Question about Sony SL-HF2000 VCR
Playback picture I have a Sony HF 720 VCR that has little use but has a major playback problem. The sound is fine from both lef and right channels. I have tried the manual and automatic tracking adjustment as explained in the owners manual. I have also cleaned the heads with a wet head cleaner. I also attempted the adjustment mentioned on your website buy removing the top and adjusting the guides. Nothing seems to have helped the picture is totally a vertical garb, recognizing nothing. Motor is smooth and quiet, remote works great, no other problems. Thank you for your asistance Brian
2 Suggested Answers
  • 579 Answers
SOURCE: Poor playback
Because the cable signal is OK, this eliminates the tuner as your problem and leaves the power supply which is a common problem. It is a switch mode type which often have trouble maintaining control of its output voltages and produce trouble downstream in the video circuitry. Either the power supply is failing which can be wholesale replaced for about a $150, or something somewhere else is failing and loading down the supply causing it to overwork. Usually in this case, you can hear a whine noise if you listen close.
Posted on Dec 28, 2007
Sound but no picture on the vcr
Do you have a picture with just normal playback of VCR? If the answer is no, then it sounds like the head might need cleaning. Use Servisol video 40 see image below:
Jan 24, 2010 | Samsung SV5000W VHS VCR
How can I set the channel BACK to CH 3 from CH 4
1) Set your TV to channel 3.
2) Insert a pre-recorded tape into this unit.
3) Press the OUTPUT button on the DVD/VCR so that the VCR OUTPUT light is lit.
• If noise appears on the TV screen, press the VCR/TV button on the remote control.
4) Press the PLAY button once.
5) After a few seconds, press the PLAY button on the DVD/VCR for 3 seconds.
• The RF output channel will change to channel 3 from channel 4 and you will see a playback picture.
• When a picture does not appear on the TV screen, repeat step [4].
6) Press the STOP button to stop playback.
Nov 17, 2007 | Emerson EWD2004
I have a Toshiba cx35e70 tv. The problem began as a turn on, live screen, no channels, no sound. I found that when I would tap on the tuner on the main board the problem would disappear. Every thing worked...
Is the VCR going through ch 3 or video inputs - if video inputs your TV tuner is likely bad if through ch 3 seeif te picture goes funny on ch 3 without using the VCR the tuner may be bad on higher band channels - smetimes you can remove the tuner and resolder the tuner itself. But if it always works with the VCR just use it that way and don't bother with the fix.
Sep 26, 2009 | Televison & Video
TRV-350 playback problem
Sounds like dirty heads. Get a head-cleaning tape and run that.
Dec 29, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
Recording from camera to VCR
1st setup ur VCD with TV and playback it to view on TV. If picture is coming, thats OK.
2nd plug ur camcorder in VCR input and select VCR input according to plug in and monitor the camcorder picture on TV through VCR. If its ok, now u r ready to record the picture from camcorder to VCR.
Jun 07, 2008 | Sony Handycam CCD-TRV308 Camcorder
Sony slv 715ub no stereo sound on tape playback
Hi, i have a Panasonic dmr-es30veb DVD ram recorder/VCR and i cant record one channel while watching another, as you can tell i am not at all technically minded and if you can help i would be grateful many thanks Eileen.
May 13, 2008 | Sony SLV-N750 VHS/S-VHS playback VCR
3-4 switch
1. Set tv to channel 4
2. insert a pre-recorded tape into vcr.
3.press play once to start playback.
4. after a few seconds press play on the vcr for 3 sec you will see a playback picture.
when a picture doesn't appear on the tv screen repeat step 4.
5. press stop to stop playback.
Mar 16, 2008 | Sanyo VWM-950 VHS VCR
Problems hooking up a VCRplayer
Hello..try to turn on the test signal generator switch it is marked test at rear of vcr...and chose av¨rf channel on your tv i.e the 0 or 9 channel than search for the vcr and memorize on tv...alt you can playback a tape ..pre-recorded without the test signal and make the search...alt 2...use a direct av-cable between vcr and tv..which is best and put tv in av mode...good luck...Ron
Mar 11, 2008 | Televison & Video
Sony SLV-798 HF VCR
on alot of vcrs if you already have a set time for one channel to record at a later time if you dant set the earliest first it wont let you change it but im not sure if you already have one set ahead of time or not
Feb 09, 2008 | Televison & Video
Proscan vcr psvr70
Sounds like it's wired up wrong...try this:
take cable line to VCR in, VCR out to cable/receiver box(if you have one) then box to TV...it sounds like the vcr is getting the channels from the box and not the vcr...you will need to have the vcr scan the channels (round in the settings menu) You will also be able to watch and record 2 different things.
Oct 18, 2007 | Proscan PSVR70 VCR
Sony SL-HF2000 VCR Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
