Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA big screen,HDTV,2004,model#D61W20,,blinking power light
Turned off yesterday,,won't turn on today. green light in power button will turn on for 3 seconds,, then it will go out,,it will then do this 2 more times for a total of 3 blinks with the light staying on for 3 seconds with each blink....can anyone help? Thanks in advance
  • 5 more comments
  • michaelsnow3 Nov 23, 2008
    I removed back of set and fuse is fine,,however now I can hear the click and it seams to be comeing from a part that I believe is called a FLYBACK,,,saw this on other posts on this web site,,,,would that be the 3 blink power button problem?
    It's beyond me...I'm a carpenter...but thanks for your help,,,,buy the way,,,I have not had a TV repaired in at least 13 years,,,any Idea of what to prepare myself for thanks....
    Is the power board the board with the flyback on it or the board with the fuse at power cord entry point?
    How do I check if flyback is burned,,,can it be done with a simple continuity tester
    also, must fly back be removed 1st to do this
    see thread
    jl to
    Sergeant:
    Champion:
  • 283 Answers
Check the flyback if burned. I you decide to replace it,the small wires are disconnected at the focus and screen control block, and the large HV cable is disconnected from the HV splitter.you may have to reuse the large red wire if the new flyback doesnt have the HV lead attached. The Hot is the horizontal output transistor its mounted to a aluminum heat sink near the flyback. Try check also the tv lamp if working.... Please dont rate me if not satisfied..Thank you....
Posted on Nov 23, 2008
    Genius:
  • 1,550 Answers
This indicates that you have a faulty capacitor on power supply board . You need to check for the faulty capacitor on the board . Also chance of bad soldering .
  • 899 Answers
There is most likely a failure in the standby circuit and it will need testing to find the culprit
can you do some tests with a meter? or solder components?
if so I can help you determine the problem , but you may end up having to replace a board because of parts that are not available and only RCA has them and only will sell the board , not the parts
can you do this or will you need to call an electronic repair shop to have a tech come out and do the repair ?
electech
  • 2 more comments
  • jason Nov 23, 2008
    the clicking sound that you hear is the relay switch on the power section , this could be a bad horizontal output or bad or poor solder or even a failing flyback , but some tests will need to be done to find the exact cause , can you resolder or check some components?
    the repair will cost from $200 to $350 depending on the cause of the problem , if it is just a component then probably not to much but if a board or more exspensive part has to be replaced then about the 350 it will cost to do the repair
    electech
    yes you can check it for continuity , but remember that the flyback also sends power to other parts of the circuitry
    but before you do that look for any pr's ( pico fuses) that might be open
    then look for solder that might be bad
    after that check for capacitors that are not working correctly ( to do this put the meter on the highest resistor setting to see if you get a reading , if not, replace it)( this will not work with larger capacitors though)
    then check the horizontal output transistor and the components around the horizontal
    also check components around the vertical IC and its components
    then let me know the results of those tests
    electech
  • jason Nov 24, 2008
    you should also do this to make sure there is not a problem with the power in
    test the loptx ( low output transformer) for no voltage , low voltage , voltage drop on plug in and standby volts
    Scholar:
  • 181 Answers
Check out for the fuse of the tv on the main board it would have b;lown off.
Posted on Nov 22, 2008
My rca hdtv floor model big screen, shuts off after i power on..like 5mins after..3 blinking green light then turns off. why wont ot stay on? please help me! is this fixable?
it can be a flyback or a fuse or broken soilder an if you look at all the cap on the bord an you see any that look humped up or crack the could be it.
Jul 14, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
D61w20 rca turns on and off
I have a RCA D61W20 chassis ITC222, I had the same problem and my repair guy found out the blue bulb was the main problem, along with replacing some transisters on one of the power boards, He also had to adjust the service convergence (not auto convergence). Works great now!
Aug 27, 2009 | RCA D61W20 61" Rear Projection Television
Trouble turning on RCA D61W20
the green light blinks three times but does not come on
Aug 16, 2009 | RCA D61W20 61" Rear Projection Television
TV does not power up
I have mits 35" CS 3505 will not turn on... just turned off and thats all she wrote,,, what is the estimate cost of the deflection circuit board
thanks
artie
Jul 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52inch HDTV (2004 model) green power light flashes 3 times
Replace the flyback 259296 and the cp150 You can get the aprts with detailed instruction on how to do the repair at the following link.
http://servicemanuals.vstore.ca/
Jun 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca Big screen shut down and now no power
NO audio and no picture .... no power to on - off button. Checked outlet and it is good .... cable connection good - checked with another tv....
Jan 25, 2008 | RCA HD56W58 56" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
27 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
