Sounds like elements are not turned on there might be a switch for the elements or the hi-limit thermostat is damaged, or the pressure stat is turned off.
hi.. the model may have a digital timer that is accessed using the panel
swithes get the number for wilbur curtis from thier web site they will
talk you through it {simple} the other style timer is a potentiometer
type... To adjust first unplug brewer, look behind either the front panel
or top cover for a dial with numbers around it. turn the dial down
slightly brew a pot of water see where the water level comes keep
turning down till desired level is reached...
that model may have a digital timer that is acssed using the panal swithes get the number for wilbur curtis from thier web site they will talk you through it {simple} the other style timer is a potentiometer type To adjust first unplug brewer, look behind either the front panel or top cover for a dial with numbers around it. turn the dial down slightly brew a pot of water see where the water level comes keep turning down till desired level is reached
