Question about Grohe 19.045.000 Seabury Thermostatic Roman Tub Filler with Hand Shower - C...
Ghroe Seabury 25502 roman tub filler leaking at liftrod control
I've a Ghroe Seabury 25502 roman tub filler when i turn the water on it will squirt/spray through the top of the liftrod that controls the spout/shower ,
when I pull it up so the water is diverted to the hanheld shower its fine but if I push it down to divert the water to the spout it will start to spray ou of the top
someting I can take apart anf fix or do I need a whole new spout assemly
thanks
Manny
    Problem Solver:
  • 18 Answers
It can be repaired.
You can see an exploded diagram here
I can post more if you need more specific instructions.
Posted on Dec 11, 2008
Why hot water is still running when house water is turned off?
Is the hot water under sustained pressure or after you leave it on for 15 seconds or so, the flow lessens? If that's the case, the residual pressure in the pipes is forcing the water out as well as gravity if the faucets on the lower floors are still flowing.
Oct 03, 2014 | Kohler Brushed Nickel Roman Bathtub Tub...
Delta foundations windemere roman tub faucet leaking out of spout
If you will make contact with George at M-One-Specialites he can track that down for you and help you get that fixed.
He has a very extensive list of repair parts for faucets.
Rod
US Parts Center
Jan 28, 2013 | Delta BT2796-SS Foundations Windemere...
How do I tighten the faucet handle. The handle is floppy and unless you put downward pressure on the handle when you turn it, it will continue to move from left to right
From what you have described it sounds like the stem in which the handle rests on is stripped and allowing to move from side to side.
Remove handle it has a set screw in the side of it and turn water off. Check the stem may be in need of replacing or the retaining nut that holds the stem down to counter top may be in need of tighting.
Feb 12, 2011 | Kohler Brushed Nickel Roman Bathtub Tub...
Leaky faucet
From the sounds of it. It is time to call in a Pro. Be sure to check references. I hope all goes well.
May 26, 2010 | Grohe Seabury Roman Tub Faucet with...
Moen Tub Filler Can't Remove Spout
It should lift off gently twist as you lift maybe tap spout lightly back and forth with a rubber mallet
Oct 14, 2009 | Moen Kingsley Two Handle Roman Tub Faucet...
Danze sonora roman tub personal shower stopped spraying, no kink in hose, no plug in sprayer
I had the same problem and just now fixed it.  Remove the faucet head - the tub filler - and pull out the diverter tube insert.  It's the valve at the bottom that's sticking - probably because of calcium or mineral deposits.  I washed mine with white vinegar and pushed a wooden spoon handle down the tub to unstick the valve, scrubbed it with vinegar and a toothbrush and re-installed.  Works perfectly now.
Jun 27, 2009 | Danze D303754CSN Sonora Roman Tub Faucet...
Low water flow
buught sink taps same problem do they have flexy conectors with them. my problem was as they are american hot @ cold water suply are maines fed so hole in bottom of taps [or in flexy pipes are too small
May 17, 2009 | Danze D302521 Antioch Roman Tub Faucet...
Grohe 19.045.000 Seabury Thermostatic Roman Tub Filler with Hand Shower - C... Logo
279 people viewed this question
Top Grohe Home Experts
Mike
Oloyede Monsuru
Are you a Grohe Home Expert? Answer questions, earn points and help others
