Question about GE 13TVR60 Combo
19tvr60 we have a couple of issue's. first tv remote dead. has new batteries.unable to access menu. not getting all channels.no menu feature on tv unit itself. all vcr tapes are playing in a distorted manner. HELP !!!!!!!!
  • bd2k5 Nov 27, 2007
    have a 19tvr60 tv and cant find teh remote codes or the steps to program remote
I had a dead remote as well - I took it apart and a component had broken loose from PC board. I am looking for schematic now to know what component that broke is - it had no helpful markings.
Posted on Mar 22, 2007
First try another remote.and play back try a vcr tape head cleaner. by 3m in a red case. those work.
Posted on Jan 12, 2007
SOURCE:
JVC tv stuck one channe
I would either call JVC to see if known issue or to inquire if set has a lockout feature that kills remote and all button features----other possible reason in main board with all micro functions has a problem.
Aug 27, 2012 | JVC LT-32P679 32 in. LCD TV
Manual for GE 19TVR60
use the internal buttons along the side till you get to input the use the channel adjust buttons to scroll up or down to antenna .one of the buttons on the remote should also do it but can not say for sure which one .
Jan 13, 2012 | GE 19TVR60 19 in. Combo
How do you get to the auxillary channels or the channel where the DVD player or video games would go? I have a DVD player hooked up to the TV, but it only goes from channels 2-69 with no auxillary/video...
Do you have the original remote? If you do, you need to press the input button (on the left below 7 and above the DVD controls). The external device must be on before you scroll through the available inputs. Unfortunately, I'm not sure if the OnScreen Menu has an option to toggle the Input (since there is a Menu button on the TV it would work around the issue).
A substitute remote that should access all of the TV features including the Input is available here: http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=32V420T&brand_pn=RCA_32V420T&mode=large&uuid=12787350637590
I hope this helps.
Jul 10, 2010 | RCA 32V420T 32" TV
I cannot get the channel feature to work on the tv. When I try to change channels either by remote or manually on the tv I get a message that says feature not available. i also cannot access tv channel...
I'm unsure of what this sentence means "i also cannot access tv channel through the main menu." Can you clarify? Have you tried unplugging the ac wall cord for a few hours then plug in back in and test again? If that doesn't fix the problem, your set will probably require servicing.
Jun 11, 2010 | Konka KDL32AT23U 32 in. LCD Television
I am unable to go to menu on my televsion.
Some universal remotes do not correctly handle the features of the original remote. You can get an exact duplicate remote from remotes.com: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=6509DD&uuid=12709186471510
Alternatively, get one of the higher end programmable remotes. The ones programmed from your computer are more likely to be trainable to do all the features of your original remot.
I hope this helps.
Apr 10, 2010 | Sylvania 6509DD 9 in. TV/DVD Combo
Cannot access channel 73 on TV2
If you are unable to access the TV menu using the buttons on the TV itself it is possible you can with the TV2 remote if it still controls the volume etc. for this TV. If it doe not you will need to find a code for your set in the manual for the receiver or you can go to the following link to find that info as well.http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/receiver/625.shtml
Assuming you have control of the volume still press the small TV button on the top left of the remote. Now press the menu button and you may be able to access the TV's menu. If so you need to run a channel scan/auto program the TV. You may need to use the buttons on the TV still to maneuver through the menu.
If you are still unable to access the menu you may need to purchase a universal to access the menu.
Jan 11, 2010 | DISH Network DVR-625 DTV Receiver /...
How do you get to the set up menu w/out a remote
hold down vol down on the remote and push 1 on the universal remote. this should turn your tv off and reset it to factory defaults alowing acess to all cable channels
Jan 08, 2009 | Toshiba MV13M2 13 in. TV/VCR Combo
Menu will not display
If the channel and volume visual display was not set up on the menu to display on screen , neither will show up even if either the remote or set front button are used. Make sure that the tv button is selected on the remote to access the menu .If that does not work ,then either the batteries are dead or the remote is dead.If it is you will need a new remote,sadly. Then you can press the m button , select sound and then select "display volume" and check "during adjustment". The channel display settings are found on "features" from the main menu. Hope this helps.
May 30, 2007 | Philips Magnavox 9P6034C 60" Rear...
GE 13TVR60 Combo Logo
136 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
