Compaq won't recognize DVD burner as lightscribe device
I installed a Ativa DH-3H20A CD-DVD burner in my Compaq Presario SR1630NX. It installed easily enough as ATAPI DVD A DH-3H20A. However, when I look at the lightscribe comtrol panel, it indicates No Lightscribe Drive Found. Can you please help me?
  • 1 more comment
  • dkipp24 Nov 23, 2008
    The jumer on the hard drive was set to cable select. I moved it to master. Upon restart, I still have No Lightscribe Drive Found in lightscribe control panel. I uninstalled the DVD burner in device manager and reinstalled. Still No Lightscribe Drive Found in lightscribe control panel.
    Snapshot of device manager:
    Ginko, you rock, dude! The registry change fixed it, but it did require a restart to take affect. Thank you so much!
    Ginko rocks! Thanks dude!!
  • 19,396 Answers
If the hard drive is IDe PATA, check the master/slave jumper at the back.
Posted on Nov 23, 2008
  • 2 more comments
  • Ginko
    Ginko Nov 23, 2008
    If the hard drive is PATA (parallel with ribbon cable and large connector), check the master/slave jumper at the back.
    If it is SATA, (small connector) check that Sata ports are enabled in BIOS.
  • Ginko
    Ginko Nov 23, 2008
    You should be able to use the DVD even if not recognised by the software, this happens because:
    The Restrict CD-ROM access to locally logged on user security option is turned on.
    Try the following :
    Verify that the Restrict CD-ROM access to locally logged on user only option is not turned on.
    a. Click Start, click Run, in the Open box, type regedit, and then click OK.
    b. Locate and then click the following registry subkey:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
    c. In the right pane, under Data, if the value for allocatecdroms is 0, go to step 5.
    d. In the right pane, under Data, if the value for allocatecdroms is 1, right-click allocatecdroms, and then click Modify.
    e. In the Value data box, type 0, and then click OK.
    f. Quit Registry Editor.
    From Microsoft.
  • Ginko
    Ginko Nov 23, 2008
    SeeNo LightScribe devices w/GSA-2166D?
    Here is the microsoft article, it is for a different software, but it work the same: 330135
  • Ginko
    Ginko Nov 23, 2008
    You are welcome,
My computer does not recognize my hp 557s as a lightscribe compatible device
Hi professa31!
Have you tried installing the Lightscribe software bundle? Their website says that it's required for operation of any lightscribe device. Here's the link: http://www.lightscribe.com/downloadsection/windows/index.aspx?id=810
Also, it appears that there are a bunch of reasons why it may not be detected, most of which are not bad at all. Here (http://www.lightscribe.com/support/index.aspx?id=401) is a list of a few reasons, from the lightscribe website.
Mar 03, 2011 | HP Hewlett Packard HP DVD557S 8x USB Slim...
No sound from my compaq presario is coming forth. no sound driver.
You need to download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP or Vista Windows version of the drivers you require and install them. Click on this link to download the drivers: -
www.compaq.com/country/cpq_support.html
Jun 21, 2010 | Compaq 389897-001 - HP/ Presario V2000...
Sony Optiarc AD-7581A 8x DVD?±RW DL Notebook IDE Drive w/LightScribe Burner is not being recognized and installed.... It shows the error 10 "device will not start" can anyone help?
Try a cold boot. Shut down the computer. Remove the battery. Unplug the power cord. Wait at least five minutes. Start up the computer. If still does not work, go to device manager --> CD/DVD drives. Uninstall the Optiarc drive. Go to Actions --> Scan for Hardware Changes, or simply reboot to reinstall the drive.
Apr 05, 2010 | Sony Optiarc AD-7581A 8x DVD?±RW DL...
Lightscribe not detected
go to lighstrcribe.com and dowload all the software there.
there are special programs/drivers there that you need to have.
then reboot and nero should pick it up
Apr 24, 2009 | QPS Que! Fire CD-RW Burner
Ativa CD/DVD with LightScribe
the driver is packaged with nero 7 essentials (Grrr...)
Apr 26, 2008 | QPS Que! Fire CD-RW Burner
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
