Question about Kenwood KAC-7202 Car Audio Amplifier
Brand new battery install 98 dodge pick up
I have an emobolizer installed on vehicle and I removed old dead battery, and when I attempt to install the new one ( positive on positive, then neg,... I get a small spark...is this normal...? im scared to connect it now.. can you guess I'm female ? :)
    Novelist:
    Scholar:
  • 85 Answers
A small spark when reconnecting the battery cable is normal
no spark at all would be a concern sice that uaually only happens with a dead battery.
Posted on Nov 23, 2008
Brand new battery dead in 1 day had to get jump. with truck running i removed both post and truck continued to run 2001 dodge ram
I would be having the alternator tested as the rectifier may be faulty and allowing the battery to discharge from running the vehicle electrics on it's own
Dec 21, 2013 | Dodge Ram 1500 Cars & Trucks
Last Year I installed an AVITAL5103 Remote start & Security on My 2002 DODGE RAM 1500 Q.Cab.Everything was working fine,util I instal a new car battery.When I attempt to remote stert ,the starter cra
There are two types of starters for Dodge, if you installed new battery, check to see if the remote start is to ignition module or starter solenoid, then make sure the circuit has not been closed-they go in series circuit!
Nov 29, 2011 | 5103L Security/Remote Start System
My 2000 GMC Jimmy had brand new battery installed roughly a week ago. Attempted to run errands last evening and whole vehicle was dead: unable to use key fob to unlock doors, engine didn't even attempt to...
Does or did the check engine light ever come on durring all of this ? Or did the alternator light ever come on durring all of this? Jump starting another vehicle, damage to your battery I duoght it, damage to your Alternator and or other electrical componants highly possible if not connected properly.The new battery going dead again could cause all of the problems you have discribed for me. If I were you the first thing I would do is check the new battery and see if it has gon dead now. If so check to see if it is Frozen. If it is frozen you will half to replace it, because once a battery has frozen it will never hold a charge again.Once you have replaced the battery with a good known one (fully charged). Start engine and warm up to normal operating temperature and then disconnect the battery if the engine keeps running then the Alternator is fine . If the engine stalls then you need a new Alternator.A bad Alternator could have ben the problem from the start.I also live in a cold climate zone ( RedDeer, Alberta, Canada).Good Luck and have a good XMSS.
Dec 13, 2010 | 2000 GMC Jimmy
How to put the Starter in a Eagle Talon 1991.
from autozone.com
REMOVAL & INSTALLATION
See Figures 5, 6, 7, 8, 9 and 10
  1. Disconnect the negative, then the positive battery cables from the battery.
  2. For 1990-94 vehicles, remove the battery and battery tray from the engine compartment.
  3. For 1990-94 vehicles, detach the speedometer cable connector from the transaxle.
  4. For 1995-98 2.0L turbo engines, remove the air hose.
  5. For 1995-98 2.4L engines, remove the air cleaner and air intake hose.
  6. If equipped with 1.8L engine, remove the bracket on the lower side if the intake manifold.
  7. Detach the starter motor electrical connections.
Fig. Fig. 5: Exploded view of the starter motor and related components-1990-94 vehicles, others similar
Fig. Fig. 6: Unfasten the BAT terminal connector from the starter motor
Fig. Fig. 7: Unplug the starter motor electrical connector
  1. Unfasten the starter motor mounting bolts, then remove the starter from the vehicle.
Fig. Fig. 8: Unfasten the starter mounting bolts
Fig. Fig. 9: Remove all of the starter mounting bolts ...
Fig. Fig. 10: ... then remove the starter motor from the vehicle
To install:
  1. Clean both surfaces of starter motor flange and rear plate. Install the starter motor onto the engine and secure with the retainer bolts. Tighten the retainers to the specifications shown in the accompanying figure.
  2. Attach the electrical harness connector(s) to the starter.
  3. If removed, install the intake manifold stay and tighten the retainers to 18 ft. lbs. (25 Nm).
  4. For 1995-98 2.4L engines, install the air cleaner and air intake hose.
  5. For 1995-98 2.0L turbo engines, install the air hose.
  6. For 1990-94 vehicles, attach the speedometer cable to the transaxle. Install the battery tray and battery.
  7. Connect the positive, then the negative battery cables.
Operate the starter to assure proper operation.
