Question about Lands Phones
Centrex air conditioner keeps cutting out and turning off
I have a centrex 6 KW spit unit air conditioner which often just cuts out the green power light starts to flash and then the unit turns off it happens more often on the cooling cycle but still does it on the heating. Does anyone have the same problem or knows what is wrong with my unit..
Any help would be great.I'm i better to just buy a new unit.
Thank you.
  • dminhinnett Jan 02, 2009
    same thing just started to happen to me its a real pain
Ihave the same unit, and the same thing has happened to mine, I will be fixing mine by replacing the complete unit with a known brand.
Posted on Feb 13, 2009
Samsung AQV24U series - recent electrical blackout - now keeps beeping every 30 seconds and won't turn on - have switched off mains and separate cut off switch for air cond and still continues
It sounds like you had an electrical surge and it has damaged your unit. I would suggest contacting your home owner insurance and see what they recommend. This may not work depending on your deductibable.
Dec 05, 2014 | Samsung Heating & Cooling
Panasonic power light flashing air not cold blowing
hi there you need to see where you bhave a gas leak thats all the flashing light indicates that your gas pressure is to low to activate your compressor
Dec 09, 2013 | Panasonic Heating & Cooling
My centrex air con shoes e6 and e7 and does not work why
HELLO,
I HAVE A CENTREX AIR CON UNIT AS WELL.. I HAVE NOT TURNED IT ON SINCE LAST SUMMER.. THE REMOTE IS WORKING BUT I'M NOT ABLE TO TURN THE UNIT ON.. I ASSUME IF IT'S ON A SMALL LIGHT SHOULD COME ON.
WHERE IS THE POWER SWITCH AND IS THERE A MANUAL WAY TO TURN IT ON FROM THE UNIT?
THANKS,
B
Nov 30, 2012 | Heating & Cooling
Hi Had power cut this morning and now the heat pump will not go. Green power light just keeps flashing and orange timer light on.
try turning the power off at the mains ( Isolator switch next to the unit or at the meter box.. Leave off for about 30 minutes as most AC units have a backup memory for when power goes off. Try restarting. If it still goes into a fault code mode ( flashing lights etc) there may have been damage done to the main board due to a power surge.
Jul 14, 2011 | Heating & Cooling
When in heat mode heater keeps turning on and off has trouble to keep running cuts in and out for about one minute then only runs for short time and of sometimes trips the switch in meter box ( small...
the cutting in and out is indicating that it has reached its internal thermal limits .. its too hot inside .. that trips a thermal breaker .. the breaker resets when the unit cools ... the problem is almost always caused by not enough air flow ... the intake is blocked or dust has accumulated preventing proper air flow ... or the fan could be not running or running too slow .. make sure it turns freely ... clean out any dust and filters if any ... make sure air intake and exhaust are not blocked ...
Jul 25, 2010 | LG LS-K2430HL Heat Cool Mini Split Air...
Mitsubishi split-type air conditioner model MSH-26SV. When the unit is switched on, the 2 green lights on the front panel light up normally but but the unit doesn't work at all and, after a few minutes,...
Hi I have Mitsubishi split unit which is 5 years old. when turn heat mode for 30 deg C on the remote condesing unit runs for about 6 minuts and stops. what would be the Technical problem ?Thanks an Apprentice.
May 23, 2010 | Mitsubishi MS09TW Air Conditioner
Fujitsu asya09lcc wallmount split lights flashing indoors
According to the service manual page 8, the unit has an 'indoor unit control error'. Below is the link to the manual. Hope this helps. http://www.oceanairdist.co.uk/assets/pdf/service/Fujitsu/ASYA09LC.pdf
Mat
Jul 04, 2009 | Fujitsu 24R1 Air Conditioner
How do you switch the air condition to auto
You can switch it to power saver mode, it would cut the fan when compressor cuts off as well. The other stting just cuts off the compressor. If your unit is too small for a room it will keep running, or it you dont have good insulation in your house.
Jul 02, 2009 | Whirlpool ACQ189XM Air Conditioner
Lands Phones Logo
169 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
