Question about Brother Office Equipment & Supplies
Brother mfc235c has ink but will not print black
I've just fixed mine. The print head needed cleaning. Press the 'Ink Management' button, scroll down to 'cleaning' then select 'black'. I needed to do mine 3 times before it became perfect but it worked for me.
Posted on Aug 11, 2009
  • 18 Answers
Click on the START button on the task bar, go to Control Panel, look for the printers icon and click that. A window will pop-up with a list of installed printers. Find the icon for your brother mfc235c, click on that, and in there you can change all of your print settings. Example: Print in Color or Grayscale.
Posted on Nov 23, 2008
What can i do my brother dcp j125 printer not function black ink
Check whether the ink tubes from the ink to printhead is filled with black ink. Bubbles also will cause it not to print. Always use original inks for trouble free usage.
Oct 20, 2014 | Brother Office Equipment & Supplies
Brother MFC-290C not printing black
The nozzle may be blocked. So take out the colour cartridge and place its nozzle in a bit of water for about 10 mins. Bring it out and dab the nozzle with folded paper. If the tissue is blotted with the three colour it means you have unblocked the nozzle. Try now to print after returning the colour cartridge. You may need to repeat to get good results.
Thank you!!
Jun 25, 2010 | Brother MFC 420CN All-In-One InkJet...
IT IS A BROTHER MFC235C AND THE DISPLAY KEEPS SAYING NO CARTRIDGE, INSTALL BLACK AND OTHER COLOURS LOW. THEY ARE ALL NEW BROTHER CARTRIDGES. PLEASE HELP IM READY TO THROW IT OUT THE WINDOW
you need to go into the menu and reset the error count this tells the printer the print cartridge has been changed otherwise it does not know
hope this helps
Robb
please leave feedback
Apr 26, 2010 | Brother MFC-230c Printer
I have a brother MFC-490CW and replaced the black ink, and my color ink has run out. It will not let me print as it says ink is low, so it won't even let me use the black? How do I print with only using...
By design, Brother printers stop all printing when one of the cartridges is empty. This is done to avoid cleaning cycles sucking air into the system, which could possibly damage the printhead.
Even if you print in black only by changing the print settings to "Mono" or "Grayscale" to avoid printing in color, cleaning cycles would still **** air from the empty color cartridge because they are programmed to clean ALL the ink nozzles. The only way to continue printing is to replace the empty ink cartridge(s).
After replacing the empty color cartridge, you could print in "Mono" or "Grayscale" to make better use of just the black ink.
Jan 21, 2010 | Brother MultiFunction Center MFC-440CN...
Black ink does not print on brother 240c
If you haven't changed it recently, it may be out of black ink. The product code for Black is LC51BK.
Brother's supply site
Dec 10, 2009 | Brother Multi-Function Center MFC-240C...
My black ink printing all of a sudden stopped..ink in cart.all other colors work fine
All brother machine have a one year in parts and labor this machine have a print head problem.
Oct 05, 2009 | Brother MFC 210C All-In-One InkJet Printer
Printer wont print black.already replaced with new ink but still wont print black
did you take the tape off the new cartridge and is the print head burned out for the black? if you installed the diagnostic's on it then run it and see what it says, otherwise expect the print head to be cooked, however it is possible to get a bad ink cartridge try tapping it on your finger and see if ink comes out if it does not then the ink cartridge is dried out or no good, about %15 of print cartridges are bad on just about any brand printer some more than others.
May 31, 2009 | Brother DCP 165C Compact Color Inkjet...
I Need to Print
Sadly in a word, 'No'.
Here is the exact answer from Brother:
Your Brother machine is designed to stop ALL printing operations
(printing from the pc, printing received faxes and printing copies or reports) when any of the ink cartridges are empty. This is to ensure the life of the print head and maintain premium print quality. If the unit were to continue printing, print jobs and cleaning cycles would suction air from the dry cartridge and damage the printhead. Even if you print in black only or change the print settings to MONO or GRAYSCALE to avoid printing in color, the programmed cleaning cycles would still suction the dry cartridge, because they are programmed to clean ALL the ink nozzles.
The only way to continue printing is to replace the empty ink cartridge or cartridges.
While memory is available, black and white faxes will continue to be received into memory. If a color fax is being received, the Brother machines HANDSHAKE will request the fax be sent as black and white fax.
All faxes received into memory will automatically print once the ink cartridge is replaced.
NOTE: Brother strongly recommends that customers do not use generic ink or refill their Brother ink cartridges. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability since the ink formulation in genuine Brother ink cartridges prevent smearing and clogging of the print head. The Brother limited warranty does not apply to any problem that was caused by the use of unauthorized third party ink and/or cartridges.
Nov 26, 2008 | Brother Multi-Function Center MFC-240C...
INK
Brother multifunction printers require that all ink be filled before you can print to it. If any ink is empty, you cannot print, even if you are printing only black.
Jun 20, 2008 | Brother MFC-5440CN All-In-One InkJet...
Brother problem
Did you use third party ink? If the ink is pigmented the filter in front of the printnozzels is clogged and cant be cleaned any more. What you can try is to buy a brand new original brother ink cart and do the cleaning 3 times. After that do a testsheet printing. In case its OK, your lucky and it was a problem of the cart. If you cant see any blocks (with the original ink used!!!) the printhead is crashed and has to be replaced (BTW: Its cheaper to buy a new mfc)! Do use only dye ink for brother printers!!!
Sep 10, 2007 | Brother MFC 210C All-In-One InkJet Printer
587 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
