I can get the pilot lit, set the heat level, and the burner will ignite heat up and reach the heating level set. When the burner shuts down the pilot will diminish and go out, if I try to relight the pilot it will diminish and go out, after holding it down to allow the sensor to heat up, when I turn the dial to a setting. I have to wait until the heater cools off to light the pilot and have it remain on again, then once the burner cycles it does the diminish and go out thing again.
-   I also have the same problem. I sat and watched the cylcle to see when the pilot was actually going out. After becoming impatient, I decided to turn down the thermostat to make the cycle stop sooner. While still in the warm range the pilot would stay lit. after the water got a bit hotter (top of the warm range) the burner turned off and the pilot seemed to slowly extinguish. I was expecting to see it being blown out by the burner shutting off but that didn't appear to be the case. I cannot re-light the pilot until the water has cooled. I have replaced the Thermo-coupler.
TW-   saltyd33
Jan 14, 2009
-   Seems no one on the net can answer the question. It's gotta be a clear cut answer to such definate symptoms. Your description of problem is my EXACT problem also.-   floydgator1
Check regulator on the unit.
Check pilot unit on the heater
use soapy water to check for leaks if see bubbles turn off main gas supply valve.
always turn off gas supply before any checks or repairs are made
when all else failes call your local gas provider to check heater and gas supply
Was this helpful?
Yes
No
Popular Solutions for Rinnai Desa Vent-Free Infrared
I have a ventless Vermont Castings LP burner - the pilot light goes out when you turn the knob to...
(More)
I have a ventless Vermont Castings LP burner - the pilot light goes out when you turn the knob to "On" (otherwise it will burn all day) - sounds like it could be a faulty thermocouple. I was told by the supplier that with a ventless unit you are not permitted to replace the thermocouple only but must replace the whole burner assembly lwhich I imagine to be much more espensive - does this sound right??
I purchased a house with a Glo-Warm ventless heater. It is a FS-3B serial # 8776421 and the knob is...
(More)
I purchased a house with a Glo-Warm ventless heater. It is a FS-3B serial # 8776421 and the knob is missing. I would also like a manual for it.
Pilot light is always going out on my Desa vent free stove. Cleaned the pilot assembly and it still...
(More)
Pilot light is always going out on my Desa vent free stove. Cleaned the pilot assembly and it still is going out. Can you tell me what the milivolt range for the thermocouple. Help
i have a adesa model cbn 20t serial 014970796 when i hold the button down on the pilot light for 60...
(More)
i have a adesa model cbn 20t serial 014970796 when i hold the button down on the pilot light for 60 seconds as soon as you let up on the button the piolet goes out. what is wrong?
