Question about 2wire Wireless-G 802.11g ADSL Gateway
Portforwarding: Incoming connections on port 80 not possible
Hi, would be great if maybe someone had an idea regarding this:
I set up the 2700 HG-E Gateway (Software version 4.25.43) for remote access.
Port forwarding works fine e.g. for VNC (TCP 5900) and apparently for most other ports. However, any attempt to forward incoming requests on port 80 fail. As a workaround I am now forwarding 81 to an internal webserver, but this is certainly not satisfying.
Moreover, it seems impossible to access the built-in webserver (for the config interface) from the internet (except through VNC via an internal machine).
Any suggestions?
    Problem Solver:
  • 15 Answers
Try using DMZ plus mode to open all ports to be accessible for that particular application, or specify the application name with the corresponding port on the 2wire modems firewall settings
Posted on Jan 26, 2009
Lumia 822 straight talk mms not working
Well its not working.straight talk changed their APN settings on their new sims to this
APN: tfdata
Port: 80
MMS Proxy:
MMS Port: 80
and network setup app wont accept the colon as a valid character in the mmsc box..
Any ideas??
Nexus 5 ipad air pas cher
Mar 29, 2013 | Office Equipment & Supplies
Hi Team, I have a Draytek Vigor 2700 Router. I have redirected ports 80 , and 34599 to view my DVR cameras at my office. I have a static IP and i can successfully log into my DVR via HTTP port 80,...
It is an issue the Draytek and your phone.
Draytek displays as a web page. It uses HTML or XHTML
In order to see it on your phone it needs to be coded in XHTML Mobile 1.0
Jul 02, 2011 | Draytek Vigor 2700 Adsl2/2+ Router 2 Vpn /...
Port forwarding not working on router cisco 861w. ROUTER nat DHCP IS WORKING. I have used this command to add portforwarding: ip nat inside source static tcp 80 interface FastEthernet4...
make sure you enable both tcp and udp port fowarding . worst case comes to worse reset it back to factory settings. or upgrade the firmware (i couldnt port foward until i upgraded my firmware on my wrt model)
Mar 17, 2011 | Cisco 861 Router
Attempting to set up Outlook Express Email for a friend who has new AT&T account. She was not provided with an information package. Need install procedure and required data. Paul
Regarding the issue that you guys have, here's some help that I can offer.
  • AT&T ATT incoming mail server:
  • AT&T ATT outgoing mail server: (requires authentication)
  • Incoming Mail Port: 995 (secure connection (SSL) checked)
  • Outgoing Mail Port: 465 (secure connection (SSL) checked)
Thank you for choosing FixYa! sir. I hope it helped you out. Clicking on YES to vote for me will greatly be appreciated. Thank you!
Mar 06, 2011 | Computers & Internet
Can not connect to Internet
You can enable autoproxy detect in control panel,internet options.connections.advanced.
Jan 08, 2010 | Computers & Internet
My nat is moderate. how do i fix it to make it more open
You can simply forward ports. I believe you are using XBOX 360. Here are the ports that you need to open
3074 TCP
3074 UDP
88 UDP
80 TCP
53 TCP
53 UDP
You can open those ports using your router's Port Forwarding feature. To know more about portforwarding, you visit
Oct 23, 2009 | SMC Barricade SMCBR14UP Router
How to connect 2wire 2700 HG-B router to voice modem motorola
that 2wire only works with DSL services, if you are using cable internet then no it wont work. If the surfboard digital voice is just a VOIP router then yes, plug the surfboard into one of the ethernet ports on the back of the 2wire.
Jun 06, 2009 | 2wire 2700HG-B Router (2700HGB)
What is portforwarding
You need to login to your router and go to firewall or virtual servers.  In there you can setup port forwarding.  The goal is to forward external (internet) traffic to a specific internal machine (your PS3).  You do this on a per TCP/UDP port basis and must specify the appropriate external TCP and/or UDP port and internal TCP and/or UDP port.  Sounds harder than it is.
Or you can setup your PS3 in your router's DMZ (Demiliterized Zone).  This sets up the router to forward ALL internet sourced traffic to a specific machine (your PS3).  This is the easier way to do it so you don't have to worry about specific TCP/UDP port numbers.
Jan 24, 2009 | Linksys Wireless-G WRT54GX Router...
Motorola Router SBG900i blocks download from particular server
The best page for portforwarding can be found here.
It mainly depends on the software and the ports used, so it might differ from application to application. has excellent user guides.
Jan 07, 2009 | Arris SURFboard 2.4GHz Wireless Cable...
Toyta engine
To my knowledge Toyota HG-J80 is an 80 series Land Cruiser powered by a 1HD-T diesel engine.
The 1HD-T belongs to the HD family of engines. The 1HD is 4164cc, 6cyl, turbo-charged, 4valves/cylinder, sohc, with bore of 94mm, and a stroke of 100mm, cr: 18.6:1. The T designate it as being turbocharged.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 06, 2008 | 1996 Toyota Land Cruiser
Open Questions:
See all 2wire Wireless-G 802.11g ADSL Gateway Questions
2wire Wireless-G 802.11g ADSL Gateway Logo
149 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
