Question about Samsung CLX 3160fn All-In-One Printer
My Samsung CLX-3160FN prints with the left side of the page being very light, while the right side appears normal.
  • sparmar Feb 18, 2009
    printout fading from left and hard to read but get better as its get to right hand side, can anyone help. thanks.
  • Anonymous Feb 24, 2009
    This is a common problem with this printer, it requires replacement of the black developer roller. If you are under warranty (12 months) then Samsung will replace for you. I had mine replaced after 6 months but now requires replacement again. looks like it will be an ongoing problem.
    President:
  • 670 Answers
If your printer looks like this:
Then you need to clean the developer blades. In the image above it is the black blade that need to be cleaned. If there are streaking on any other color, then they also needs to be cleaned.
To clean the developer blades, look to this link. http://losingambition.com/clp300imagefix/ It describes how to clean them. It only takes a few minutes to do once you get the developers out of the unit. Just be careful when you clean the edge of the blades. You need to make sure that the residue is completely removed from the edge. Also be sure that when you reinstall the blade that the little foam does not get trapped below the blade. Otherwise when you print the side where the blade is not properly installed will have too much color.
If you are afraid of messing your printer up, then you need to buy a new imaging unit. They go around $100.
Posted on Feb 27, 2009
I have a Samsung CLX-3160FN, and after every page
it is most likely that the fuser actuater arm is not sitting back to the sensor properly. open the back door you will be able to see the fuser, on your right hand side you should be able to see a fliper that sit in between a sensor. try to adjust the fliper flag and see if it works.
if it still continue to give you the same error. try remove the fuser four screw 2 side on each. adjust the flag again and fix it back. it should work and double check for any lose small pices of paper jam in the printer.
May 15, 2010 | Samsung CLX-3160 All-In-One Laser Printer
Samsung clx-3160fn won't print
Usually I've seen that happen when you use generic toners. There are 4 toner clutches down the right side, with the right cover off you can see which clutch is doing the grinding. Many of the generics are overfilled and hard to turn and will make the noise until you loosen them by hand turning them til they loosen up, or just replacing.
Dec 28, 2009 | Samsung CLX 3160fn All-In-One Printer
I hve vertical streaks on the left side of the page. Put in new cartride with no help. I have a samsunf clx-3160fn
This is the problem of black developer in the imaging unit.
Please visit Authorised service center and they will change for you.
Oct 14, 2009 | Samsung CLX 3160fn All-In-One Printer
Poor Printing Quality
The last time I saw that I had to replace the HV power supply and prints went back to normal...If it's out of warranty it'll cost around $150.00
Aug 31, 2009 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX-3160FN Vertical lines when printing black
This is a very common problem with Samsung CLX-3160 and CLP-300 printers. The real problem is that the developer blades get dirty with the toner. Buying a new imaging unit will only fix the problem for a short period of time then it starts to get buildup on the developer blades.
You need to clean the developer blades. If there are streaking on any color, then also needs to be cleaned.
Jan 14, 2009 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX-3160FN All in One Printer
open the scanning unit. in scanning unit clean the mirrors.
Sep 16, 2008 | Samsung CLX 3160fn All-In-One Printer
Black lines across page
are black lines appearing on paper after printing from computer or when a fax is sent or recieved or both?
Jan 15, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX 3160fn All-In-One Printer Logo
428 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
