Will not open tape door (Onkyo TA 2055 cassette tape deck)
I just bought this at a thrift store as is. It also appears the drive motor is not running. I see various indicator lights but it will not eject tape or open the door. There is a remote socket in the back...does the remote (which I don't have) have to be plugged into the socket for the deck to work with front panel controls?
thanks
tom
  • 579 Answers
SOURCE: Left Deck Door Stuck Shut on Cassette Deck
The cassette mechanism has a large gear that rotates to different positions for the different modes. On time around is a play - stop cycle. It is stuck in one position and won't come around to the stop spot. Need to take the cover off and help it to turn to get the cassette out. Then figure out if something is wrong preventing it from turning or if the wheel driving it is the problem. They are all a little different so this is where your mechanical apptitude comes in.
By the way, you'll figure out right away they don't intend these things to be fixed.
Hope Ya Fix It.
Posted on Feb 10, 2008
tech48
  • 624 Answers
SOURCE: Onkyo six CD changer stuck
The Onkyo CD changer has an internal mechanical problem that could be anything from a disc being jammed in the mech, to a bad belt, or a bad IC or supply voltage that goes to the servo circuit. No way to be certain without troubleshooting it. You can open it up and see if a disc is stuck, but unless you have some experience in this sort of thing it is better left to a professional, You can cause more damage than you started with by trying to fix something you don't know that much about.
The tape deck could have any number of problems as well. A bad belt or gear, a defective servo circuit, and the list could go on, but they are all things that also should be checked by a professional.
Most of the time a tape won't eject is form the tape head being engaged and not letting loose of the tape. But since it won't turn off, you have some more serious problems. That is an indication of something not communicating with the microprocessor. It could be a digital transistor, a shorted capacitor, and like before, many other things. Whatever you do, don't force the tape deck open. It will destroy the head assembly and it may even void your warranty (you did say it was new).
You need to find an authorized Onkyo service center near you. Contact Onkyo if you can not find one yourself.
This really is the best action you could take. Onkyo is a very good brand, and in most cases is worth getting repaired. If it were some type of cheap-o brand it wouldn't matter what you did to it because replacing it would always be cheaper than paying for a repair. That is not the case with your equipment.
If I can be of further help, just ask me.
Dave
Posted on Jun 28, 2008
  • 4234 Answers
SOURCE: Cassette Tape stuck
The problem here is that the unit is stuck in a partial position. The "reset" by unplugging and plugging back in usually causes the unit to reset to a known position. If there is no activity (no motor sound), it will need to be opened up and reset manually. If you hear the motor running for a short period, it is attempting to reset, but the belt is most likely worn or broken. These units are relatively simple, but a bit tricky to dis-assemble. This repair should not require anything other than a belt or 2. Figure on $3-$10 for parts plus the local labor rate for the repair.
Dan
Posted on Oct 07, 2008
petraman7
  • 1175 Answers
SOURCE: Tape deck won't play.
Hi...
From being a Pro-tech and working on these and other like them I'd say it's the main belt+ idler wheel that has worn out.
Very challenging job to do..Like knightstar7 said
Posted on Feb 09, 2009
SOURCE: aiwa cassette deck won't eject
I had this problem on an AD-S40. Turned out to be the drive belts, which had stretched, resulting in the fact that the motors couldn't drive the mechanism through it's various load cycles of opening/closing the captain roller, etc. as required to operate the mechanism. Stuck in mid-cycle, the doors would not open.
After removing the case cover, you can turn the belt driven wheels by hand to complete the cycle, so that you can eject. Then get new belts (several outfits sell belts based on length, on line). You don't need to do much to replace the belts -- after unlocking and getting the tape out, it was only a couple of screws to remove the mechanism, as a unit, and there is no need to fuse with the circuit boards and such. Easier than I expected.
Posted on Apr 20, 2009
How do I connect Onkyo cassette deck TA RW 470 to Onkyo receiver TX 903?
Hi Angela, you would connect the tape deck to the tape in and out inputs on the back of the Onkyo, if you need assistance please give us a call at 800-229-1687 our Product Support Team is here 24/7 ready to assist, Thanks, JT
Nov 16, 2015 | Onkyo Audio Players & Recorders
I just got an Onkyo R1 TA-RW505 dual cassette deck and the left deck door won't open with the eject button. I did get it open by sliding a slim knife behind the door and it appears that there is a
This is most common as the catch is there to stop you from opening the cassette door while the head base is in the up position. The reason many of these cheap dual cassette decks all have this problem is that the mechanisms are not built to last and then the cost to repair them exceeds their value. You need to find out why the mechanism is not getting back to the stop position and when you do this the eject issue will be fixed. Typically it is a stretched belt.
Putting it in is another matter though.
Mar 11, 2013 | Audio Players & Recorders
Where can I find a repair manual to replace belts on my Onkyo Stereo Cassette Tape Deck TA-630d
I have found a service manual for you that can be downloaded free:
http://elektrotanya.com/onkyo_ta-630m-sm-tape-deck.pdf/download.html
After the page is appeared fully, click on this place:
Get Manual
Not logged in
Only 2 downloads
allowed a day
and the downloading will begin.
gylacz
Mar 31, 2011 | Onkyo TA-RW255 Single Cassette Deck
I have a onkyo cassette tape deck ta 2600,when you push play on the cassette,it would play the tape for half of a second and stop
Sounds like the cassette tape itself is too tight to play, try fast forwarding or rewinding the tape in the deck all the way to the end of tape several times before trying to play. This may solve the problem
Dec 27, 2010 | Onkyo Audio Players & Recorders
My cassette deck Onkyo model Ta 2060 is working slowly
HELLO
By the fault you describe this sounds very much like a belt problem. Take the case off the deck and check the belt(s). Some decks can use more than one belt and you need to look at their condition.
Are they too slack around pulleys maybe? Belts don't last forever and I'm not too sure of the age of your deck. But personally, I would change them all.
Make sure the tape path is clean as well, clean heads, pinch roller and capstan.
Dec 14, 2009 | Audio Players & Recorders
I need replacement drive belts for an Onkyo
i bought some today from **** smith electronic store , i paid $7.97 for a pack of ten assorted sizes
May 18, 2009 | Audio Players & Recorders
Gunk fused to record & playback heads of Onkyo cassette deck
The best cleaner for heads is Servisol Video 40. You can get it from Maplin's UK or Amazon.
Mar 19, 2009 | Onkyo TA-RW244 Single Cassette Deck
Cassette tape spins fast
Hi Chris..
It's not worth repairing. I would find something else in good condition
Feb 01, 2009 | Onkyo TA-RW244 Single Cassette Deck
Sounds like the belt that drives the capstan is too slack or decomposed, The capstan(s) which are connected to a geared flywheel, also drives the transport mechanism. There can also be tarnish on the sensor leaf switches, preventing contact. You might try to repair it yourself but, it is not an easy or simple job
Apr 23, 2008 | Onkyo TA RW544 Single Dual Cassette Deck
146 people viewed this question
 Grubhead
Grubhead
