Question about Car Audio & Video
Radio works but there is no display
The removeable face has no display at all the on/off switch working & changing of channels.
  • matt442oldz Nov 30, 2008
    thank you for your help i new that was the case. thank you for your help.....
  • 20 Answers
Your l,e,d display is blown and probably your best option would be to replace the headunit as it will probably cost you more than what its worth to have it fixed ,hope that helps,,goodluck.
Posted on Nov 30, 2008
Why wont my channel change work on my cb
I'll have to answer with a question is the instant 19 or 9 switch selected? Some models an have addition switch on face for quickly changing to one if not both of these channels.
Mar 02, 2015 | Radio Communications
No TX/ rx Radio Shack TRC-495
it probably jumped freq. somehow. There is now manual or anything but a picture of this radio and a few tune up rv's but thats it.I have the exact same radio and it works fine If you can put it on an oscilloscope it should tell you right away what the problem is. Then try a frequency counter.
Mar 06, 2014 | Cobra 29 LTD CB Radio
The lights on the front of my nightwatch is not working but the rest is the meter and channels light up and the dimmer works just the backlighting wont whats the problem thanks
  • That Night Watch face plate is AC ran by a converter inside the radio. The LEDS are part of the face plate and sold as one unit. The face plate goes out often on these radios. In short the face plate needs replaced if you want it to light up. The radio's performance will not be effected by this. Cobra can actually switch that out fairly cheap. Cheaper than buying a face plate used on the net.
  • https://www.cobra.com/index.cfm
Regards, Tony
May 20, 2011 | Cobra 29 WX NW ST 40-Channels Base CB...
Radio was dropped now the channel indicator is not working no way to tell what channel it's on. its a uniden pc68xl is there a resistor or something to check?
If your lucky, its just the display that is broke. You can buy a replacement on ebay cheap. If its not that, you may have broke something else and you would have to trace it. It would need a tech.
If its still working other wise, just find channel 19. Go near a big highway and check all the channels until you find a lot of truckers talking. Then ask them if its 19. once you find 19, make a mark on the dial and on the radio face in the same spot. then when you put the marks together, you will be on 19. then you can just count up and down.
Each spot on the dial is a specific channel.
the other things to check. If you haven't test transmit on the radio, and just put power to it to see if it still worked, check (if it has them) either the cb/pa switch, and make sure its on CB, because some radio's when you go to pa the meter shuts off, and if you have it check the wx/cb switch. this is for weather. Make sure its on cb again, because again, sometimes this turns off the channel display.
If you haven't hooked it all the way up yet and just to power, you may have over looked that.
I have gotten worried quite a few times working on a radio and not realizing it was on pa or weather.
Fingers crossed. Hopefully you just didn't check the switches.
Oct 08, 2009 | Radio Communications
I have a Kenwood KDC MP532U. The face plate will not display.
it more than likely has bad solder connections inside the radio on some surface mount resistors usually located on the right front of the radio as it faces you.
Sep 16, 2009 | Car Audio & Video
Radio Screen has went blank radio plays but cannot change
hi gloria_garre, indications are very similar to what one would experience when the electrical portion of the ignition switch starts to fail. Most of the powered accessories such as the radio, mid, cluster displays etc are directly powered from the electrical portion of the ignition switch. In my experience at the dealer, I have had to replace a few switches, one being on my own parents 2002 530i. I would recommend having it checked, and also make sure your charging system is working to specifications.
Apr 22, 2009 | 2001 BMW 5 Series
Alpine CDA-9856 not receiving XM radio
there should be a reset on the xm box itself if not the alpine has one on the face its a small button the size of a pen tip on the face or behind the face plate..this should do it
Nov 22, 2008 | Car Audio & Video
Car Radio, Casette Player and CD Player not working
Hello Lei,
It sounds like the antenna has came loose from the back of the radio and the wiring harness is loose.
Make sure you have a good ground going to the radio, or this will cause a short and make the radio do strange things, the fact you sometimes get a signal tells me the radio is in working condition.
Sep 22, 2008 | 1997 Ford Expedition
Cb radios-galaxy dx99v
This has an LED channel display, which is the same as the Cobra 29. You can pick up a new one, there are a few color options available. You need to be very proficient with de-soldering and soldering small parts. You need a desoldering iron or desoldering wic, and no bigger than a 30 watt sodlering iron, any bigger can burn the foil trace, and some solder. You have to open the case, remove the faceplate screws, remove the faceplate, remove the channel selector/pcboard, and the channel display pc board together. Now you desolder the pins of the display, aproximately 20, remove the diplay, insert the new display observing direction (make sure it is face with the decimal to the right place), solder each pin to the pc board, and clip off the excess section of the pins (which is sticking out of the back of the channel display pc board. If you have changed to a blue display, you need to remove the orange or green cover, and replace it with a blue one (I make mine from blue transparant report covers) and hot glue it to the inside of the faceplate where the old one would have been. The reason for this is that the blue light will not shing blue thourgh a green or orange cover, and if you use clear, the display will be extremely bright, and the blue cover will knock down the glare a little. Now just put the radio back together and fire it up.
Now with that said, if you think you may have any trouble with this, you can take it to any cb shop and they should be able to help you.
Any more questions, don't hesitate to email me at rollincbmods@yahoo.com
Dean Pitts
Rollin CBs
Aug 22, 2008 | Radio Communications
Car Audio & Video Logo
99 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
