Question about Lexmark X2500 All-In-One Printer
Need replacement cartridge for my X2500
My printer came with a #2 black and #3 color cartrridge, I can not find replacements ????? I was told a #14 and 15 would do the trick. Ooops, it didn't work. I also tryed #28 and 29, Now what ?
Prettau2@yahoo.com
    President:
  • 1,901 Answers
You can order them from Lexmark. (A bit expensive.) Links below.
#2 Cartridge
#3 Cartridge
Also available at Circuit City:
#2 & #3 Combo
Posted on Nov 22, 2008
COLOR DOES NOT PRINT, NEW CARTRIGE INSTALLED
85e2e31.jpg mohammed387
Rank:wizard_s.gif Wiz
Rating: 79%, 100 votes
contact service center..if u have warranty.. THIS LAST WARING MOHAMMED DONT ANSER ?S U DONT KNOW WHAT U ARE DOING IN THIS IS YOUR LAST WARING THX FIX-YA
Oct 12, 2008 | HP DeskJet 820cxi InkJet Printer
I have an HP Officejet 6500 wireless printer. I have gone thru 3 black cartridges - printer indicating that it is full, however, color will print and not black. I have returned 3 black cartridges, at...
if the printer is in warranty please tell hp to replace it adn if not please try replacing the printhead,
this has resolved several similar issue and is just a suggestion.
you can contact hp on this number 1-800-474-6836 (1-800-hpinvent). if you r in US
Jan 11, 2011 | HP Officejet 6500 Wireless All-in-One...
Changing ink cartridge
  • Here is an instruction set I found at http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html
  • Step 1 Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
  • Step 4 Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
  • Read more: How to Replace Ink Cartridges in a Lexmark X2500 Printer | eHow.com http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html#ixzz0uMXO4kIN
    Jul 21, 2010 | Lexmark X2500 All-In-One Printer
    X2500 All-In-One Printer: why says the black and color cartridge replacement...
    Check to see if the installed cartridge is the correct one for the printer. If the cartridge is the proper part number, remove the ink cartridge and make sure all the packaging tape has been removed from the copper circuitry strip on the backside of the cartridge. Reinsert the cartridge and try printing again.
    If the error continues, remove the cartridge again and clean the copper circuitry strip on the backside of the cartridge, and the contacts inside the printer, by following the instructions below:
    1. Use a clean, dry, soft, lint-free cloth. Locate the copper-colored circuitry strip on the back of the cartridge.
    2. Wipe the copper-colored strip with the dry cloth. Use an upward motion, from the nozzle end to the top of the cartridge. Do not wipe the nozzle end of the cartridge or touch the nozzle plate. Wipe the contacts only once.
    3. To clean the printer contacts, carefully look for fibers or contamination on the electrical contacts inside the carriage assembly, but do not wipe the printer contacts with any object. The contacts in the printer can be damaged if too much pressure is applied during a wiping process. Try to remove any visible attached debris within the carriage assembly by gently pulling the debris off with your fingers. If the carriage contacts show noticeable damage, contact the Customer Care Center listed in the printer's User's Guide.
    Reinsert the cartridge and try printing again. If the error continues, the cartridge may need to be replaced.
    Hope this helps. Please rate my response.
    Thanks.
    Have a good day.
    May 18, 2010 | Lexmark X2500 All-In-One Printer
    Can i print using black ink when im out of color ink it wont let me even though ive changed the settings to print colors as black and white
    That's the way Kodak works
    It won't allow yu to do anything if any of the lights are flashing or there is a error message
    NO RESOLUTION
    Get your color ink cartridge replaced by Kodak.
    Just say its a new color ink cartridge and printer is saying its empty!!
    Hurraay you'll get a free color ink cartridge
    Jan 25, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
    Error message that color cartridge has low ink, so printer won't print. How do I override this? This message occurs when only one color is low and requires replacing the entire cartridge.
    No way 2 override the message. Printer works on a combination of both black and color ink to print those perfect pictures and documents. If it is showing color ink needs replacement,you ve 2 change it in order to print even in black and white.
    Jan 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
    Colour problem
    If the printer gives magenta instead of red you have a problem with one of the other colors. Magenta needs other colors to print red. Print a cofiguration print and check witch color is bad or missing. Replace the cartrridge of the missing/bad color
    Dec 24, 2009 | HP LaserJet 3000n Printer
    Why are only black and yellow printing?
    The printer has two ink-cartridges: black and tri-color.
    The black cartridge has ink left.
    The tri-color cartridge has run out of 2 of the 3 colours of ink.
    Buy a replacement tri-color cartridge,
    and responsibly recycle the "empty" cartridge.
    Nov 19, 2009 | Canon i9100 InkJet Photo Printer
    Where do you insert the ink cartridges on lexmark x4650
    These are the instructions for X2500 Printer
    1.Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
    2.Open the top portion of the printer to reveal the ink cartridges.
    3.Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
    4.Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
    5.Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
    6.Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
    7.Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
    8.Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
    Oct 25, 2009 | Lexmark X2500 All-In-One Printer
    Lexmark X2500 All-In-One Printer Logo
    42 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