Oct 29, 2010 | 1991 Eagle Talon
I have a 2005 Dodge Sprinter 2500. Battery exploded when I turned the ignition on. New Battery got installed but when I turned on the radio a signal appeared CODE. What does this mean?
any time the battery is removed without a memory saver the radio gets locked-this is for security purposes-if you bought the vehicle brand new there should be a radio code card in with your owners manual-if not you will have to contact a dodge dealer to get the new radio code or to get it reset-if you have to go to dodge for the code i recommend writing it down in case it happens again
Sep 15, 2010 | 2005 Dodge Sprinter 3500 Standard Roof
CODE P0137 ON A DODGE NEON
Go to Auto Zone or O'Rieley's or any local Auto parts store. Tell them you need the Downstream O2 Sensor on your vehicle, preferably not the generic one. (These you typically have to assemble the end connector for the wires by matching it to yours, You don't want that unless you have no choice) Also get the Special Socket for removing and installing it. Jack the Right Front end up with a Floor Jack preferably and put the vehicle on a jack stand. The O2 Sensor you are looking for is located under the Drivers side after the Catalytic converter. Unplug and remove the old one and after putting the Anti-Zeeze on the threads of the new one, this usually comes with it or you can pick up a packet at the register, install it and plug it in. It needs to be tight but not so tight you need a impact wrench to remove it. To reset your code remove the NEGATIVE battery terminal for 1 min and replace. Happy Driving.
Jun 28, 2010 | 2005 Dodge Neon
98 dodge avenger es 6 cyl., won't start
Is you battery going dead? How old is the battery? After 4-5 years a battery is bad and needs to be replaced.
It sounds like you didn't replace the alternator?
Do you get a click when you try to start and it wont start?
Also check the grounds on the starter they could have corroded and this would cause an non-normal starting pattern. To chech these locate them, usually close to that starter and screwed into the frame of the vehicle. Unscrew them and take a wire brush and clean them very good making sure to expose bare metal. Do the same to the frame where it is screwed into.
Make sure to unhook you battery before doing anything!
Reply with the answer to the questions and we can go from there.
Good Luck,
Subikid90
Mar 04, 2010 | 1996 Dodge Avenger
I want to change the O2 sensor in my 1999 dodge durango. Is it hard to do? It looks like it just plugs in, but I don't know the location where I would find it on my car. I have just seen a picture of what...
No...not hard to do.....if you have the right tool.
Hope this helps!
Sensor sockets, like this one from Lisle®, are slotted on one side to accommodate wiring
Most models have O2 sensors to monitor emissions before and after the catalytic converter
Removal & Installation
WARNING NEVER apply any type of grease to the O2 sensor electrical connector or attempt any soldering of the wiring harness. This will influence the sensors operation.
  1. Disconnect the negative battery cable.
  2. Raise and support the vehicle.
CAUTION The exhaust pipe gets extremely hot during engine operation, and if touched, severe burns can occur. If servicing the oxygen sensor, avoid contacting the exhaust system.
  1. Disconnect the wiring harness from the oxygen sensor.
  2. Remove the sensor using the appropriate tool.
NOTE The oxygen sensor threads are coated with an anti-seize compound. The compound must be removed from the mounting boss threads, either in the exhaust manifold or Y-pipe. An 18mm x 1.5 x 6E tap is required.
To install:
  1. Clean the threads of the mount to remove any old anti-seize compound.
  2. If the old sensor is to be reused, apply anti-seize compound to its threads. New sensors come with the compound already applied.
  3. Install and tighten the sensor to 22 ft. lbs. (30 Nm). Connect the wiring harness.
  4. Lower the vehicle.
  5. Connect the negative battery cable.
Oct 22, 2009 | 1999 Dodge Durango
Security system-passlock
I hav a 1995 88 w/ same problem. Key was worn out, Had Security system disabled.by installing a resistor to by pass Sec. System.Had it done for $35.00 Check locally for a starter/alternator shop in your area.
Jan 05, 2009 | 1998 Oldsmobile Intrigue
Kenwood KAC-7202 Car Audio Amplifier Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
