Question about GE GSD4500G Built-in Dishwasher
Dishwasher Not Draining Properly
Once the rinse cycle is complete and the draing cycle starts, the water begins draining through the Air gap. I have the hole in the air gap cover pointed towards the sink, so that is where the water is coming out. What causes this? I checked the line from the air gap to the disposal and it is clear.
  • THUNDA Nov 03, 2007
    I'm encountering the same problem as Frisco.
  • 5 Answers
On many Dishwashers at the bottom ( remove lower rack ) is usually a metal mesh screen Under that screen is the pump inlet .When the screen gets clogged up or even restricted .It will either slow drain ,and or spit it out the breather hole on the air gap .So i think the issue is inside the dishwasher .If its a newer SS tub Then the mesh screen should be metal .However if its plastic then it will be a plastic screen Hard water deposits along with food particles can clog the pump screen
Posted on Jan 19, 2018
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: Dishwasher doesn't drain
Greg, if the model number ends in GO1, your dishwasher has a piston nut assy. thats problably giving you the grief. If this assy. goes bad you will have water left in the tub at the end of the wash. A common GE problem. It's located under the filter screen in the back and just unscrews out. Part number is wd24x199. It's an easy fix. Look up the part on the net to get an idea of what it looks like. Catriver..post back.
Posted on Jan 27, 2007
whytfang
  • 170 Answers
SOURCE: brand new dishwasher overflows all over counter during each rinse
It sounds like you have an Air Gap...a separate device that is used to prevent back flow into the DW. Take off the top of the air gap and see if it is gunked up and or clean it with a shop vac...as well disconnect the line to the drain evac it as well... also there is a reservoir in the back that is attached to the drain pump...take the screws out...see that it is clean and free of debris...be careful as glass or other particles can be in there. Also have you had a new dispoal installed if so the drain plug may not have been removed. As i read more I am certain you have an air gap...make sure it is cleaned and free from obstruction....if this does not solve the problem...here are some other GE specifc things and a link to help......
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Here is some GE specific info and a link.....
GE dishwashers will have a sump entrance screen ( #4 ) that should be removed and checked for any gookus, see 1 or 2 screws on the cover top, which is behind the lower spray arm. Almost all ( some newer GE dishwashers have a separate drain pump and motor - but for our purpose, we will talk about the most common GE dishwashers ) GE dishwashers have a drain solenoid ( #1 ) that can fail and stop the draining. If the solenoid cannot pull in the silver plunger, the drain port will not open to allow the motor and pump assembly to drain the water out. The solenoid can be ohmed with an ohm meter for continuity, or tested to see if it is receiving 110-120 volts AC. Many GE dishwashers have a self clean filter ( #3 ) inside at the back. The draining water must pass through a plunger in the self clean filter body. This can get clogged up, or the plunger may twist and distort and not allow the draining water to get past. The filter can be removed from the inside and the plunger will twist out of the self cleaning body for testing/checking. Next obstacle for the draining water in the back flush valve ( #2 ). This valve can twist or distort and block the water flow as well. The drain port will need to be accessed to check this flapper valve, the drain port will untwist from the self clean filter body. All hoses in-between the items mentioned above and the drain hose itself all the way to the house plumbing should be checked for restrictions.
Some extra filter, draining tips and pictures....
During the wash and rinse modes of the cycle, soiled water falls down the back of the tub and into the filter area. The water comes through the filter and back into the tub. During the wash and rinse periods all ( we hope! ) the water will pass through the filter. The soil will settle into the collection chamber and is held there. When the dishwasher goes into the pump out mode the water in the sump is pumped through the collection chamber. This closes the piston valve to the inside of the tub. The pump flushes the collection chamber of all the food soil and pumps it down the drain. A check valve is located in the drain line port. This valve allows the water to flow in the drain direction only and prevents the water from coming back into the tub. The drain line check valve must close in the back flow direction or the piston valve in the collection chamber may not reopen into the tub after the pump out is complete. Water should "fall" through the filter and go back into the tub....the heavier food particles go down into the chamber and are collected.
Here is a link for you to check out...I have all this info in my data base but since it is in PDF format it does not translate well to this format...
http://www.applianceaid.com/gedishdrain.html
I hope this helps...it is always useful to include the Model #...more specific instructions can then be provided
Good Luck and good day.....please rate my effort...the Fang
Posted on Mar 28, 2009
ginko
  • 19396 Answers
SOURCE: Water not draining completely from Dishwasher tub
That usually happens because of a faulty water level sensor, check it out.
Posted on May 21, 2009
  • 3 Answers
SOURCE: GE diswasher GSD4020Z02BB doesn't completely drain
This is exactly what happened to me and I paid the repair man. Learn from me. Open dishwasher, unscrew screen along back of dishwasher. Piston assembly should be right there. Part is WD24X10018. GE will charge you $17 plus labor. Can buy it on-line for around $12. Takes about two minutes to fix.
Posted on Jul 08, 2010
My GE dishwasher drains fine after wash cycles. However, After rinsing, about 2 inches of water is left in the tub. The drain runs for 30-35 seconds at the end of each wash cycle, but only 4-5 seconds...
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 12, 2010 | Dishwashers
Not draining water after cycle has completed
Hi
Thanks
Rylee
Dec 24, 2009 | Whirlpool Dishwashers
GE GSD4920Z dishwasher. Problem is that it does not drain completely at the end of the cycle--about an inch of water remains. After checking for clogs, etc, we followed a troubleshooting procedure which...
Hi
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 09, 2009 | GE 24 in. GSD4920Z Built-in Dishwasher
My kenmore ultra wash plus is not draining
Hi
Thanks
Rylee
Nov 04, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore ultra wash dishwasher model 15752000 is not draining completely after cycle has finished
Hi
Thanks
Rylee
Oct 21, 2009 | Kenmore Dishwashers
Runs the cycle but doesn't drain completely
Hi
Thanks
Rylee
Oct 12, 2009 | Kenmore Dishwashers
Dishwasher doesn't drain completely after full cycle
If there is any blockage in your diposal, water will comes up to the sink, since it happened to me. As soon I installed the air gap then it fixed the problem. No air gap, water flowing is slowing down conflicting with timed draining causing this problem. Let's think of this, if you fill up water in a 1/2 galon milk container, and you try to emty it. If you pull down straightly , it will be slow compared to pull it at an agle to let air going into the opening. The air vent helps water flow better meeting the timed draining.
Sep 13, 2009 | KitchenAid 24 in. KUDP01IL - Multiple...
Diswasher does not drain after rinse.
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to some different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then you may want to consider calling a professional plumber. He may need to replace the drain valve or hose.
Thanks
Rylee
Aug 20, 2009 | Maytag Dishwashers
Kenmore Ultrawash QuietGuard 3 Dishwasher not draining or rinsing
Not draining may either need new drain motor. or something is blocking the drain pipe.
Spots on dishes means you are using to much detergent or the wrong kind of detergent.
Your owners manuel should tell you what type to use.
Nov 18, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwasher dosen't drain completely
HI. check the following areas for faults.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Dec 08, 2006 | GE 24 in. GSD2600GBB Built-in Dishwasher
GE GSD4500G Built-in Dishwasher Logo
46 people viewed this question
Top GE Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Steve Allison
Steve Allison
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
