Question about Comfort-Aire Heating & Cooling
Comfort aire model wpc 12 -1 intake/outtake pump is noisy
2 Suggested Answers
  • 415 Answers
SOURCE: weatherking heat pump sounds noisy
Without hearing the "noise" it is difficult to diagnose via internet; however, I can tell you that the 20 degF temperature difference is a good sign.
If the noise is at the outdoor unit, try to determine if it is the casing or something else. Sometimes the casing can rattle and/or vibrate that can cause a sound. Sounds can also come from refrigerant lines rubbing against the casing. Other noise sources at the outdoor unit are the fan motor, fan blade assembly, and compressor. You can remove one of the fan motor wires from the contactor, tape off the end, and start up the unit for a few seconds to see if the noise is still present. Then you can replace the wire and remove the compressor wires from the contactor and repeat the test. This will help you determine where the sound is coming from.
If the sound is coming from your indoor unitl, the most common sources are loose tape, Blower wheel, blower motor, or blower housing. Also look for loose panels.
Without being onsite with toolbox in hand and being able to actually hear the sound, I hope you find this information to be helpful to you moving forward. :-)
Posted on Jun 07, 2010
If I'm having problems with my intake/outtake valve, is there a way I can fix that specific part or do I need a whole new engine?
Depends on the year make model and engine size. Plus what happened to cause this diagnosis.
May 01, 2016 | Cars & Trucks
Ihave 12 volts going into the ac but no power at the comfort control,
There is/are fuse/s in the Comfort Control. It depends on which model. There are also fuses in the control box in the AC behind a cover in some models. Heat Pumps have fuses on their control board on the outside, under the plastic cover.
Mar 22, 2015 | Dometic Heating & Cooling
Engine on but do not pump water
Be sure the inlet and outlet lines are clear. This has a limited suction lift 23' max, be sure you are not exceeding that or the maximum head. each foot is 0.433 Psig so 98 * .433 = 42.43 PSIG.
Specifications Type Self-priming/Centrifugal Caliber 2 in. Maximum Capacity 160 gal / min Total Head Suction Head Self Priming Time 120 sec / 16 ft Engine Type Air-Cooled, Four-Stroke Rated Horsepower 4.0 @ 4,000 rpm Bore x Stroke 56 x 50mm Displacement 123cc Cooling Forced Air Lubrication Splash Oil Capacity Starting Method Recoil Ignition System Transistor Controlled Dimensions Fuel Tank Capacity 1.2 gal. Recommended Fuel Unleaded Regular Dimensions (LxWxH) Dry Weight A-20070116-1378-130-E
Dec 08, 2013 | Yamaha YP20G Water Pump 2-Inch, 160 GPM...
1985 Volvo 740 GLE does not start well when either cold or hot. Have put on new distributor cap, plugs and plug wires. What is the problem?
Check your start injector (under the intake manifold). If OK, check the air valve. 12 VDC at the connector should mean the valve will move when tapped or shaken lightly. To see if it moves - shine a flashlight through the upper opening...
... and verify that you see light on the other side. After five minutes it should close completely. If no change occurs and you have 12 volts at the connector, replace it.
The start injector could also be faulty. It uses a timed thermostat that opens at the operational standard of 60 degrees F. It will pulse on and off and if it's stuck open or closed, this will cause hard starting. The other possible cause is das Luftmassenmesser (Airmassmeter) has failed. Check for breaks in the fine filament around the meter. Also clean it with air mass meter cleaner (NOT brake fluid cleaner!!) and try your starting again; no change, and it is faulty.
Finally, the fuel pumps could need attention, check the fuel filter, tank pump sock (if the tank pump is very noisy it is failing) and tank pump operation. A faulty tank pump makes the main pump work overtime, and this is a major league problem for these cars.
Aug 04, 2010 | 1985 Volvo 740
Pump loses presssure when automatic pool cleaner is installed
If you have outtake valves post filter (versus intake pre-filter and motor) you could try choking those down to reduce flow back to the pool but maintain pressure through your pump and filter...
Aug 26, 2009 | Hayward 1HP Super Pump II Inground Pool...
Vapour does not come out of Omron NEC28 nebulizer
You'll read a lot about making sure that the filter is clean and that the medicine cup is cleaned and that hard water can effect the operation of the nebulizer. However, the problem is most likely in the pump. Even though the pump is running, it is not pushing enough air into the medicine cup. You may even feel air coming out of the tube. When unrestricted, the air will come out, but, once restricted by the medicine cup, the air may not be fast enough to nebulize the liquid. If you want to confirm this, take the tube and hold it to the end of a bike pump, if, while pumpung, you successfully see mist, then you know for sure.
Fixing the pump is not too difficult. Over time, the chamber where the air is compressed becomes dry and, just like a dry bike pump, the air escapes from the chamber due to poor seals. The pump is pretty simple. Make sure it is unplugged from power and remove the screws holding the housing together. Inside you will see the motor, a fan, a power switch and the intake and outtake tubes. Follow the outtake tube to the pump. The junction where the tubes meet the pump is the location of the air chamber. You may need to remove the screws that secure the tubes to the chamber. Once apart, take some grease and lightly coat all of the interior surfaces of the chamber. When finished, reassemble and you're good to go!
Apr 19, 2009 | Health & Beauty
Omron nebulizer will not mist. All tubing is intact. What to do?
Mar 23, 2009 | Omron Healthcare Omron NE-C25 COMP-Air...
Very little mist coming out
Jan 25, 2009 | Mabis CompMist Compressor Nebulizer
Heating & Cooling Logo
111 people viewed this question
Top Comfort-Aire Heating & Cooling Experts
Marvin
Marvin
Cesar Quant
Cesar Quant
Tim Whalen
Are you a Comfort-Aire Heating and Cooling Expert? Answer questions, earn points and help others
