Question about Coustic Car Audio 401SE Car Audio Amplifier
Amp plays but pulses when bridged
I have a coustic 400 watt amp and i accendently grounded the output to the car while the amp was playing. . the amp was bridged during this incident. . now as soon as i turn it on and it gets feed from the rca jacks it starts pulsing. . but it plays fine when its unbridged. . i know i blew somethng but im not sure what. im fairly good with electronic repairs but not when it comes to amps . any help would be greatly appreciated
5 Suggested Answers
  • 631 Answers
SOURCE: coustic 601se power on but bad sound
This is generally caused when there are blown output transistors but that generally causes the fuse to blow or causes the amp to go into protect mode.
If you connect a 15 amp fuse in series with the main power wire and it blows when remote voltage is applied, the amp is drawing excessive current. The problem could be either in the power supply or audio circuits.
Do NOT apply power without having the transistors clamped TIGHTLY to the heatsink. They can fail in seconds when there is a problem. The heatsink helps protect them.
The following page may be helpful when troubleshooting.
Amplifier Repair Primer
Let me know if you have any other questions.
Posted on Aug 23, 2008
informatica
  • 1114 Answers
SOURCE: Car Amplifier
Hi - You can download the manual by clicking the link underlined in blue below:
Coustic 480
So the startup red led shows an over current condition, if your sure the speakers are OK then you will need to go "under the hood". The best start for this is the following web site:
Basic Car Audio Electronics
This will give you a basic guide to troubleshoot the amp.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Informatica
Posted on Sep 08, 2008
Professor_V
  • 92 Answers
SOURCE: every time i hook up my coustic car amp the radio
THE GOAL HEAR IS TO DETERMINE IF THE INSTALLATION IS CAUSING YOUR PROTECTION FAULT OR IS IT THE RADIO OR AMPLIFIER ITSELF HAVING INTERNAL DAMAGE. REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL POWERS UP ON ITS OWN, THEN REMOVE THE REMOTE TERMINAL COMING FROM THE RADIO. IF THE AMPLIFIER SHUTS OFF, THEN YOU MAY HAVE A SHORTED TURN-ON TRANSISTOR WITHIN THE RADIO AND IT IS OUTPUTTING THE DC NEEDED TO TURN THE AMPLIFIER ON. IF YOU REMOVE THE REMOTE TURN-ON FROM THE RADIO TO THE AMPLIFIER AND THE AMPLIFIER STAYS ON, THEN THIS POINTS TO A FAULT WITHIN THE AMPLIFIER AND IT WILL NEED TO BE SERVICED. MAKES SURE THAT THE AMPLIFIER AND RADIO GROUNDS ARE 100%. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Posted on Jan 16, 2010
  • 147 Answers
SOURCE: Sound turns on and off.
Amp is probably going into protection mode, or does not have enough current from the power wire to continue operating. Check that the speaker wires are not shorting out against each other. Also check your power wire and ground wire. Ensure that the amp is solidly grounded. Are you using the proper gauge of power and ground wire? (4awg recommended.)
Posted on Mar 12, 2011
I have Sony xm-2165gtx amp 165 watt rms x 2 at 4 ohm 200 watt x 2 at 2 ohm 400 watt x 1 bridge output at 4 ohm stereo or bridge mono output 4 ohm stable in bridge mode this mean can't go lower then 4 ohm...
You can't bridge that amp onto a load lower than 4 ohms. So you can't bridge that amp onto two 4 ohm subs. To get the most power out of your subs is easy. Run one channel to one sub and the other channel to the other sub. 165 watts RMS is plenty for most subs.
Dec 05, 2013 | Car Audio & Video
How do you switch the behringer 3000 to bridged mode,what settings do you use to get 1200 watts out of it.
Well... you probably won't like this, but here is some info: In bridged mode, a different Speakon to speaker cable is required from only the B... it is wired differently and you can only use one of the plugs. The speaker or speaker system CANNOT be less than 8 ohms in bridged mode... this precludes using speakers in parallel or multiple speakers that are less than 16 ohm impedance... such speakers are NOT commonly available as most are either 4 or 8 ohm. There is a slide switch for bridged mode on the face of the mixer. Next thing you won't like... The 1200 Watts specification is PEAK power, NOT RMS... You can get 400 watts RMS per side USING 4 ohm speakers. If you use 8 ohm speakers, each of those will get 200 watts. I use this mixer myself and ALSO repair them. The voltage swing at the outputs is about +/-60 volts MAX (peak). This is about 40 volts RMS by the time the circuit LOSSES are taken into account. Across a 4 ohm speaker you get 10 amps times the 40 volts or 400 watts. Across an 8 ohm you get 5 amps or 200 watts. The voltage rails in the switching amp are +/-70 volts DC so these are reasonable values. Bridged mode just uses both sides of the amp driven in opposite directions for higher voltage out BUT you have to use no less than a single 8 ohm speaker so there is NO advantage to bridged mode power wise. IF YOU NEED more power, use extra speakers from an additonal amp driven by the 1/4 TRS mains output jacks OR use additonal POWERED speakers driven from the same jacks. Please read my tip about the hazard regarding the SLEEVE of the cahnnel A cable when using Speakon to 1/4 plug cables being the HOT and the tip being the cold for channel A. Ground the sleeve accidentally and goodbye channel A amp...
