Question about Dyna-Glo D-E37 Wall Mounted Panel Heater
Flame shooting to high
The flame when you turn the heater to the first position shoots past the brick. we vacumed the bricks out but it is still doing it. do we need to change the brick ? and if so how do we change it? the flame is blue and otherwise works good.
  • Dyna-Glo Master
  • 3,328 Answers
Call the gas company to have it serviced sounds like it needs it
Posted on Dec 16, 2008
Heater pilot light flame is high and middle brick is blue not orange?
both need a clean pilot is blocked hence high flame , both need a clean could try blowing then out with a air line , or can of air or just clean injectors on both.
Jul 26, 2011 | Heating & Cooling
I HAVE A VENLESS HEATER GLO-WARM HEATER THAT THE FLAME IS SHOOTING ABOVE THE BRICKS AND HAS EXCESSIVE GAS FUMES APPEARS TO HAVE A LARGE FLAME WHAT CAN IT BE
can you turn flames down with the control knob ,if not you need control gas valve,that if burning right gas for heater you got. Check the data plate.If not right gas your heater your living very dangerous.
Jan 22, 2011 | Vanguard International Blue Flame - Large...
My flame is above the guard on the heater in the middle flame. How do I adjust the flame to be lower?
this is happening because the bricks need cleaning. I imagine the flame is burning blue instead of glowing red in the middle brick. Contact your local propane or natural gas dealer about getting the heater cleaned. This type of problem causes a huge loss of efficiency and could be dangerous.
Oct 29, 2010 | Vanguard International Infra Red - Medium...
I have a Empire Corcho radiant nature gas space heater that the middle brick panel flairs when on. When the other two bricks light they burn normal (ie no flair or flames except slight flame as bricks heat...
Problem sounds like the incoming gas pressure is too high or the burner below the middle brick has debris or trash clogging some of the openings. Recommended next step is to remove all power / natural gas to the space heater and check all burners for debris or blockage. If burners are clear have your natural gas provider test the incoming gas pressure to ensure it is correct for that appliance.
Dec 13, 2017 | Heating & Cooling
Flame burns to high
I had this problem. From using the center brick most of the time, lots of dust bunnies build up in the gas chimney behind the brick.
Tie 2 pipe cleaners together with a small perpendicular circle at the top and carefully remove the dust bit by bit by twirling the cleaner.
The brick should fire like new if it is carefully cleaned out.
Jan 25, 2009 | Vanguard International Infra Red - Large...
Flame
the first thing I would do is pull it apart and give the bricks a good cleaning with a wire brush to get any soot off. If they are broken beyond the point of replaceing them in the unit you will need new bricks.
Jan 18, 2009 | Desa International GWP20T GLOWARM Wall...
Glo Warm propane heater started to go out. I blew out the pilot with air compressor. It is staying on, but the middle burner in back of the pilot light is flaming a little above the brick. The other...
sounds like when you blew heater out with air compressor you moved brick so flame isn't hitting bottom of brick like they should. You should try and put brick back on top of flame so that you don't get to much heat on the refractory of the heater.The refractory will take the heat for awhile then refractory will start to break down. Then you will either have to install new refractory or replace heater
Jan 17, 2009 | Desa International GWP20T GLOWARM Wall...
Infrared Heater - flaming thru plaque
Jan 15, 2009 | Procom ML060HPA Heater
Can not get the bricks to light on my empire corcho
I have the same htr in Mich. & have worked on gas htrs.for many years.
Does the flame go out when you let go of the button to lite it?
If it does, then the thermocouple is bad.
If the flame stays on, but goes out when you turn the dial,
the gas regulator is bad.
Probably a little more expensive to buy new then to fix it.
Michael.
Nov 20, 2008 | Reddy Heater RLP100 Portable Forced Air...
Dyna-Glo D-E37 Wall Mounted Panel Heater Logo
533 people viewed this question
Top Dyna-Glo Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
fordexpert
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
