Question about Nikon Coolpix 2100 Digital Camera
Nicon Coolpix 2100 - Not able to close the lens and camera doesnot work
I have Coolpix 2100. While taking photo the battery power went off. After that, Iam not able to close the lens and as well Iam not able to take any pictures. The display also will not turn on. Even i tried by replacing with different battery.
It hapenned to me last mouth..! but I wasnt able to got the lens in
Posted on Apr 17, 2007
After my Nicon coolpix S570 has dropped on the floor, the lens does not work and when i turn on the camera, i hear a noise and get a message for lense error.
you have stripped the lens gearing you will find that you need to have the lens gogs replaced a very expensive repair sir. it may be time to buy a new one
sorry
take care
may you and yours have a happy new yr
Dec 29, 2010 | Nikon COOLPIX L3 Digital Camera
Lens Error !
Follow the above steps:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in and turn the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. Error E30 means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras AV cable, and turn the camera on in picture review mode. Have no idea why this would work, except that quite a few people have reported some success with it.
Fix #4: Place the camera flat on its back on the kitchen table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum cleaner.
Now we're entering into the realm of potentially damaging your camera in conducting the fix. Take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. A lot of people have reported success with this method. HOWEVER, there is some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables.
Fix #7: Try forcing the lens. Many people have also reported success with this method. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include pulling, pushing, rotating or twisting on the lens barrel while hitting the power button. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the lens barrel side that has the largest gap. While doing these, listen for a click that indicates that the lens barrel guide pins have reseated in their guide slots. If you hear this click, immediately stop and try the camera. The following photo illustrates unseated guide pins that would cause a lens error.
Goodluck,
Please don't forget to rate me as fixya..
Feb 01, 2008 | Nikon Coolpix 5200 Digital Camera
I dropped my Nicon E8700 and it landed on the lens... IT stopped working. Is it repairable?
I hope your lens did not shatter. It is repairable. Please take it to the service center. If the lens is not shattered, the cost should be low.
Oct 25, 2009 | Nikon Coolpix 8700 Digital Camera
Wont turn on but light is blinking
Are there any error messages on the LCD display?
Will the camera lens stay out when the camera is turned on?
Can you still take a photo/flash/sound without seeing the photo?
If the camera will not turn on even with a fresh set of batteries it could have a system or lens error in the camera.
a possible lens jamb when closed and the green led on top comes on then shuts off after the lens attemps to extend but cant.
Aug 29, 2008 | Nikon Coolpix L11 Digital Camera
Camera possessed, lol
From the menu of the camera, you need to change and select the settings for the pictures. Some cameras have this option where it will take one or more picture automatically. Also check that the self timer is off.
Artgirl
Jul 08, 2008 | Nikon Coolpix 2100 Digital Camera
Lens error !
I had the same problem. I dropped my camera on the floor today while its on. I tried hitting it but it didn't work. So what I did is, I pull the lens or shuttle forward then I close it and turn it back on. It work perfectly fin now. I hope that helps.
Nikon coolpix 2100 camera won't stay on
I've been having problems with the batteries and the camera refusing to start even with fresh batteries. I bought loads of new rechargable batteries and have finally found some that work. Duracell rechargables. Theyr'e brilliant and keep their charge for ages despite continuous use of the camera! Last summer I managed to take 975 photos before the batteries finally decided to give up!
Jan 27, 2008 | Nikon Coolpix 2100 Digital Camera
Mikon Coolpix 2100
My camera freezes like this when the battery starts to run low. I think it has something to do with the flash. I just leave it to sort itself out for a few minutes even though I'm usually missing some good photo opportunities n eventually it sorts itself out. Trick is not to keep turning it on and off, and fiddling with the dial.
Nov 25, 2007 | Nikon Coolpix 2100 Digital Camera
Coolpix 2100 Just Stopped Working
It sounds like your card has got corrupted, probably because the batteries ran out while the camera was writing to the card. It's important that you don't use the card until you've recovered the pictures from it.
If you have a lexar card, the chances are that it came with some card recovery software. I'd recommend you use this to recover the pictures from your card before reformatting it, then it should be good to go.
If you have no luck with formatting it after recovery, the card must be damaged, but I'd be very surprised if so.
Nov 19, 2007 | Nikon Coolpix 2100 Digital Camera
Nikon Coolpix 2100 Digital Camera Logo
90 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