May 10, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Sound turns on and off. Green light sound, red light no sound. It is like playing name that tune. A few seconds of music then off then on and repeat. It is not the deck as it has meters showing output. The...
Mar 10, 2011 | Coustic Car Audio 481QE Car Audio...
How many watts is this amp
Specifications Power Output: 100 Watts RMS x 2 channels at 4 Ohms ≤ 1% THD+N Signal-to-Noise Ratio: 80 dBA (reference: 1 W output) Additional Power Output: 200 Watts RMS x 2 channels at 2 Ohms ≤ 1% THD+N
400 Watts RMS x 1 channel bridged at 4 Ohms ≤ 1% THD+N THD+N (Distortion): <0.25% (reference: 1 W output) Frequency Response: 20 Hz to 20 kHz (-3dB) Maximum Input Signal: 5V Maximum Sensitivity: 100mV Dimensions: 14.37 x 9.72 x 2.5 (365mm x 247mm x 63.5mm)
Jan 03, 2010 | MTX 4002 Car Audio Amplifier
I have a kenwood kac-728s and two coustic 10in. subwoofers hooked to it and every time i start my car and the radio powers on the two 20 watt fuses on the amp blows.any ideas?
That is pretty much saying that the amp's power supply is shorted or at least has a low resistance path to ground which is causing the fuses on the amp to blow. The amp has protection circuitry to prevent damage to the output stage so that is not what is causing this. Is the amp new?
Dec 30, 2009 | Kenwood KAC-728S Car Audio Amplifier
Not a problem just a question
  • 100 watts RMS x 2 at 4 ohms
  • 200 watts RMS x 2 at 2 ohms
  • 400 watts RMS x 1 at 4 ohms in bridged mode
  • stereo or bridged mono output
  • 4-ohm stable in bridged mode
  • Tri-Way capable
  • requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
  • 50-250 Hz high-pass/low-pass (12 dB/octave) crossovers
  • wired remote included for fingertip control of Punch Bass (0-18 dB boost at 45 Hz)
  • MOSFET power supply and output devices
  • MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
  • TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
  • Trans•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
  • NOMAD — advanced protection circuitry for "intelligent" shutdown protection
  • speaker- and preamp-level inputs
  • 11-1/8"W x 2-3/8"H x 9-7/8"D
  • Wire your sub in bridged mode (4 ohm mono)
    + to + on amplifier
    - to - on amplifier
    (using bridging terminals)
    Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
    Apr 25, 2009 | Rockford Fosgate Punch 401S Car Audio...
    Speakers
    400 watts delivered to 300 watt speakers the only way to do this would be to wire two subwoofers in series so that the power needed to drive them will be 600 watts to max, however this will increase your impedance on the speaker (8 ohms) load so what you can do to compensate is get an 8 ohm 600 watt resistor and put it in parallel with the speakers you will then have 4 ohms of impedance at a total capacity of 600 watts of power In other words the amplifier won't blow these out now.
    Oct 08, 2007 | Pioneer GM-X722 Car Audio Amplifier
    Speakers
    Hi Trim God,
    I do not reccommend that you push the Pioneer speakers over 100 watts.  The jenson will already drown the car with bass through your pioneers so much you will want to turn off the bass boost when playing some low bass hip hop songs. It changes from one venue of song to another, so I just keep the jenson bass boost off and use my head unit to adjsut the sound to fit my listening prefences. I am telling you man, you will be blown away .  Hook up the pioneers straight to the Channels,. do not bridge.  I put Subs in my truck though.  I used the Pass output to send the audio to me Jenson 2 Channel 600W amp. I drive one 10 inch enclosed JBL Class A/B Sub. I bridged the output of the 600 W amp to the 10 inch sub  in my Z28.  The pioneers never get drowned out.  I did smoke my 2 channel Amp one time. and also took out a MTD 10inch sub. I am talk shooting flames and smoked the whole car up. I think if you bride the XA4150 to the pioneers, you will have the flaming smoke problem in no time.
    Oct 02, 2007 | Jensen XA4150 Car Audio Amplifier
    Coustic Car Audio 401SE Car Audio Amplifier Logo
    32 people viewed this question
    Top Coustic Car Audio Car Audio & Video Experts
    Greg Cann
    Greg Cann
    Professor_V
    Professor_V
    JonSnell Electronic
    JonSnell Electronic
    Are you a Coustic Car Audio Car Audio and Video Expert? Answer questions, earn points and help others
