SOURCE: Where is the throttle position sensor at on a 2005
THIS ENGINE HAS ELECTRONIC THROTTLE CONTROL..THERE ARE 2 THROTTLE POSITION SENSORS LOCATED IN THE THROTTLE BODY,COMPLETE ASSEMBLY MUST BE REPLACED IF DEFECTIVE..IT ALSO HAS SENSORS IN THROTTLE PEDAL ASSEMBLY AS WELL..WHAT TROUBLE ARE YOU HAVING?
SOURCE: mitsubishi outlander cooling fans not operating
There is a Recall to replace your cooling fan module because of this concern.
Open your hood and look at the black box bolted to your radiator fan by the battery. If it does not have a green dot on it, you have not had the replacement fan module installed.
Contact your local dealer with your VIN handy to verify the recall has not been done and to schedule an appointment.
If the recall has been done, verify if you have power coming out of the module to the fans, as the fans do burn out eventually.... but rarely both at once.
SOURCE: RPM to low (700rpm) mitsubishi outlander 2.4L 2005
Your throttle body likely needs cleaning.
Take the intake hose off and using throttle body cleaner or brake cleaner, spray a rag and use our fingers to clean the gunk off the throttle plate and the contacting area of the inside of the throttle body.
SOURCE: need mitsubishi outlander 2005 drive belt diagram
Here you go, please be sure to rate me if you find this answer useful!
