Question about Verona 34 in. CTG536S Gas Cooktop
I HAVE A CORNING COUNTERANGE. I THNK WE BOUGHT IT AROUND 1973. IT HAS BEEN A WONDERFUL APPLIANCE ALL THESE YEARS....BUT NOW THE OVEN THERMOSTAT DOES NOT WORK PROPERLY. THE OVEN LIGHT TURNS OFF BUT THE OVEN ELEMENT DOES NOT....SO THE OVEN JUST CONTINUES TO GET HOTTER AND HOTTER. I CANNOT READ THE MODEL NUMBER BUT THERE IS A NUMBER STAMPED IIN BIG NUMBERS..IT IS 2103306945. IS A THERMOSTAT AVAILABLE FOR THIS RANGE?
YOUR ADVISE DID NOT POSE A SOLUTION TO MY PROBLEM. I THINK YOU SHOULD REFUND THE TWENTY DOLLAR FEE YOU CHARGED ME FOR LESS THAN FIVE MINUTES OF "CHAT". NEITHER OF THE WEB PAGES HAD ANY HELPFUL INFO. WHAT A RACKET YOU HAVE GOING!
Posted on Nov 24, 2008
What does F1 mean
The Fault Code/s will show up in the appliance Display
F0 - No Alarm Signal
Replace Main Electronic Control
F1 - Door will not Lock
Check door lock. Is Door Lock Getting Power
F2 - Door will not Un-Lock
Check door lock. Is Door Lock Getting Power Supply? Check Control Thermostat
F3 - Self Test Error
Disconnect Appliance from Mains Supply, Wait 5 Minutes and then Reconnect to Mains Supply
F4 - Shorted or Open Circuit Oven Temperature Sensor
Replace Oven Temperature Sensor, Check Sensor Harness Connection between Sensor and Control Unit
F5 - Relay Contacts Failed - Sticking
F6 - Power Board Temperature Too High
Check Correctly Installed, Check Cooling Fan Assembly, Ducting and Airways
F7 - Incorrect Polarity - Mains Supply
Check Mains Connection - Live & Neutral round the wrong way
F8 - Power Supply to Interface Problem
Check Wiring Harness, Replace Main Electronic Control
F9 - Procesor is Auto Resetting
Apr 05, 2015 | Electrolux White Westinghouse Stove Range...
I have a 37 year old 3+! corning range which I love. The oven heats between 25-50 high..Help!!
This sounds like replacing (or if possible - adjusting) the thermostat will fix the problem. Fortunately, thermostat technology hasn't advanced to the microprocessor level yet, so you (or your appliance repair person) should be able to find a workable replacement - assuming it isn't a real odd-ball.
Some thermostats allow for minor adjustments - but not all. Since I have no idea which oven you have - there's little more I can provide.
Oct 09, 2013 | Verona 34 in. CTG536S Gas Cooktop
Maytag precision touch control 500 electric smoothtop
The heating coils in the oven need to be inspected very carefully where they plug in to the oven wall. You will need to remove the back covers and check the insulators and wiring harnesses. Over time the insulation can break down and oxidize the metal connections. You can use a voltmeter or test light to verify that the coils are getting voltage from the thermostat/switch. replacing parts is cheaper than buying new if you can find the parts.
Oct 04, 2017 | Cooktops
Whirlpool oven code E2F3, and oven never gets up to the correct temp.
The thermostat in the oven itself needs replacing. Unfortunately, you'll probably need to get a professional in to do this job.
Oct 21, 2012 | Whirlpool Stove / Oven / Range Cooktop -...
My cooktops eye stopped working
Is the oven not working as well? If it isn't working check your breaker for that appliance.
Oct 06, 2012 | Frigidaire FEC36S6EB
Oven problems-electric plugs on oven face don't work
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
May 28, 2009 | Verona 34 in. CTG536S Gas Cooktop
Corning cooktop burner outage
The cooktop has to be examined for failure of the element or the switch. Some of the switches & some of the elements are still around. Have the elements checked for continunity. You will have to take it out of the counter and take the unit apart to do this.
Oct 18, 2008 | Verona 34 in. CTG536S Gas Cooktop
Corning smoothtop electric range
You MUST use flat bottom pans on three of the four burners, the back right burner is the multi-pan burner and accepts any type pan. You'll notice the other burners have a circle in the center, that is the thermostat that reads the temp of the pan, that burner type needs the flat bottom pan to work correctly. The multi-pan has no thermostat and it will boil water in any pan.
Good luck
Jan 18, 2008 | Verona 34 in. CTG536S Gas Cooktop
Verona 34 in. CTG536S Gas Cooktop Logo
442 people viewed this question
Top Verona Cooktops Experts
Steve
Bosse Photos
Pierre Legault
Are you a Verona Cooktop Expert? Answer questions, earn points and help others
