Question about Philips Magnavox MT2501C 25" TV
DVDs Black and White
The TV plays fine on all channels, but DVDs only come in black and white. No inputs I assume means the color streams through the cable connection. Is there anything that can be done when connecting the DVD to the TV that will allow us to watch DVDs in color?
5 Suggested Answers
SOURCE: I can only record and play back in black and white.
siri,
for the black and white screen output of your DVD and VCR.
1) for DVD player: using remote control locate "setup" button and click.a dialogue box should appear indicating " audio setup" video setup" etc.....
2) select and scroll to "video setup". in video setup there should be an option to choose "AUTO" "PAL" or "NTSC"
3) choose "auto" then check if any change in screen color.
for VCR, locate a switch or button indicating "PAL" "Auto""PAL SECAM" "NTSC". same with the dvd choose and select "auto"
note: if you still have the manual for both VCR and DVD check the instruction with regards to video color setting.
cheers,
mark
Posted on Jan 16, 2009
rulds2008
  • 3866 Answers
SOURCE: change input source for philips magnavox
use the up/down channel until you get to the input you have connected. You did not say you had a remote so i am using the standard fix for this.
Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Apr 28, 2009
SpideRaY
  • 687 Answers
SOURCE: DVD PLAYS THE MOVIES BLACK AND WHITE
This is usually associated with trying to play NTSC formatted DVD's on this PAL player. As you might not know even if the unit is set region free (Region Code 0) the movie is still encoded for NTSC.
You can also get this problem if you are using S-Video plug with a SCART Adapter and the switch is set to output instead of input something to do with the internal pins. I recommend using SCART to SCART or HDMI if you have it
LOL
Posted on Sep 24, 2009
  • 1335 Answers
SOURCE: inherited a flat screen tv without remote. cannot
You need to invest in a univeral controller. You can either order one onlne or go to a local store and purchase one. The controller instructions will give you the correct codes to access your TV controls. I don't understand your comment about black and white on the DVD player. Are you having problems hooking up the DVD to the TV? Most problems will be cleared up after you get a remote. If you need a user manual for the TV let me know the model number and we can find the correct source. Thanks.
Posted on Jan 02, 2010
Will only play DVDs in Black and White
Onkyo DV-CP706B 6-Disc DVD Player (Black) - Amazon.com
www.amazon.com/Onkyo...Player-Black/.../B001AMS...
Amazon.com, Inc.Color: BlackChange .... It's quieter than it was before, and it plays ALL DVDs, even if you can see some visible damage ..... THere was no color-just black & white.
Onkyo dvd player no color only black white Questions ...
www.fixya.com > Forum > Tags > dvd player no color only black white
Onkyo dvd player no color only black white related problems. Ask your Onkyo dvd player no color only black white questions. Get free help, advice & support ...
Onkyo dvd player plays black white Questions & Answer
Dec 29, 2015 | Onkyo Dr-s2.2 5.1 Dvd Home Theater...
What does my tv lost color its black and white but when play xbox it color on game?
what model is your tv set ???
tell me more about it and I might be more usefull
Might be a tuner failure if all your inputs work fine but your channels are black and white..
Jul 29, 2014 | LG Televison & Video
Tv plays cable in black and white but plays dvds in color. What is the issue?
Try changing the channel on the TV to 3. Most cable boxes change everything to channel 3.
Oct 21, 2013 | JVC Televison & Video
Why GE TV plays color DVD/VCR tapes in black and white
Some inputs on tvs won't process the color signal. Try one of the other inputs. Mine does the same. If u have already used the working ones on something else, U will need a switch to select one or the other available at Radio Shack if u can find one.
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
Jan 22, 2018 | GE Televison & Video
I have a go video DV2140 that is only a couple months old and suddenly is started playing DVDs in black and white. I've tried different DVDs and they are all black and white now. The TV itself is color...
Bring it back to the place of purchase since the item is under warranty, this is a manufacture defect and you are in your perfect right to have a replacement.
Mar 14, 2012 | Toshiba Televison & Video
Koss dvd player kd305a plays black and white.
Check the av channel on the tv,the av is normaly av2,if it say`s any different then press the av button on the tv r/c until it plays in colour
Oct 15, 2009 | Televison & Video
Panasonic DVD-RV31 DVD Player plays black & white only (no color)
Hi,make sure your tv channel says av2 and not av2s as this will play in b/w,hope this helps
Jul 10, 2009 | Panasonic DVD-RV31 DVD Player
DVDs all play in Black & White
Could be because it is set to NTSC. Needs to be set to Pal.
Mar 27, 2009 | Panasonic Televison & Video
Color to black and white and back again
Since you're using a composite cable (yellow RCA) that carries both luma (brightness) and chroma (color) information, it's not the cable that is the problem.
That means it's either the DVD player itself, or the TV. If you have another video device (VCR, etc) that you can connect to the TV, try that. If the other device also goes from color to black and white, then it's your TV. Otherwise the problem is your DVD player.
Since your TV only has mono audio (white RCA, but no red) I would recommend getting a new TV if the TV is to blame.
Jun 13, 2008 | Sony DVP-NS57P
Philips Magnavox MT2501C 25" TV Logo
41 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
