Question about Jensen VM9510 Car DVD Player
Need bypass code for Jensen VM9311TS
I dont want to have to use the parking brake or the toggle switch. Is there a bypass code to do this? Jensen VM9311TS.
  • Anonymous Apr 07, 2009
    does this work on the Jensen VM9212N too?
  • 165 Answers
Here it is how brother,insert a dvd movie,next use the toggle switch sequence to get image,next press stop button twice on the remote,then press 1 2 6 4 on the remote,you will now see a menu that says
Regon Code
Brake Override(I know you are drooling by now)
Macrovision
Loader Version
Model Version
Using the right joystick on the unit,navigate to the options of your choice,click on them to toggle on,off or which region code you want.
This wht you want.
Region Code 1
Brake Override ON
Macrovision OFF
When you are done,click SYS SETUP on the main remote TWICE to save the settings and vingo.
Posted on Mar 20, 2009
simplemitch
  • 752 Answers
SOURCE: Parking Brake wire on Jensen VM9311TS
It may need to see a Positive....not a ground (the brake wire rests at ground and goes positive when the pedal is pressed). but to answer your question, the brake wire for your car is Light Green and is at the brake switch above the pedal.
Posted on Sep 20, 2007
Shuttle83
  • 1139 Answers
SOURCE: Brake wire for Jensen VM9311ts
You first have to figure out which one of these wires goes to ground potential when the brake is engaged. Get a digital multimeter set it to read resistance (turn the dial to the omega symbol)and then connect one end to ground of the car try the outer ring of the 12 cigarette lighter and the other using the tip to pierce the insulation of one of the wires, then press the parking brake. The meter with the brake not pressed should have ---- when the break is pressed the meter should read 0000 or some value less then 1.000 ohm. The wire that goes to ground when the brake is pressed is the parking break wire and attach your DVD player brake wire to that. My money is on the solid green wire.
Posted on Sep 21, 2007
SOURCE: jensen vm9311ts car tv
ground green pink wire
problem fixed
Posted on Feb 23, 2008
SOURCE: bypass brake code VM9311YTS
just connect the pink wire to the ground wire. some will tell you that a menu will pop up if so just input the numbers 5,4,3,2,1,0 make sure you hear a beep after every number. the menu will look like a hammer icon. im not sure if you have to input the code because i didnt need to
Posted on Apr 22, 2009
SOURCE: bypass parking break feature on the Jensen VM9311TS
with Dvd playing (use toggle switch between the ground and pink .. switch on and off several xs till dvd plays) then on main remote push
stop twice, then 1264, joystick south twice, then once, then sys setup twice to save
Posted on Jun 20, 2009
How to bypass brake jensen vm9215bt
Did this work? none of the codes (543210 / 1264) work for me. I dont want to hardwire it.
Oct 22, 2012 | Jensen VM9215BT
Cant buy pass brake on my vm9311ts
use toggle switch on inout bypass code with remote
May 10, 2010 | Audiovox Jensen In-Dash DVD/CD Receiver w/...
What would be the best way to bypass the E-Brake on a Jensen VM92
If you have the old firmware then all you need to do is ground the parking brake wire
OR
if you have the new firmware(just bought the system) a toggle switch is involved:
1 - connect e-brake wire from dvd unit to the switch
2 - connect a ground wire from switch to the unit chassis(any good metal grounding surface will do)
3 - pop in a dvd, toggle the switch back and forth 2 or 3 times depending on what wire you placed where...and voilaa!! your dvd system should work in motion!!
Jul 02, 2009 | Jensen VM9510 Car DVD Player
Bypass parking break feature on the Jensen VM9311TS
You can purchase an aftermarket bypass kit from electronics store or off ebay... But hey, be careful, no watching movies while driving... K
Jun 05, 2009 | Jensen's VM9312 Car DVD Player
Difficulties in installin of VM9311TS
just by pass it with the bypass code
May 04, 2009 | Audiovox VM9311TS
Make is jensen vm9311TS
HI,
I'll let you know if the codes are available..
Jun 03, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
FRANK-BARBERENA@HOTMAIL.COM
toggle switch. attach the wire (thats supposed to go to the ebrake) from the radio to the switch. then a wire from the switch to ground. on my jensen, you need to turn the switch to off for 5 seconds then on and the screen should show your video just fine.
May 04, 2008 | Jensen VM9510 Car DVD Player
How do i bypass the parking brake switch in order for my video to play
hook the pink wire to a toggle switch and ground the switch to the chassis. when the unlawfull screen comes on then turn the switch on for a few seconds then back off for a few seconds then back on and the screen should go away. I done this with mine and it works. unfortunately you have to do this every time.
Feb 23, 2008 | Audiovox VM9311TS
VM9311ts
no u dont run the pink wire to a toggle stwich and the other side to a ground and u can run it while u drive
Sep 22, 2007 | Jensen VM9510 Car DVD Player
Sep 19, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Jensen VM9510 Car DVD Player Logo
1,874 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
