Question about Vtech 5.8GHz Cordless Phone with Digital Answering System
At&t answering machine model 1305 just beeps and the light flashs
The answering machine light is just flashing and no matter what button i hit it just beeps at me . its an at&t model 1305 . please help
  • Anonymous Dec 19, 2008
    can not get the answering machine to record incoming messages when it says it's on
  • lecounte Jan 10, 2009
    I have the same problem with my AT&T model 1306 answering machine. I even have tried putting a new cassette in it as well as disconnecting the phone and the entire unit for a while but when I turn it back on, the light is flashing continuously and it beeps when I touch any key.
  • 959 Answers
Disconnect the power to the phone and let it sit a while. Plug it back in and see if that doesn't help you out .
Posted on Nov 24, 2008
My washing machine is only beeping and all lights flashing
I don't know the make or model number of the unit, but most likely the beeping and/or lights flashing is a digital error code being displayed. I need more info to better help you with your issue. If the lights are blinking in a pattern(ex 2 blinks followed by 4 blinks) or certain functions are blinking in a pattern over and over, that is an error code display which must be interpreted. The machine is trying to tell you where the problem is.
Aug 19, 2015 | Washing Machines
The lights come on, but the machine doesn't start
do you hear a beep when the start button is pushed? if u do hear a beep then it could be your lid switch is faulty, if you dont hear a beep then your keypad is faulty. is the plastic covering the buttons cracked?the keypads fault sometimes because water goes thru the cracks into the electronics causing it to corrode. please reply with answers 4 more help.
May 06, 2010 | Fisher and Paykel GWL11 Top Load Washer
Error keeps popping up
PROBLEM
CAUSE
SOLUTION
3 beeps sound and E:rr flashes on LCD display (31)
prog (24) was pressed before clock time was set
auto (23) was pressed while no program was stored
TSB was pressed (25) before brew cycle was complete
Set clock time, then set the program
Set the program first.
Wait until brew cycle is complete and 2 beeps sound
Mar 05, 2009 | GE 106591 Coffee Maker
Beeps but doesn't start
Duet dry lights up, hit the start button and it just beeps and lights flash. but will not start.
Mar 01, 2009 | Whirlpool GEW9250 Electric Dryer
Model 1305 at&t answering machine
http://telephones.att.com/telephones_ui/support/dsp_manual.cfm?manualID=151
Apr 18, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Hi Mrs R-
I found this link where you can go to download the manual for your phone. It's an Adobe PDF.
1. You will need to click on the link below.
http://telephones.att.com/telephones_ui/support/dsp_manuals_list.cfm#257
2. Your model 1305 is at the top of the list. Click on "1305 Manual", which will be in Blue Letters.
3. It should look like this:
f43c815.jpg4. Click on Download the 1305 manual.
5. It may ask you to specify where you want to save it onto your computer - or you may just open it from online.
6. From what you said it sounds like you may need to turn the tape over.
Hope this helps!
faishortcake
Apr 17, 2008 | Lands Phones
Zanussi zwf 1432 w washing machine
pcb as the signs were that the pcb was stuck in a programme and unable to change. Anyway, long story short, to fix it:
Take the lid off the washing machine (2 screws at the back) *unplug first
Locate the pcb, unscrew and lift above the washing machine with all wires in tact.
Locate the wires that are coming out of the back of the "program" board, it should be 2 blue wires.
Follow these back to the pcb and unplug
plug in washing machine
Turn on washing machine
Only the on/off light should come on
Whilst on, and being careful, plug back in the wires you unplugged
VOILA, fixed washing machine!!
Right, have to go, got a weeks worth of washing to do!!!!
Feb 24, 2008 | Zanussi ZWF1430W Front Load Washer
Problem with frigidaire washing machine
I've read in a product review that Frigidaire put out a service bulletin regarding the electronic timer circuit board in these machines. Apparently enough of these boards failed to prompt a factory response. With this in mind, you should call an appliance repair center and ask them if they're aware of this Factory Service Bulletin. In many cases like this, where a part is manufactured defective, the repair could be free to you.
Apr 15, 2007 | Frigidaire GLTF1240A Front Load Washer
My tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Dec 14, 2006 | Tricity Bendix AW1400W Front Load Washer
Vtech 5.8GHz Cordless Phone with Digital Answering System Logo
131 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
