn it UP ! do this in the shade cuz it aint no fun in the hot sun(me Florida) the first thing i would do is oil the motor then have the capacitor checked , the motor may not need to be replaced just serviced ?.. hay now if'n i was any help write a review of thanks or just VOTE,, MOTORWIZJ ..FL
May 28, 2010 | Dometic Rooftop RV Air Conditioner
Fuse on control module blows when calling for cooling
Disconnect the the red and the yellow wires at the outdoor unit. Then replace the fuse and turn on the power.......see if the fuse blew. If the fuse blew, your problem is most likely a short in the low voltage wiring. Check for crimped or damage wire or wire insulation and repair as necessary. If the fuse is okay, then the problem is within your outdoor unit.......again inspect all wiring for any damaged insulation or crimped wiring.
Check these items and let us know.....we can guide you further after you perform these checks. :-)
May 26, 2010 | Goodman CLQ36AR49 Air Conditioner
My furnace heats the house well, but during the cool down it actually blows cold air dropping the temperature causing the furnace to re-ignite. How do I adjust? Goodman - GMS9/GCS9
Depending on the age of the furnace you may be able to adjust the cool down. On some furnaces there is a silver box usually made by honeywell. This is your fan limit control. If you take the cover off you will see a dial with different temperature settings with 3 pins in a grove. The first one is fan on with temperature rise this turns the blower on when the furnace starts and warms up. The second is the fan off after furnace shuts down, this would be the one you want to adjust to a higher temperature to keep the blower from blowing cold air. The last pin is the high limit if the furnace gets to this temperature it will shut the furnace off but keep the blower running. Make sure that the thermostat fan option is set to auto and not on.
Jan 02, 2010 | Goodman GMS90703BXA Heater
Constant high pitched noise emitting from furnace
This is probably a dry bearing in the vent motor. Those motors run at high RPM's and can make a deafening high pitched squeal if they become dry and need oiling.
Some of the motors have oil cups on them for dripping oil into and others;s are much more difficult as you need to guess where the bearing is and try to drip oil down into them or run the oil to them.
Any light weight small motor oil ike a sewr machine oil will work.
Many hardwares have small oil bottles with extending spouts made just for oiling motors for just a couple of bucks...
The other thing that can cause this is if the blower wheel is coming loose and has moved to the side and is hitting the side of the blower housing. Take the bottom cover off and check for play or movement side to side in the blower wheel. Spinning it with the power off by hand may give you a clue as you will hear it scraping the side of the housing.
Dec 29, 2009 | Goodman GMS90703BXA Heater
GMS9/GCS9 no heat
Pull it apart andf make sure there is not a bird in it - if not then yes replace it.
Mar 30, 2009 | Goodman GMS90703BXA Heater
Goodman GMS90703BXA Heater Logo
294 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
